hansh Samba Member
Joined: January 13, 2004 Posts: 616 Location: Bend, OR
Posted: Fri May 07, 2004 4:49 pm Post subject: Need a brain! |
I need a working computer for a 1980, federal model Vanagon. Apparently I fried the one in it. A California model will not work. Let me know here or give me a call if you have one (my internet is down right now so, calling is best but I'll still check the forum).
Hans
541-280-4768 |
Randy in Maine Samba Member
dieselvanagon Samba Member
Joined: March 18, 2004 Posts: 39 Location: Fresno, Cal
Posted: Fri May 07, 2004 8:20 pm Post subject: |
will be out at a pick and pull yourself junk yard tomorrow, (SAT) will see if I can keaster one for you, they should be the same
fed and cal
:fist: |
hansh Samba Member
Posted: Sat May 08, 2004 10:16 am Post subject: |
Would the Cal. and Fed. models work the same??? I actually have a Cal. model ECU sitting in my driveway in a parts van, however, my mechanic seemed to think that it would not work. It definitely has a different number of pins and the wiring in the Cal. model is drastically different. Anyone happen to know this for any reason?? It would be great if either would work, but I'm skeptical.
Thanks,
Hans |
Posted: Sat May 08, 2004 11:53 am Post subject: |
No. To different to work. Federal is federal, CA is CA. I will bet that if you went to Bus Boys or Bus Depot and looked for the part number and for any that cross reference applications, you will find something that will work. Sometimes early rabbits and the like used the same ones BTW. Give it a shot.
Bus Boys is call it a #039-906-021EX for a manual tranny from 80-83 and list the same number for a 79 CA auto.
I see Karl has a post just below me, I would defer to his judgement.
Last edited by Randy in Maine on Sat May 08, 2004 6:09 pm; edited 2 times in total |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Sat May 08, 2004 6:05 pm Post subject: |
No, you cannot swap ECU's between Fed and Cal Vanagons:
California Models:
071-906-021B All Transmissions 1980-1983
Federal Models:
039-906-021E Manual Trans 1980-1983
039-906-021C Automatic 1980-1983
Only Vanagon ECU's will work in a Vanagon.
The ONLY aircooled ECU in all the Fresno and Madera self-serve yards is a Fed manual one in Westside Auto Dismantling. The one in Pick n Pull is a melted glob...... I have been looking for a Calif ECU for over a month.
It seems like all the Vanagons showing up are wasserboxers. Pick a Part in Fresno just put out a complete 84. Pick a Part in Madera has a later, Wolfsberg edition Vanagon. |
Posted: Sun May 09, 2004 8:13 pm Post subject: |
Does the wizard give out hearts and lottery tickets along with brains?
And my little dog too? :2gunfire:  |
Karl Samba Member
Posted: Sun May 09, 2004 10:23 pm Post subject: |
Not sure why Bus Boys says the 80-83 manual ECU is the same as the 79 Cal auto ECU.
The 79 Cal auto trans ECU Bosch short number is C105X.
The 79 Cal manual trans ECU Bosch short number is C104X.
That is all these C numbers fit.
A while back someone asked what the difference was between all the ECU's on bay window buses. VW/Bosch made 4 per year model. Cal auto and Cal manual, Fed auto and Fed manual. I said I have never felt a diference in any of them when I test them in my 77 Westy.
With that in mind, I just went to my EKTA disc to see what VW says the part number of the ECU should be.
That 039-906-021B that Bus Boys says fits fits 79 Cal manual trans.... well EKTA says it is the ONLY ECU available for ALL transmissions in these applications:
1) Calif, from the start of the 77 year model to the end of the 78 year model
2) ALL Fed bay buses from 77 to the end of 79.
EKTA does not show it for 79 Cal!
3) ALL aircooled Fed Vanagons, 80 to 83.5.
The Calif Vanagon is 071-906-021B
No wonder I never felt a difference! There isn't one. |
Posted: Mon May 10, 2004 8:55 am Post subject: |
I gather none of these have the input for the signal generated from the O2 sensor?
Or am I way off base here?
Thanks Karl. You certainly are the guy in the know! |
