1956 RHD Swedish 23 window samba full restoration
mabbo
mabbo is offline
PostPosted: Fri Oct 18, 2019 12:59 pm    Post subject: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Hi,
Im restoring a Swedish 56 23 window at the moment. Unfortunately its not mine, its a customers. I want this bus so bad. Its pretty rough and has had some really grim previous "repairs".
It will be as close to factory as possible, and has most of the parts ready to put it back together once we have finished the metal and paintwork.
Here it is as it arrived:
We cut the panels off we know are getting replaced ready for blasting:
A few pics the blaster sent me. Waiting to get it back:
And the money shot...
ronjonlasvegas
ronjonlasvegas is offline
PostPosted: Fri Oct 18, 2019 4:10 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
That is a cool bus and I'm sure it will be amazing once it is done. You have your work cut out for you, it is rough. The front frame area and toolbox area under the front seat look seriously hacked. I'm not sure what happened there?
aa390392
aa390392 is offline
PostPosted: Fri Oct 18, 2019 9:36 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Sorry about that front section, shit needs work. Good luck. Anxious to see the progress
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
adriano
adriano is offline
PostPosted: Fri Oct 18, 2019 10:24 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
is it possible that it was originally a LHD?
I remember something on swedish bus with LHD and left cargo door.
Do you have the BC?
mabbo
mabbo is offline
PostPosted: Sat Oct 19, 2019 9:27 am    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Thanks for the replies...
Its been hacked pretty bad around the front but I'm pretty sure it hasn't been converted from lhd.
Will get more pictures online when it's back from the blasters in a few days
Cheers
djfordmanjack
djfordmanjack is offline
PostPosted: Sat Oct 19, 2019 1:33 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Are you sure ?
the shifter base is angled to the left, indicating a LHD. Unless that detail would be the same on a RHD. it is clear to see that they replaced the upper part of frame over the axle due to quite possibly accident damage Confused
this will be a great build to watch, keep us updated please !
62 Dickholmer, custom color Seeblau L360
mabbo
mabbo is offline
PostPosted: Thu Jan 23, 2020 3:26 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Had a bit of time on the samba... Heres a quick update of what we have got done.
Got the bus on the chassis jig:
Braced the body up and cut the crap out ready for the new chassis rails etc:
Repairing the front floor section under the treasure chest:
Repaired the chassis rails and mocked everything else up in place. Welded the sills / I beams / top hats etc together but so it could be removed to complete the welding on the chassis rails:
The new front chassis rails needed reshaping a little as they sat a little too low at the middle of the bus when they were bolted on to the jig at the beam mount and front bumper mounts:
Welded the front repair section to the rear repair section, and the rear repair section to the original chassis rails at the torsion housing area. Cant get to the underside of this section while its on the chassis jig so will finish later:
Welded the front inner chassis rails around the beam mounting area:
When we were happy with the fit of the floor and tool chest panel, they were spot welded as factory:
And fitted in position in the chassis:
We slid the new heater cable tubes into place and welded to the original tube that holds the heater knob/mech:
Positioned into the new tool chest panel and welded in place:
The door gaps were pretty bad:
So we decided to repair the posts next so we could work on the door gaps.
Repaired the A posts next. The originals were rotten around the lower hinge mount but were good above that. The door seal channel we bought wasnt the right shape so we put it in the stretcher:
Then we were ready to repair the A post:
Same on other side:
The RHS B post inner was repaired:
The LHS B post inner didnt look too bad but was full of pin holes but a lot of the outer was good, so we kept as much of the outer as possible, and removed the full inner:
The new panel has no mounts for the semaphores, so they were taken from the OG panel and fitted to the new panel:
Pinned in place:
Probably forgot loads, but thats about where we are up to at the moment Smile
Bulli Klinik
Bulli Klinik is offline
PostPosted: Thu Jan 23, 2020 4:01 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Looks like a great project. Nice, clean work!
Mike K
Bulli Klinik
Colorado Springs
mabbo
mabbo is offline
PostPosted: Wed Jan 29, 2020 2:51 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Not the most exciting update, but we have spent what seems like forever messing around with the silver weld through BBT / Taiwan panels. Not been impressed with any of them so far... Doubt Ill be using them again.
The LHS B post bottom just ended at the sill, so I had to buy a lower KF repair piece and weld it on. Then we spent a bit more time lining the body up and pinning everything in place before we weld anything. Door gaps are getting there now, but not quite right yet:
Back on it tomorrow...
mabbo
mabbo is offline
PostPosted: Tue Feb 04, 2020 1:15 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
More progress Smile The top of the dash and window lip were rotten so I made a small panel, cut the rot out, welded the new section in and ground down:
We ordered a Klassic Fab front panel. It was damaged in transit. Got its pretty good with a bit of hammer and dolly work. Still not 100% though. Few before and after pics:
pyrOman
Fire Master
pyrOman is offline
PostPosted: Tue Feb 04, 2020 2:02 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
mabbo wrote:
I'll be very interested in your approach on welding the front skin to the lower windshield frame! Think
Braukuche
Braukuche is offline
PostPosted: Tue Feb 04, 2020 2:25 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
That sucks about the damage to the nose.
Mine arrived undamaged and was so nice I didn't have to do any bodywork on it, polyprimed, blocked once and shot it.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
mabbo
mabbo is offline
PostPosted: Tue Feb 04, 2020 2:45 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
We got the LHS B post spot welded together, and welded to the bulkhead:
The bulkhead was also spot welded to the front top hat:
The top of the new bulkhead was nothing like factory where it welds to the B post so we made a section for each end and finished it as factory:
Removed the rotten front kick panel and fitted a new one:
Also welded the tubs to the tool chest area:
We trimmed down a Wolfsburg West windscreen panel down and fit it in place at the correct height using our window frames, then pinned it to the front panel, starting in the centre to get the swage as close as possible:
Pinned in place where we want it:
One of the wiper holes and pressings dont line up, so that will need sorting:
And the doglegs pinned in place ready to weld once we are finished with the front panel:
mabbo
mabbo is offline
PostPosted: Tue Feb 04, 2020 2:46 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Hopefully should get the top window frame repair panel welded to the KF nose tomorrow ready to paint before fitting Smile
mabbo
mabbo is offline
PostPosted: Tue Feb 04, 2020 2:48 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Yea I really like the KF front panels. Iv fitted a few WW ones and dont like them as much. The return lips are odd and the pressings around the headlight bowls dont seem to match. I really like the KF panel.
mabbo
mabbo is offline
PostPosted: Sat Feb 08, 2020 8:52 am    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
The corner of the dash and window frame was rotten so I made a small repair panel and welded that in:
The none factory holes were then welded up:
I wanted to replicate the original body number in the new bulkhead panel, so I marked up where it should sit and stamped them back in place:
Not too sure what this number is for, but thought Id replicate it at the same time as fitting the new seat back stop:
Once we had the windscreen repair panel pinned in the right place on the nose, we spot welded it in place:
The back of the dash / inner framework, and inside of the front panel and front valance were epoxy primed and painted body colour before being welded together:
Then we spot welded around the window frames and down the A posts:
Will get the welding on the front panel finished on Monday then that will be it for a while.
PostPosted: Sat Feb 08, 2020 9:25 am    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
I'm not sure either. At one point I thought the numbers matched the end of the VIN # but my '55 doesn't match.
Random manufacturing number used on the construction line?
mabbo
mabbo is offline
PostPosted: Sat Feb 08, 2020 1:03 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Hi mate.
Well, whatever they were for, I love details like this. Such a geek.
Cheers
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sun Feb 09, 2020 12:51 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
There is a thread in one of the beetle forums that shows these random single or double digit numbers stamped in various area around the body. I dont think a definite answer was ever reached but the most plausible was inspector stamps.
Official Dual Carb Thread
mabbo
mabbo is offline
PostPosted: Sun Feb 09, 2020 1:35 pm    Post subject: Re: 1956 RHD Swedish 23 window samba full restoration Reply with quote
Thanks for that mate. Thats interesting Smile
