dc Samba Member
Joined: April 03, 2004 Posts: 1426 Location: Kitsap Peninsula
Posted: Sat Nov 21, 2020 9:55 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Good to see progress on the inner structure of the nose - lots of critical alignment and repair - well done! _________________ 1963 Karmann Ghia |
TRS63 Samba Member
Joined: December 17, 2017 Posts: 1000 Location: Stuttgart - Germany
Posted: Mon Feb 01, 2021 6:23 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Feels so good having again something to report here!!
I had a lot of issues with my beetle, that led to no time for the ghia for several months. But it looks like that it's now over and I plan to work on the ghia every week like before I started in January back on this project
so, what happened the last couple weeks?
I first finished my second door strut, so that I will be able to start the heater channel when time comes.. Of course, everybody loves pictures so:
Then I made a bit on the front-left bottom..here is also some work needed:
same behind the front metal:
so let's measure the fresh metal needed:
and make some place:
the part of the heater channel behind was quite rusted..
then adjusting:
and point welding in place with the tig:
and continuously welding, mostly without extra material, as adjustment was great:
Almost fully welded, next time I will finish the welding, planishing it and then put in primer:
stay tuned, a lot more coming
Antoine _________________ Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
https://www.thesamba.com/vw/forum/viewtopic.php?p=10086685#10086685 |
Marcdeb Samba Member
Braukuche Samba Member
Posted: Mon Feb 01, 2021 8:54 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Looking good as always. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Mon Feb 01, 2021 1:14 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Looking very good.....and more importantly, a good shell....
Compared to....
Can't wait for the next updates!
Vlad _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
TRS63 Samba Member
Posted: Tue Feb 09, 2021 6:39 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
I would be at a loss to figure out how to get all the parts lined up properly again!! I find every step of your restoration to be very educational and it is so interesting to see the construction details of how these cars are designed and built. Keep up the fine work. I can't wait to see the car all back together again. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
kingkarmann Samba Member
Posted: Tue Feb 09, 2021 7:11 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
The word "dedication" does not adequately describe this! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
will t Samba Member
Posted: Thu Feb 11, 2021 9:01 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
TRS63 wrote: |
No problem at all
So, after its arrival, I did a bit of disassembly and created some reinforcement to "replace" the doors:
And then it was time to build a dolly and take off the body:
Now you can enjoy the view on the terrible fiberglass pan riveted by the previous owner
Stay tuned!
Antoine |
Antoine your work is amazing and inspiring. I am in the midst of stripping down a 67 to send to the media blasting shop, where the body will be separated from the frame/pan and both will be blasted. Your support in place of the doors is very tidy indeed. I would not have thought this prudent unless the car happened to be a convertible. Would I be making a mistake in continuing my process without these supports?
Thanks! |
TRS63 Samba Member
will t Samba Member
Posted: Fri Feb 12, 2021 6:22 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
TRS63 wrote: |
Thanks a lot guys, really appreciated
@will t: it depends on your car, normally if your heater channels aren't that bad, you don't need them on a coupé. In m'y case, I knew they were crusty so I preferred being safe it is also quite easy if you do a simple fixture like mine
Antoine |
Makes sense, thanks. And by the way you are inspiring me to learn how to do metalwork! |
TRS63 Samba Member
Posted: Wed Feb 17, 2021 5:15 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Thanks, happy if this thread motivates you to start in the amazing world of metalshaping
the latest update:
After the welding primer dryed out, it was time to tack weld the airbox, only a couple tacks at the beginning to check it assembled:
Seems to fit good:
Then I put the repro "tunnel" for the back part..and it was totally wrong. I compared it with my original..and for sure it was way off...
I then made some cut to "adapt" it:
and welded some tab to keep the position:
Then it was a matter of filling the space by creating the missing part and tig welding it:
now it fits:
and then I removed the old storage primer, put some primer on it and then some paint in the OG color except where welding comes (I put there some welding primer!):
and the some on the body counterpart:
Cheers
TRS63 Samba Member
will t Samba Member
Posted: Sat Mar 13, 2021 1:35 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
That's just plain artwork. Amazing |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Sun Mar 14, 2021 7:23 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Amazing
I also love the work space. I have a thing for timbers and stone. |
TRS63 Samba Member
TRS63 Samba Member
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sat May 29, 2021 6:36 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Awesome as always Antoine! I am really so envious of guys like you who can just fabricate pieces so well and with such precision. Great to see all the hard work you have taken on to preserve this Ghia instead of letting it die in a rust pile!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
theghiagirl Samba Member
Joined: February 15, 2004 Posts: 537 Location: Near Portland, OR
Posted: Sun May 30, 2021 6:40 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Hello Antoine,
Your work is amazing and I love your commitment and determination to bring this Karmann Ghia back to life.
I came across this picture yesterday in one of my photo folders and remembered seeing your 1960 Strato Blue build thread. This is a picture when it was for sale in Portland, Oregon on Craigslist. Maybe someone here knows who owns the Oval window?
