mabbo Samba Member
Joined: October 13, 2004 Posts: 208 Location: United Kingdom
Posted: Wed Jan 30, 2019 3:01 pm Post subject: Og paint - best way to clean up and protect |
Hi,
I have an OG paint 55 Beetle that came from Sweden. There is rust underneath the paint.
Id like to remove some of the staining if possible. Id considered using a rotory polisher to go over it but I dont want it to look too shiny.
How would you best approach this?
Close up:
I have heard of people using Anchor wax which I believe leaves a greasy surface which I wouldnt want, and Collinite 476 but have no idea as have never used either.... This is my first 'patina' car - my others have all been sanded and polished to death.
Cheers |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Thu Jan 31, 2019 5:43 pm Post subject: Re: Og paint - best way to clean up and protect |
Wet sand it with 2000 grit & then wax it. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
EverettB Administrator
Joined: April 11, 2000 Posts: 69831 Location: Phoenix Metro
mabbo Samba Member
Posted: Fri Feb 01, 2019 2:19 pm Post subject: Re: Og paint - best way to clean up and protect |
Thanks for the replies
I dont fancy colour sanding and mopping it to be honest... the paint has loads of raised rusty bits - i tried a clay bar on it and it took the paint off the highs and left black marks... you can see the raised bits here:
I tried the CLR on a small patch with a grey scotch pad. This is the only product I could find - https://www.amazon.co.uk/gp/product/B0731HLFD4/ref...&psc=1
I tried it on a small area of my rear valance, and it just took the OG paint off right back to primer, so Im a bit cautious about using it, but the results do look great on here.
Iv got a bit of paint to get off the front quarter too, not sure the best way to approach this either:
Cheers |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Tue Mar 30, 2021 6:15 am Post subject: Re: Og paint - best way to clean up and protect |
Has anyone used a MrClean Magic Eraser with CLR? I have light material to remove and my thinking is that it won't remove too much original paint.
Cool to see my bus frames on the top of Everest list above although I used the green 3M pads on them.
I'll use TR-3 after cleaning.
It's for my Nissan 720.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
