Drilling into fan shroud ok?
Nekomorgan
Nekomorgan is offline
PostPosted: Fri Oct 04, 2019 1:16 pm    Post subject: Drilling into fan shroud ok? Reply with quote
Is it ok to drill a couple holes and mounting screws into the fan shroud? As long as it's not drilling into the fan/alternator backing plate. Its a black doghouse fan shroud
Life is an adventure. With a VW life is an endless adventure.
kangaboy
kangaboy is offline
PostPosted: Fri Oct 04, 2019 1:20 pm    Post subject: Re: Drilling into fan shroud ok? Reply with quote
Perfectly fine. Lots of people mount their coils on different spots on the shroud than they were originally mounted. Some have even cut large holes in their shrouds to run their intakes for FI mods. Just use self tapping screws or run bolts through the whole shroud from one side to the other.
-74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote:
Shocked
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out Laughing
Cusser
Cusser is offline
PostPosted: Fri Oct 04, 2019 1:23 pm    Post subject: Re: Drilling into fan shroud ok? Reply with quote
I've drilled into it too. Look carefully at photo below of my 1835cc engine; I drilled a hole for the return spring for my Weber 40DCNF, and to the right, near that metal fuel filter are two holes with hex head screw plugs that I used to mount the coil remotely when this engine ran dealer-installed AC.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Oct 04, 2019 1:53 pm    Post subject: Re: Drilling into fan shroud ok? Reply with quote
Is it off or on the engine?
The oil cooler is also inside the fan shroud.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Nekomorgan
PostPosted: Fri Oct 04, 2019 2:20 pm    Post subject: Re: Drilling into fan shroud ok? Reply with quote
It's on the engine. Where inside it exactly is the cooler? So I won't drill into it
Mr. 010
Glenn is offline
PostPosted: Fri Oct 04, 2019 2:27 pm    Post subject: Re: Drilling into fan shroud ok? Reply with quote
It's over #3.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Nekomorgan
PostPosted: Fri Oct 04, 2019 2:29 pm    Post subject: Re: Drilling into fan shroud ok? Reply with quote
It's over #3.
Ok, so it isn't close to the front face of the shroud? Cause I checked, the cooler is in the extrusion behind the shroud, exiting behind the rear tin
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Oct 04, 2019 3:08 pm    Post subject: Re: Drilling into fan shroud ok? Reply with quote
One reason I eventually replaced the fan shroud on my Baja Bug was all the damn holes I had drilled in it for mounting a generator style voltage regulator onto it. The holes would wallow out over time so I'd reposition it... eventually, moving it down on top of the generator itself. The holes remained, but I did cover them with some electrical tape until I retired it.
The holes were not the only reason I changed the shroud, I wanted to try an EFI shroud with the venturi ring at the air intake side, to see if engine cooling would be better with it, as I've found that VW engines tend run rather hot at my altitude due to a lack of air density.
you can see some traces of the old electrical tape that I had removed covering the holes in this image:
Andy T.
scottyrocks
scottyrocks is offline
PostPosted: Fri Oct 04, 2019 4:02 pm    Post subject: Re: Drilling into fan shroud ok? Reply with quote
Here is an oil cooler, sans fan shroud, at the base of cylinder 3. Be careful where you drill.
Please ignore the tin. Not my engine.
– D. Tartt, 'The Goldfinch'
Cusser
Cusser is offline
PostPosted: Fri Oct 04, 2019 4:17 pm    Post subject: Re: Drilling into fan shroud ok? Reply with quote
And weird because such "cool tins" are typically on the bottom of the cylinders !
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Fri Oct 04, 2019 4:58 pm    Post subject: Re: Drilling into fan shroud ok? Reply with quote
See the crate in the back ground. GEX!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
raydog
raydog is offline
PostPosted: Sat Oct 05, 2019 4:50 am    Post subject: Re: Drilling into fan shroud ok? Reply with quote
Are you talking about the pallet? Why is that GEX?
Just came across another unique way of installing tin
Cusser
Cusser is offline
PostPosted: Sat Oct 05, 2019 8:48 am    Post subject: Re: Drilling into fan shroud ok? Reply with quote
Actually, that's NOT the correct way to measure 9 or 10 ft lbs of torque !!!
Your photo shows 9 lbs 13 oz of force applied at a force arm the length of the combination wrench, technically where the hook is positioned inside the box end. If we assume that your combination wrench is 4 inches long, or 1/3 of a foot, then you are actually applying 9.8 lbs of force at 1/3 of a foot, or about 3.27 ft lbs to the nut.
