big swifty Samba Member
Joined: August 21, 2007 Posts: 255 Location: Formally in Republic of VT; now in Hollywood, FL
Posted: Fri Sep 13, 2019 2:32 pm Post subject: Syncro transaxle with pressure oiling/cooling |
I have been urged to start a new topic to present this info which was previously on pg 16 of this seminal thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0.
Standing on the shoulders of giants…here is my system. A bit of background first:
While stopped at a red light, minding my own business, I was rear-ended by a texting fool. Since my van sits on 16" rims with Syncro.org springs and OME shocks and his car was low, my relatively low-mileage TDI engine was obliterated and the transmission low gear carrier mounting attachments were broken. At first, the ins co wanted to put a “junkyard” engine and syncro box in my van. I had documentation of the rebuilds for both, along with the taller gearing in the "rebuilt" trans. (The rebuilder of my original box did an ok job according to syncroshop. He is an expert Porsche dude who has rebuilt many 911/912 transmissions but not many syncro transaxles.) They also appreciated the rarity of the syncro transmission while searching for a "replacement". I managed to source one of the last (new from VW) factory ALH replacement engines and negotiated a transmission rebuild from the offender’s insurance carrier. I had previously squirreled away an aluminum case and gear carrier from when they were last available from Weddle. As we know, Gears has made available some amazing parts. I went for the GT billet carrier, new GT R&P, new GT mainshaft, new GT 3rd and straight-cut 4th. New low gear carrier and alu bellhousing. All new bearings and syncronizers. So, I basically have a brand new syncro transmission with oiling at the pinion bearing, gun drilled mainshaft and 4th gear.
My wife has instructions that I be buried in my Syncro coffin.
My filtering is a la Soto with 2 Canton housings; one with their stock element and one with Tom’s magnetic filter all fed by a Weddle pump, cooled via a Setrab and temperature controlled with an Inkbird with a manual override. Porn follows:
ALU bellhousing
Billet carrier with a milled 0.001" clearance for 4th gear thrust bearing
Apparently, the measurement has to be done on the inside through the main bearing hole with the gear case installed. Then pulled apart, take out the race and mill out another one or two thou being sure to setup the mill and housing each time. Lather, rinse, repeat.
Low gear carrier
Comparison of what Vermont winters does to a bellhosing vs. new.
1st 2nd and 3/4 slider hub
4th
Drilling for pinion bearing
Assembly begins
Checking clearance for chrome molly retaining ring
Mainshaft and 4th oiler
Good things come to those who wait
Filter housing and plumbing fittings
Magnetic element (not my picture)
Weddle pump and element filter. The pump is mounted on a provided plate with a cover
Suction
Vertical magnetic filter mounting. The cooler and it's ports is visible above.
Cooler behind PS tail light
Distribution manifold before and after mounting. I sheathed the hoses to prevent chafing as it crosses the skidplate
I also sheathed the line going up to the cooler
Oiler input (pardon the blur)
With this configuration, the crossmember has to be clearenced with a BFH
Inkbird
Finis.
I will be watching the filter effluent closely as mileage mounts and will report back. It will be interesting to see what appears on the magnets of an essentially brand new $yncro transmission behind a chipped TDI engine with an 11mm pump, larger turbo, larger injectors. At the time of this rebuild, with about 60k on the previous "rebuild", the used components looked "not bad" according to syncroshop.
I drive thoughtfully. With great power comes great responsibility
Hoping that this will continue to inspire people and push the care and feeding of the Syncro MT as far as we can. _________________ Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. Deleted. Tunezilla Stage2.
1991 Jetta coupe TD. Giles Superpump. SOLD
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Fri Sep 13, 2019 3:09 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
Very, very nice.
I like the location and cover for the pump. How is it mounted to the chassis rails? Looks like it would be bolted but I don't see any hardware in the right of this photo:
| big swifty wrote: |
My nearly complete cooling / filtration system is all still in the packaging. Seeing your system is a reminder to get it installed asap. Thanks for sharing! |
I am square Samba Member
Posted: Fri Sep 13, 2019 3:28 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
Nice work _________________ Dustin
'73 Thing
'86 Syncro Doka
'85 Vanagon
'08 R32
'14 Tiguan |
Posted: Fri Sep 13, 2019 3:47 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
| erste wrote: |
| I like the location and cover for the pump. How is it mounted to the chassis rails? Looks like it would be bolted but I don't see any hardware in the right of this photo: |
Good eye! The plate is held to the rails with self tappers. They went in after the photo. _________________ Evan
1991 Jetta coupe TD. Giles Superpump. SOLD |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10940 Location: Western WA
Posted: Fri Sep 13, 2019 8:29 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
Cool.
How many miles so far?
Did you filter from mile zero?
Having a positive flow of filtered-only oil fed to the center of the pinion bearing seems reasonable the bearing will last much longer.
Plus capturing and removing other trash.
I posted a couple oil-pipe kits in the classifieds for the Guard transaxle gun-drilled Syncro mainshaft.
https://www.thesamba.com/vw/classifieds/detail.php?id=2311854 _________________
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Sat Sep 14, 2019 10:11 am Post subject: Re: Syncro transaxle with pressure oiling/cooling |
| Sodo wrote: |
Did you filter from mile zero? |
Only ~ 150 miles so far. Filtered from mile 2. Just been driving around town to date. I have only been in 4th gear for limited runs on a short stretch of highway. The straight cut 4th gear whine is something to get used too.
Plan on a longer trip soon. _________________ Evan
tjet Samba Member
Posted: Sat Sep 14, 2019 3:58 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
Does the straight cut gear solve any known issues, or is it just stronger? I know there's a 4th gear temp issue at high speeds.
Nice trans, btw. I really like that magnetic filter. I now need to get one just for the cool factor. |
Posted: Sat Sep 14, 2019 4:34 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
| tjet wrote: |
| Does the straight cut gear solve any known issues, or is it just stronger? I know there's a 4th gear temp issue at high speeds. |
Good question. My old (Weddle) used 4th gear is in good condition and seems to have survived a chipped ALH engine. I'll defer to Paul on this question. The straight cut is what he recommended.
I shouldn't have overheating issues (fingers crossed) i am pressure oiling 4th gear. _________________ Evan
gears Samba Member
Joined: October 28, 2002 Posts: 4411 Location: Tamarack, Bend, Kailua
Posted: Sat Sep 14, 2019 5:34 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
Thanks so much for showing the GT parts in action, big swifty .. The build looks extremely professional.
We've been steering TDi guys toward straight-cut gears whenever possible. I believe straight-cut gears will stand up to the powerful pulses of the TDi engine better than helical gears (at least we've had good success with them in Porsche world). _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
4Gears4Tires Samba Member
Posted: Sun Sep 15, 2019 5:57 am Post subject: Re: Syncro transaxle with pressure oiling/cooling |
Aren't straight cut gears extremely noisy? _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
gears Samba Member
Posted: Sun Sep 15, 2019 7:00 am Post subject: Re: Syncro transaxle with pressure oiling/cooling |
The F1 tooth profile ones we made were unfortunately too noisy (sounding like Hewland gears). But the F1 tooth profile is overkill for VW 3rd & 4th gears.
The smaller "street" tooth profile which we now use for VW straight-cut gears are MUCH quieter, with positive feedback from every user so far. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Sun Sep 15, 2019 2:49 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
| 4Gears4Tires wrote: |
| Aren't straight cut gears extremely noisy? |
I don't find it extremely noisy. I actually like the sound now...knowing that it is bathed in clean, coil oil. _________________ Evan
Posted: Mon Nov 22, 2021 4:38 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
Pictures of first transaxle oil change at ~600 miles.
plug
filter
plates
plates
magnets
Posted: Mon Nov 22, 2021 4:54 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
You spent all that effort to drive 600 miles in 2 years?
Looks like the oil filtration system is working well. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
Posted: Mon Nov 22, 2021 5:04 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
Looks like the oil filtration system is working well. |
Unfortunately, yes.
Relocated to start a new venture and then the pandemic hit. I was too busy with the new gig.
I'm happy with the results so far. _________________ Evan
Syncro Jael Samba Member
Posted: Tue Nov 23, 2021 2:16 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
That looks really great. The GT Parts should really perform well even with the TDI pounding.
I was always overkill on replacing the gear oil. Every 10k miles or at least yearly. Oil is cheap insurance compared to transaxle rebuilds. Your magnetic filter is also very nice.
I also set my cooling system up so that in cold months the cooling radiator could be closed off to the ram air so that the oil would heat up quicker. Then I could turn on the circulating pump at 80°f.
I also always ran down the highway with the front diff coupled, if you still have a VC, to take some of the load off the transaxle. Watching the transaxle temps drop when doing this will make a believer out of you.
That is really nice documentation for everyone also! Great Job!
Cheers,
Ron _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17400 Location: Brookeville, MD
Posted: Tue Nov 23, 2021 2:37 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
| Syncro Jael wrote: |
Cheers,
Ron |
Ron, What temp drop did you see coupled vs uncoupled? _________________ Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
valvecovergasket Samba Member
Posted: Tue Nov 23, 2021 2:57 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
wow! super clean install!
one thing maybe to throw out there - depending on the temps youre seeing those push on hose ends may benefit from clamps as well
https://www.anplumbing.com/push-on-ensure-clamps.html
pressure is probably negligible, so its probably not as relevant as it would be on an oil cooler sort of application, but figured it was worth mentioning |
Posted: Tue Nov 23, 2021 3:16 pm Post subject: Re: Syncro transaxle with pressure oiling/cooling |
| dobryan wrote: |
Cheers,
Ron |
Ron, What temp drop did you see coupled vs uncoupled? |
It was usually 2-3°f. I believe Sodo also has documented the reduction in heat while the front diff is engaged on the highway. This can only be the result of less work and stresses on the transaxle.
Once I come into town or down the off-ramp I disengage with a decoupler. _________________ 1987 Syncro Westfalia Hightop - NAHT
