Powder coat vacuum leak ?
EDragnDean
EDragnDean is offline
PostPosted: Sat Jul 27, 2019 1:12 pm    Post subject: Powder coat vacuum leak ? Reply with quote
Replaced the seals on the Thing, and still have an intake leak at the rubber boots. Replaced these boots twice now. So I thought, maybe its the powder coat... looked up powder coating online and it says it is a porous material.
Is it possible that the powder coat is causing the vacuum leak? I've never heard of this before.
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
mondshine
mondshine is offline
PostPosted: Sat Jul 27, 2019 3:48 pm    Post subject: Re: Powder coat vacuum leak ? Reply with quote
The powder coat causing a vacuum leak seems very unlikely.
What have you done to determine that the intake boots are the cause of the leak?
Also, I can't tell from your photo whether the vacuum port on your intake manifold is capped. Is it?
How about these three places?
EDragnDean
PostPosted: Sat Jul 27, 2019 8:20 pm    Post subject: Re: Powder coat vacuum leak ? Reply with quote
1- I cant tune the carb and it wont idle
2- sprayed carb cleaner around the left boot and the idle changes
3- yes its capped, welded shut.
And I haven't checked the circled area, it looks closed, but I will hit it with carb cleaner and see if it changes the idle speed.
Volkzbitz carb, and I swapped it for my know good carb of my other vw and still have the same issue
