FullFender Samba Member
Posted: Thu May 02, 2019 9:21 am Post subject: Twin Turbo Kit |
Not sure if this is old news or not? I know that it was discussed on here awhile back and they came to the conclusion that a single would be more efficient. Id like to see how it drives.
https://www.instagram.com/p/Bw5xZjWDJoI/ |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79384 Location: Sneaking up behind you
Posted: Thu May 02, 2019 10:51 am Post subject: Re: Twin Turbo Kit |
Looks KEWL. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Thu May 02, 2019 1:10 pm Post subject: Re: Twin Turbo Kit |
Here is some more photos, I stumbled across. Wonder how much it sets ya back??
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 10940 Location: Oregon
Posted: Thu May 02, 2019 1:20 pm Post subject: Re: Twin Turbo Kit |
FullFender wrote: |
Here is some more photos, I stumbled across. I wonder how much it will set you back? Lol! |
All the way to the back of the seat frame! Lol! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!  |
k@rlos Samba Member
Joined: October 04, 2012 Posts: 499 Location: Suffolk, England
Posted: Thu May 02, 2019 1:37 pm Post subject: Re: Twin Turbo Kit |
As with all things depends how it’s engineered. If it’s built and setup correctly it will drive amazingly and go like absolute f*ck. 2 smaller turbos is far better than a single big 1. Less or no lag and the same if not more power. I follow Vic’s work on Instagram & Facebook, his workmanship and knowledge is outstanding. |
Glenn  Mr. 010
Posted: Thu May 02, 2019 1:41 pm Post subject: Re: Twin Turbo Kit |
This is my favorite twin turbo.
Member #1009
#BlueSquare
Dauz Samba Member
Posted: Thu May 02, 2019 3:16 pm Post subject: Re: Twin Turbo Kit |
k@rlos wrote: |
2 smaller turbos is far better than a single big 1. Less or no lag and the same if not more power. |
Negative. Depends on the application. Factory "twin" turbo motors such as the RX7 and I think the Supra (hybrids on the 300z) have a smaller and a larger turbo to support low and top end. These "twins" almost always get yanked for one big turbocharger IF you're doing any type of top-end motorsports. Nowadays there are variable geometrical turbochargers (aka VGT) that replace having to have "twin" turbos with their variable "vanes" that open and narrow depending on your throttle. So with that said, your assumption is sooo inaccurate.. imo
Dauz Samba Member
Posted: Thu May 02, 2019 3:18 pm Post subject: Re: Twin Turbo Kit |
67rustavenger wrote: |
FullFender wrote: |
All the way to the back of the seat frame! Lol! |
It's pretty common for people to "invert" the rear package tray for more depth in their engine bay. |
theDrew Samba Member
Posted: Thu May 02, 2019 3:30 pm Post subject: Re: Twin Turbo Kit |
curious as to how well a turbo works with 1/2 the exhaust pulses. Twins make sense to me on a V8, but I question on a H4.
But they sure look sweet. Can't imagine all the fab work to make it all fit. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
Posted: Thu May 02, 2019 5:24 pm Post subject: Re: Twin Turbo Kit |
Dauz wrote: |
FullFender wrote: |
/S All the way to the back of the seat frame! Lol! |
I am aware of the package tray modification. There's a turbo bug running around these parts with the turbo between the engine and the package tray. If you didn't look close. You'd miss it. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Thu May 02, 2019 6:00 pm Post subject: Re: Twin Turbo Kit |
Dauz wrote: |
k@rlos wrote: |
These "twins" almost always get yanked |
I agree. With a larger turbo you can reach levels where the twins would start to run out of steam. Even if you dont reach that point there is still room to grow.
theDrew wrote: |
But they sure look sweet. Can't imagine all the fab work to make it all fit. |
I think it would only experience half the exhuast pulses if he had paired 1-4 and 3-2 , right? he used an X-Pipe so theoretically, both turbos are seeing exh gas from all four cylinders?
I believe their first application was in a 21-window bus. |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Thu May 02, 2019 6:49 pm Post subject: Re: Twin Turbo Kit |
It’s missing a belt. |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4277 Location: deepest, darkest Switzerland
Posted: Thu May 02, 2019 10:26 pm Post subject: Re: Twin Turbo Kit |
From A. Graham Bell, I seem to remember the minimum of cylinders you want to run a turbo properly is 3. Something about pulse timing. It's worth checking out what the industry is up to.
My favorite 2-turbo (can't really call it "twin" turbo) is the Porsche 959. It had a small turbo, to spool up quickly, and then when that was saturated, some gates, and solenoids switch the flow over to the bigger one. 2850cc, 450hp. How about the Lancia Delta Integrale Group B with a compressor and turbo?
Now, if the 4 cylinder's exhaust is merged before 2 turbos, I guess it could work. With the total flow of the big turbo divided by two, you should get the same flow, and maybe the smaller turbos will spool up faster. I can't think of another reason to do this, apart from looks. |
oprn Samba Member
Joined: November 13, 2016 Posts: 14680 Location: Western Canada
Posted: Fri May 03, 2019 4:46 am Post subject: Re: Twin Turbo Kit |
I truly believe that the 2 stage dual turbo is the answer for smaller displacement engines. The smaller one covers the hole in the lower end of the power curve that the big one can't and the big one covers where the small one would normally run out of steam at the higher end. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4130 Location: NW Washington
Posted: Fri May 03, 2019 5:58 am Post subject: Re: Twin Turbo Kit |
If Twin turbos wasn't such a nightmare for plumbing I would have tried it....
I have the perfect turbos for twins.......  _________________
richardcraineum wrote: |
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah .. |
cbeck wrote: |
His user name in a previous life was dick head. |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Dauz Samba Member
Posted: Fri May 03, 2019 2:20 pm Post subject: Re: Twin Turbo Kit |
Yeah, if I were to ponder "why" someone would want to twin turbocharge an aircooled flat 4, I'd say it's simply because they can. |
Posted: Fri May 03, 2019 5:07 pm Post subject: Re: Twin Turbo Kit |
Forget the parallel twins..... twins in series would be the way to go.
Have the small turbo fed air by the big turbo.
Under low demand the small turbo would basically draw air through the big one but at high power levels the big one would feed pressurized air to the little one for a compound boost level.
This is kind of interesting......lots of info on youtube on compound, sequential turbos if you want power. You have to weed through the BS.
cbeck wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Fri May 03, 2019 7:01 pm Post subject: Re: Twin Turbo Kit |
clonebug wrote: |
x2 Ive always toyed with a compound setup in the back of my head, but like you said, there is so much plumbing involved.
Heres a question: wouldnt it be better to have a smaller turbo feeding a larger one rather than vice versa so when you are under load/ high rpm the large turbo isnt being restricted by a smaller one down the line? |
oprn Samba Member
Posted: Sat May 04, 2019 4:12 am Post subject: Re: Twin Turbo Kit |
I would also be very concerned about the small turbo grenading from overspeed when the big turbo came on strong! I have not researched the plumbing on the factory set ups but I would think they would be parallel but with a relief valve somewhat like your present waste gate that would feed the bigger turbo after a pre-set exhaust manifold pressure.
I'm not sure how they handle that. |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1397 Location: North Carolina
Posted: Sat May 04, 2019 6:14 am Post subject: Re: Twin Turbo Kit |
One turbo behind the apron, the other above the trans!
What would the plumbing issues be on this configuration?
Could you provide adequate oiling to the turbos? |
