Exterior Film/Trim Repair Tactics
jmciii
jmciii is offline
PostPosted: Sat Nov 30, 2019 6:12 pm    Post subject: Exterior Film/Trim Repair Tactics Reply with quote
Does anyone know a good way to repair this thin film of black trim around windows?
Peeling it away and then going back with PlastiDip come immediately to mind.
matthewb
matthewb is offline
PostPosted: Sat Nov 30, 2019 7:22 pm    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
I had the same problem. I used a heat gun to help me remove the old vinyl and then sprayed with black plasti-dip. It came out looking pretty good, unless you were looking for it you wouldn't notice a difference.
Joshwa
Joshwa is offline
PostPosted: Sun Dec 01, 2019 12:09 pm    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
you Could just remove and leave it that way like I’ve done. I like it better.
93 Weekender TDI conversion (AHU)
93 MV TDI conversion (1Z)
Weekender rear cot
Late model cabin air filter on 93
Euro spec bumper install on 93
IdeaNerd
IdeaNerd is offline
PostPosted: Sun Dec 01, 2019 12:49 pm    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
@Joshwa I'd be interested what that looks like on your van.
Joshwa
Joshwa is offline
PostPosted: Mon Dec 02, 2019 10:13 am    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
Weekender rear cot
rcowan
rcowan is offline
PostPosted: Mon Dec 02, 2019 10:56 am    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
I'm sorry, all I see is an awesome bumper..... What are we supposed to be looking at again? Smile
Thanks Josh. I was wondering about doing the same thing on our white van. Perfect example for me!
jmciii
jmciii is offline
PostPosted: Mon Dec 02, 2019 12:01 pm    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
Yes. I am inspired. I want to do the same treatment with our silver.
IdeaNerd
IdeaNerd is offline
PostPosted: Mon Dec 02, 2019 12:22 pm    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
@Joshwa Thanks for posting! Smile Appreciated!
Joshwa
Joshwa is offline
PostPosted: Mon Dec 02, 2019 1:09 pm    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
I'm loving the bumper.
Weekender rear cot
Mr Brown
Mr Brown is offline
PostPosted: Mon Dec 02, 2019 8:55 pm    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
I bought new film from an Ebay seller in the UK, pretty close cut but needed some trimming. I took the middle window out to do it. Indistinguishable from the original. 4 years and still looks good. Hardest part was getting the old adhesive off.
postjosh
postjosh is offline
PostPosted: Fri Dec 06, 2019 8:12 am    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
i've been removing the film on my '93. it's hell to get off. some of it just peels but most of it i've ground off with abrasive disks on a portable drill. then i go around the windows with a dremel grinding wheel. i recently bought a clothes steamer and will see if that works when i resume work in the spring. for now i just put some primer over the bare metal i'm eventually going to repaint probably two tone and i will use the alternating color on the lip around the windshield but will leave the window surrounds in the body color.
'93 EV Wkndr – 5 cylinder – 5 speed - 280k+ miles
IdeaNerd
IdeaNerd is offline
PostPosted: Fri Dec 06, 2019 7:04 pm    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
Did you use a heat gun, or just pull it off at ambient temperature?
Joshwa
Joshwa is offline
PostPosted: Sun Dec 08, 2019 6:51 am    Post subject: Re: Exterior Film/Trim Repair Tactics Reply with quote
You should use a heat gun.
Weekender rear cot
