Tiico and/or Kennedy flywheel weight ?
syncroserge
syncroserge is offline
PostPosted: Sun Oct 02, 2011 7:45 am    Post subject: Tiico and/or Kennedy flywheel weight ? Reply with quote
Putting together an AFN setup for a friend's syncro. He has the adaptor plate and flywheel but there are no markings of any kind on them.
Anybody know how much they weigh or have one they can put on a scale?
I will call Kennedy but what is the contact info for who now deals the Tiico?
merci les copains Smile
Outback Kampers
Outback Kampers is offline
PostPosted: Sun Oct 02, 2011 8:20 am    Post subject: Reply with quote
All Kennedy plates I've seen have a timing hole below the manifold side of the engine, and marks for TDC on the backside of the flywheel.
But - if I were building this, I would never use a Kennedy plate to build a Syncro TDI. Just not as strong as the proper bell housing setup - risk of pulled studs, flexing, cracking. I've seen it before.
Karl Mullendore
1990 Syncro 16" sunroof Reimo highroof conversion
1990 Westy Multivan 112i automatic
1992 LT31 Karmann Distance Wide 'La Tortuga'
2014 Touareg X TDI
syncroserge
PostPosted: Sun Oct 02, 2011 8:45 am    Post subject: Reply with quote
Agreed..not a big fan of the adaptor plate either. I've been pushing hard
for a "proper" Wink setup..
thanks for the Kennedy info.
rcook52459
rcook52459 is offline
PostPosted: Sun Oct 02, 2011 7:38 pm    Post subject: Reply with quote
these are the people for tiico conversions now. http://www.foreignautosupply.com/Tiico_Owners_Page.html
85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu May 03, 2018 9:02 pm    Post subject: Reply with quote
Hi folks.
This is for a "Rabbit" Kennedy adaptor kit but is likely the same for all applicable Kennedy flywheels.
Is the #1 TDC mark on the Kennedy flywheel a countersunk hole? Or?
Thanks
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
mathieux46
mathieux46 is offline
PostPosted: Tue Dec 08, 2020 9:10 pm    Post subject: Re: Tiico and/or Kennedy flywheel weight ? Reply with quote
Hi,
Kennedy confirmed me their flywheel weight for a 3600 VW inline kit weight is 17 lbs.
I'm now wondering how much this flywheel would improve smoothness on my TDI swap which currently have a light 12 lbs flywheel.
Thanks
Mathieu
danfromsyr
danfromsyr is online now
PostPosted: Tue Dec 08, 2020 9:35 pm    Post subject: Re: Tiico and/or Kennedy flywheel weight ? Reply with quote
ALOT
diesels are no place for a lightened flywheel
mathieux46
PostPosted: Wed Dec 09, 2020 10:01 am    Post subject: Re: Tiico and/or Kennedy flywheel weight ? Reply with quote
Danfromsyr,
Thanks!!
Seeking the heaviest flywheel I can use with an adaptor plate. Up to now it seems to be 17 lbs, which is still much lighter than a VW diesel SMF ( 22 lbs).
Would you know any other options?
Thanks
Mat
