ghiafreek Samba Member
Joined: December 19, 2002 Posts: 958 Location: San Antonio, Tx
Posted: Sat Jul 13, 2019 8:35 am Post subject: Exhaust ...stock or what? |
Excuse me for not knowing but by owning a vanagon, much less a subi conversion, is new to me. I noticed an exhaust leak this morning and found the culprit. Looks like the catalytic converter has cracked at mount near muffler. First off does this all look stock exhaust system for what would of been for the previous 2.1L? Its a 2.5 subaru conversion. Ultimately, I need to know what catalytic converter to buy.
thanks for your help.
Mikesarge Samba Member
Posted: Sat Jul 13, 2019 8:52 am Post subject: Re: Exhaust ...stock or what? |
If not stock, it looks designed to fit in the stock location, more or less. The muffler looks like a gowesty unit, but it’s hard to tell.
The cat looks stock to me, so you could buy a regular replacement and be fine most likely.
However, what happened to me was, once I got my cat off, I noticed rust holes in my muffler, then in my (old smallcar conversion) headers. Now my whole exhaust system is new. All this to say, take a close look at each component before you order parts, could save you some downtime. _________________ 1986 Syncro westfauxlia EJ-frankenmotor
1980 911 SC 3.1 |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10297 Location: Mt Lemmon, AZ
Posted: Sat Jul 13, 2019 9:32 am Post subject: Re: Exhaust ...stock or what? |
I recently replaced everything (Y-pipe, cat, muffler) with components from Rock Auto (brand Walker). Not high end performance stuff but it is just an exhaust and a simple enough task if you have new parts, gaskets & bolts.
Mine is a WBX but I agree, what you have looks very like and original Vanagon system. |
Posted: Sat Jul 13, 2019 9:42 am Post subject: Re: Exhaust ...stock or what? |
| Thanks. Helps a lot. I will double check all before buying. Does sound pretty meaty with a hold in the cat. vroom..vroom!! |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1015 Location: Oakland CA
Posted: Sat Jul 13, 2019 9:15 pm Post subject: Re: Exhaust ...stock or what? |
Mostly stock, but I have never seen vanagon with two O2 sensors in the catalytic converter. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1988 Location: Vancouver Island, BC
Posted: Mon Jul 15, 2019 8:59 am Post subject: Re: Exhaust ...stock or what? |
I put in the GoWest stainless steel exhaust, with cat. It looks quite like the one on the pics here. And The cat does have two ports. On mine, one port is not used. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
jberger Samba Member
Posted: Mon Jul 15, 2019 9:09 am Post subject: Re: Exhaust ...stock or what? |
| davideric9 wrote: |
| Mostly stock, but I have never seen vanagon with two O2 sensors in the catalytic converter. |
Ditto.. I'm guessing he has an OBD2 subi swap, pre and post cat sensors. He'll have to have an extra bung welded to any Cat he buys.
J |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15410 Location: Syracuse, NY
Posted: Mon Jul 15, 2019 11:17 am Post subject: Re: Exhaust ...stock or what? |
| jberger wrote: |
| davideric9 wrote: |
J |
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
