sphet Samba Member
Joined: November 09, 2016 Posts: 258 Location: Vancouver, BC
Posted: Tue Jun 30, 2020 5:41 pm Post subject: Sliding door inside rear-most handle bracket replacement? |
Hello,
My rear-most handle on the inside of my slider has always been loose. I took the panel off and it seems the bracket with the square bit sticking out is quite bent and looks like it has been spot welded. The screw holes in the sheet metal are stripped so the screws are no longer holding it in.
I will try to buy 'the next size up' of screw to make the fit tighter, but I wonder if the bracket is available anywhere? I could not find a part number.
Also before I put a new panel on should I waterproof it somehow? The original panel had plastic on the outside. Would a coat of acrylic medium be enough?
_________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee
MarkWard Samba Member
Joined: February 09, 2005 Posts: 14120 Location: Palm Beach County, Florida
Posted: Tue Jun 30, 2020 6:31 pm Post subject: Re: Sliding door inside rear-most handle bracket replacement? |
Can’t help you, but in our camper I have never used that handle. In hindsight, when I fabricated the new panel, I would have deleted it. I do not like that original insulation, I removed all of it and replaced with 4 layers of Reflectix from Lowe’s. All of the sill rust seemed to be a result of the OE insulation holding moisture. _________________ 1982 Vanagon Camper with ALH TDI.
1990 Vanagon Camper Syncro.
In Car https://youtu.be/5hbfdUJR88Q |
sphet Samba Member
Posted: Tue Jun 30, 2020 7:46 pm Post subject: Re: Sliding door inside rear-most handle bracket replacement? |
MarkWard wrote: |
Can’t help you, but in our camper I have never used that handle. In hindsight, when I fabricated the new panel, I would have deleted it. I do not like that original insulation, I removed all of it and replaced with 4 layers of Reflectix from Lowe’s. All of the sill rust seemed to be a result of the OE insulation holding moisture. |
Thanks Mark — I can appreciate your perspective. I don’t know if my hinge is going or the bearings need replacing, but I benefit from that handle to pull the door shut.
How did you attach the Reflectix to itself and the wall? Did you use a sound deadening product as well? And finally did you put a vapour barrier between the metal and the panel? _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
plummerdesign Samba Member
Joined: September 04, 2010 Posts: 465 Location: Portland OR
Posted: Tue Jun 30, 2020 8:21 pm Post subject: Re: Sliding door inside rear-most handle bracket replacement? |
That IS a tough part to locate. It is riveted in place, so needs to be drilled out for replacement. Looks like this area on your sliding door has seen some 'action'. Indeed, the pull handle is quite useful to close the door from the inside quietly. From 1985 onward the mechanism was totally changed to keep hands away from the latch area. The pull handle was deleted.
There is a fellow near you on CL in the Richmond area with an '82 shell. Might be worth asking for that part.
When I cannot locate this stuff, or have no time to scour U-Pull It yards there is a useful place to go. Not cheap though.
https://www.bus-ok.de/T25-sliding-door
You could ask if they have this part (share a photo). _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
sphet Samba Member
Posted: Tue Jun 30, 2020 8:28 pm Post subject: Re: Sliding door inside rear-most handle bracket replacement? |
plummerdesign wrote: |
That IS a tough part to locate. It is riveted in place, so needs to be drilled out for replacement... |
I don't think it was riveted in place - it looks like it has original counter-sunk openings in it - but who really knows.
I'll call around and see what I can find - thanks for the tips. _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 295 Location: Grove City, OH
Posted: Wed Jul 01, 2020 4:22 am Post subject: Re: Sliding door inside rear-most handle bracket replacement? |
The actual latch for the door is on the rear so this handle is very helpful to fully latch the door when closing it from the inside.
The fiberglass insulation inside the slider, inside the hatch and behind your kitchen all retain moisture and if your van has not already starting rusting in these areas it's just a matter of when and not if. We removed all of this old fiberglass and reinsulated with a combination of lengths of closed foam pipe insulation and sheets of reflectix. _________________ '74 Thing
'83 Westfalia |
Posted: Wed Jul 01, 2020 5:52 am Post subject: Re: Sliding door inside rear-most handle bracket replacement? |
My feeling is the inner areas need a way to dry out. It probably also depends on your climate, if you have AC, camping heat etc if you need to use a plastic sheet.
We must be lucky. When I’m closing the slider, I grab the forward handle which unclips the door. I give the door a pull closed and momentum brings the door closed and latched. The rear handle is located that you don’t even have access till the door is already mostly closed. I suppose if you were sitting in the back seat and the door was slightly open, you could grab that handle and pull it closed. Just not how we use it.
I did stick some barrier to the sheetmetal called Be Quiet. The stacked panels of reflectix seem to stay in position fine without glue. _________________ 1982 Vanagon Camper with ALH TDI.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 8855 Location: Orbiting San Diego
Posted: Wed Jul 01, 2020 6:23 am Post subject: Re: Sliding door inside rear-most handle bracket replacement? |
I consider a rear grab handle on the slider to be a huge benefit.
Once I put one in one of our vans my wife decided it was to be standard.
Easy to close while seated on the bed or bench.
No need to get the door up to speed.
Quieter at night.
Mark |
dobryan Samba Member
Joined: March 24, 2006 Posts: 12975 Location: Brookeville, MD
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 2897 Location: Dartmouth, Mass.
Posted: Wed Jul 01, 2020 10:11 am Post subject: Re: Sliding door inside rear-most handle bracket replacement? |
crazyvwvanman wrote: |
Quieter at night.
Mark |
I just added this to my list of staycation van projects items. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
sphet Samba Member
Posted: Wed Jul 01, 2020 10:20 am Post subject: Re: Sliding door inside rear-most handle bracket replacement? |
Quieter at night.
Mark |
Mark - is the hanging loop-handle-thingy standard? I think I have a hole in the pillar right there and have wondered what it's for. How is it installed? _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
Posted: Wed Jul 01, 2020 12:56 pm Post subject: Re: Sliding door inside rear-most handle bracket replacement? |
The loop grab handle is OEM.
