mattlockwood Samba Member
Posted: Thu Mar 31, 2016 3:29 pm Post subject: Wierdest turn signal issue ever... |
1970 Bay...
Turn signals, hazards, work great as theyre supposed to. Actual lights are blinking and the turn signals on the dash blink together.
However, with the ignition in the 'Run' position, the blinkers work, but I get no blinkers on the dash. When I use the hazard light, same thing: actual lights are blinking, but no signals blinking on the dash..
Any ideas? _________________ 1970 Bay Window Bus.
110 hp 6 cyl Aircooled automatic
Last edited by mattlockwood on Thu Mar 31, 2016 4:36 pm; edited 2 times in total |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52793 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Mar 31, 2016 3:39 pm Post subject: Re: Wierdest turn signal issue ever... |
First click on control panel at the very top left of the page, then scroll down to the bottom where it says signature line, now type the model and year of your bus in there and click apply. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Thu Mar 31, 2016 6:01 pm Post subject: Re: Wierdest turn signal issue ever... |
click on pic
Posted: Thu Mar 31, 2016 7:08 pm Post subject: Re: Wierdest turn signal issue ever... |
Ahhhh...., thanks for adding that, so many different signal circuits it's impossible to cover issues with a blanket fix. Start by counting the terminals on your flasher, if it's the OG one it likely has 4, if it's a replacement it's probably got 2 or 3, Kbl needs to be piggybacked on 49a if it has less than 4, or your OG 4 terminal relay has issues internally.
All this assumes your fuel gauge and idiot lights work normally. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon May 09, 2016 1:47 pm Post subject: Re: Wierdest turn signal issue ever... |
So I fixed my fuel gauge issues, all idiot lights working..
Replaced my aftermarket 4 prong flasher with a new one just in case..
Same issues: blinkers and flashers work fine , just no lights on the instrument cluster while key is in "run" position. Instrument blinkers work fine in the "acc" position.,, _________________ 1970 Bay Window Bus.
110 hp 6 cyl Aircooled automatic |
Joined: January 01, 2007 Posts: 17852 Location: sticksville, ct.
Posted: Mon May 09, 2016 2:00 pm Post subject: Re: Wierdest turn signal issue ever... |
there is no "acc" position...off, on, start is how all bus switches work. do you have some sort of aftermarket switch? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Mon May 09, 2016 9:30 pm Post subject: Re: Wierdest turn signal issue ever... |
My bad- "on" not "acc" _________________ 1970 Bay Window Bus.
Posted: Mon May 09, 2016 9:38 pm Post subject: Re: Wierdest turn signal issue ever... |
So then what's the difference between "run" and "on"? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue May 10, 2016 6:34 am Post subject: Re: Wierdest turn signal issue ever... |
Sorry: wasn't clear and had it wrong:
Key out or "off": hazards are blinking and lights blinking on dash
Key in and turned at least one position to the right: hazards blinking and lights blinking on the dash
Key turned two positions to the right: hazards blink but no blinkers on dash- all idiot lights on and fuel gauge indicating fuel level.
Also- turn signals work but no lights on dash _________________ 1970 Bay Window Bus.
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4097 Location: Seattle, WA
Posted: Tue May 10, 2016 12:49 pm Post subject: Re: Wierdest turn signal issue ever... |
Two positions to the right would be "Start". Don't know why the dash indicator lites aren't coming on, but why would you care?
Ordinarily, for the few seconds the key would be in that position, the starter is running and drawing enormous current, causing
the system voltage to drop way low. Maybe too low for the flasher relay to operate.
Still with the aftermarket flasher relay? Did you wire it up as busdaddy suggested above? _________________ '67 bug: seized by the authorities
Posted: Tue May 10, 2016 1:05 pm Post subject: Re: Wierdest turn signal issue ever... |
Oh my goodness:
Trava : hazards blink and indicate on dash
Desl: hazards blink and indicate on dash
Lig: hazards blink but do not indicate on dash. Blinkers blink but do not indicate on the dash
Partida: start position- not concerned about the lighting
I did wire the flasher as BD mentioned: basically did a one for one wire swap from OG relay to new 4 prong aftermarket one
Posted: Tue May 10, 2016 1:24 pm Post subject: Re: Wierdest turn signal issue ever... |
So the Kbl wire is piggybacked on to terminal #49a? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue May 10, 2016 1:47 pm Post subject: Re: Wierdest turn signal issue ever... |
No- I wired each corresponding to its match on the aftermarket. KbL went to K1, which seemed logical.. _________________ 1970 Bay Window Bus.
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Tue May 10, 2016 2:38 pm Post subject: Re: Wierdest turn signal issue ever... |
We need a Spanish or Portuguese translator for the ignition switch.
I found this:
"partida ... departure (act of departing)
start (beginning point of a race)"
Not a three position OG switch: OFF, ON, START
Possibly Spanish or Portuguese switch and a wiring diagram specifically for a Mexican or Brazilian bus would be appropriate.
Aloha
tp |
Starbucket Samba Member
Posted: Tue May 10, 2016 3:02 pm Post subject: Re: Wierdest turn signal issue ever... |
The new after market flasher units HAVE to have 21 Watt max bulbs F&R to work right. WolfsburgWest part # N177322 (single element) and N177372 (dbl element) $1.70 each. |
Posted: Tue May 10, 2016 3:18 pm Post subject: Re: Wierdest turn signal issue ever... |
Starbucket wrote: |
thanks. I'm actually talking about the blinker INDICATORS on the dash, not the external lights....the external lights work great . _________________ 1970 Bay Window Bus.
Posted: Tue May 10, 2016 3:44 pm Post subject: Re: Wierdest turn signal issue ever... |
OK well try switching 49 and 49a incase you got them backwards unless you marked the wires when removing from the old flasher. 49 goes to the emergency flasher switch and 49a goes to a triple connector. |
Tcash Samba Member
Posted: Tue May 10, 2016 6:21 pm Post subject: Re: Wierdest turn signal issue ever... |
Tom Powell wrote: |
I found this:
Aloha
tp |
http://www.thesamba.com/vw/forum/viewtopic.php?p=5609119#5609119 |
Tcash Samba Member
Posted: Tue May 10, 2016 6:36 pm Post subject: Re: Wierdest turn signal issue ever... |
Follow the Green wire on E3 E-Switch #15 to the fuse box. Make sure the Green wire and the Black wire from the dash turn signal lights are connected to that fuse on the fuse box.
Good luck
Tcash
Posted: Mon May 16, 2016 8:50 am Post subject: Re: Wierdest turn signal issue ever... |
busdaddy wrote: |
So the Kbl wire is piggybacked on to terminal #49a? |
Ok- so I piggyback kbl onto 49a on the relay. Lights now come on the dash with the key "on"...
But it's both blinkers on the dash blinking now, whether I do left or right turn signal  _________________ 1970 Bay Window Bus.
