Headlight Ring Screw
ricaroo
ricaroo is offline
PostPosted: Thu Mar 14, 2019 10:39 am    Post subject: Headlight Ring Screw Reply with quote
The right side Chrome Ring Mounting tab for the screw is stripped.
I find it hard to imagine that the thin piece of metal had many threads to begin with. I would appreciate any suggestions on how to repair this.
Thanks,
Rick
1971 Standard Beetle 2 dr Sedan 1600dp
guidosarduchi
guidosarduchi is offline
PostPosted: Thu Mar 14, 2019 10:57 am    Post subject: Re: Headlight Ring Screw Reply with quote
Following as I have the same issue
71 Super Beetle Convertible (Thunderbug)
65 AMC Rambler Classic Hardtop
08 Pontiac G6 Hardtop Convertible
Cusser
Cusser is offline
PostPosted: Thu Mar 14, 2019 11:03 am    Post subject: Re: Headlight Ring Screw Reply with quote
Larger-thread sheet metal screw?
Can you please post a good close up of that area (I don't feel like pulling off one of my headlight rings to look)?
Because maybe a rivet nut, clip nut, or similar could work.
https://www.homedepot.com/b/Hardware-Fasteners/Speed-Nut/N-5yc1vZc255Z1z0ztb8
Buggeee
Buggeee is offline
PostPosted: Thu Mar 14, 2019 11:11 am    Post subject: Re: Headlight Ring Screw Reply with quote
CWAVE wrote:
...the screw location for the headlight ring screw was gone (rotted away years ago). So, I had to spend some time fabing up a repair. Threaded a piece of metal and a bit of JBWeld hopefully will hold it in place. I know I should have welded it... but we are in the season of bitter cold, and welding indoors isn't healthy or safe... It'll do. And if it doesn't hold, I can always re-visit it in the summertime.
Thomas
Thomas is out in the garage busy building his car so I thought I'd grab this from his thread as one idea. Here is the link as well. https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=200
One of my screws is stripped out too so I am curious to see what solutions people have tried.
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
ricaroo
ricaroo is offline
PostPosted: Thu Mar 14, 2019 11:55 am    Post subject: Re: Headlight Ring Screw Reply with quote
Cusser,
I believe you found the answer, Slip Nut
Can,t make it to the hardware store today however, I am going to go over in the morning and pick up a Slip Nut and give it a try.
I will post how it works sometime tomorrow
Thanks Cusser for idea.
Rick
ricaroo
ricaroo is offline
PostPosted: Fri Mar 15, 2019 12:32 pm    Post subject: Re: Headlight Ring Screw Reply with quote
I was able to attach the Chrome Headlight Ring using a 10-24 U-Nut, and the results are excellent. The attached photos is the hardware I used.
I went with the 10-24 u-nut and 10-24x2” screw because I wasn’t able to find the hardware in metric. The original screw is an M5 x 50mm.
The picture of the screw and clip are how I oriented the clip when I attached it to the metal tab.
Rick
bnam
bnam is offline
PostPosted: Fri Mar 15, 2019 6:01 pm    Post subject: Re: Headlight Ring Screw Reply with quote
I"ve had luck on this tab and similar ones by using a punch -- I place the tip anout 3/4 on the metal and 1/4 of dia over the hole and hammer the punch -- working my way around the dia of the hole.
I started on the back face and repeated on the front face. This made the hole a bit smaller.
Then used a tap to re-tap/clean the threads. Then put antiseize. This repair has held for several years (did this about 10yrs ago) on my 71.
Click to view image
1952 Citroen TA 11BL
Buggeee
Buggeee is offline
PostPosted: Fri Mar 15, 2019 6:21 pm    Post subject: Re: Headlight Ring Screw Reply with quote
Damn Bnam that's the shitake right there! That will totally work on mine, it's just stripped. Thank you!!!
TonyPgh
TonyPgh is offline
PostPosted: Fri Mar 15, 2019 6:47 pm    Post subject: Re: Headlight Ring Screw Reply with quote
I just saved that photo, I am sure I may deal with this sooner or later on my project thats arriving!
View user's profile Send private message Visit poster's website Facebook Classifieds Feedback
appetite Premium Member
appetite is offline
PostPosted: Sat May 10, 2025 4:24 pm    Post subject: Re: Headlight Ring Screw Reply with quote
To the OP, if you get pinged on this thread, can you tell me the source for U-Nut and screw?
Many thanks if you see this.
69 Westy
ricaroo
ricaroo is offline
PostPosted: Sun May 11, 2025 2:38 am    Post subject: Re: Headlight Ring Screw Reply with quote
Hi,
Local Ace hardware store, I am sure any hardware would carry what you need
Rick
