Kubel 2021
Page: 1, 2, 3, 4  Next
fastmc25
fastmc25 is offline
PostPosted: Wed Feb 03, 2021 4:20 pm    Post subject: Kubel 2021 Reply with quote
1973 Model. Spent about 15 yrs in a barn before a few sitting out in the elements.
Peace,
Paul
1973 Type181 Kubelwagen (Thing 2 ) 2110cc
1971 Transporter (Pickle) 1914cc
1961 Deluxe Beetle (Christine) 1776cc
1973 Adventurewagen Baja Bus (Clyde) 3.4L
1970 Formula Vee Beetle 2276cc
I identify as: “A Grumpy Old Vet”
fastmc25
fastmc25 is offline
PostPosted: Wed Feb 03, 2021 4:23 pm    Post subject: Re: Kubel 2021 Reply with quote
It needs everything to be touched with my magic fingers. 😂
Pans are gone.
Peace,
Paul
fastmc25
fastmc25 is offline
PostPosted: Wed Feb 03, 2021 4:32 pm    Post subject: Re: Kubel 2021 Reply with quote
Engine runs. Checked it over. Fresh lube, plugs points and carb.
Muffler was toast
Peace,
Paul
fastmc25
fastmc25 is offline
PostPosted: Wed Feb 03, 2021 4:36 pm    Post subject: Re: Kubel 2021 Reply with quote
The plan is to concentrate on refurbishing the chassis first, then body. Engine will be last.
Peace,
Paul
fastmc25
fastmc25 is offline
PostPosted: Wed Feb 03, 2021 4:42 pm    Post subject: Re: Kubel 2021 Reply with quote
Refurbished chassis with new pans. rustproofing inside and out with Master Series silver/ chassis black then undercoated underside. Rebuilt front and rear suspension with new everything including disc brake upgrade. 21mm master cylinder.
Peace,
Paul
fastmc25
fastmc25 is offline
PostPosted: Wed Feb 03, 2021 4:43 pm    Post subject: Re: Kubel 2021 Reply with quote
Peace,
Paul
Dougster43
Dougster43 is offline
PostPosted: Wed Feb 03, 2021 8:09 pm    Post subject: Re: Kubel 2021 Reply with quote
Looks like fun and you are making quick progress. Good luck!
fastmc25
fastmc25 is offline
PostPosted: Wed Feb 03, 2021 8:13 pm    Post subject: Re: Kubel 2021 Reply with quote
Thanks. Being retired helps albeit less income. 😂
Peace,
Paul
s.e.charles
s.e.charles is offline
PostPosted: Thu Feb 04, 2021 2:41 am    Post subject: Re: Kubel 2021 Reply with quote
time beats money every day.
you can always make money; time? no way.
fastmc25
fastmc25 is offline
PostPosted: Fri Feb 05, 2021 3:48 pm    Post subject: Re: Kubel 2021 Reply with quote
Installed transaxle and new cv’s. Cleaned and Repacked rear wheel bearings.
Now waiting for $$$$ to get rear brakes 🤔😂
Peace,
Paul
fastmc25
fastmc25 is offline
PostPosted: Fri Jun 24, 2022 11:33 am    Post subject: Re: Kubel 2021 Reply with quote
Fresh paint today !😎
Peace,
Paul
fastmc25
fastmc25 is offline
PostPosted: Fri Jun 24, 2022 11:38 am    Post subject: Re: Kubel 2021 Reply with quote
Have come a long way since my older posts
Peace,
Paul
fastmc25
fastmc25 is offline
PostPosted: Fri Jun 24, 2022 11:43 am    Post subject: Re: Kubel 2021 Reply with quote
Peace,
Paul
Semper_Dad
Semper_Dad is offline
PostPosted: Fri Jun 24, 2022 12:00 pm    Post subject: Re: Kubel 2021 Reply with quote
Great job!, Keep knocking it out.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
fastmc25
fastmc25 is offline
PostPosted: Fri Jun 24, 2022 12:27 pm    Post subject: Re: Kubel 2021 Reply with quote
Thanks. I’ll hopefully start assembling it next week. Then i can start my engine build. Building a new “0 mile” 2110cc. 😎
Peace,
Paul
s.e.charles
PostPosted: Fri Jun 24, 2022 1:46 pm    Post subject: Re: Kubel 2021 Reply with quote
nice paint & wheels
Joe 20
Joe 20 is offline
PostPosted: Fri Jun 24, 2022 7:55 pm    Post subject: Re: Kubel 2021 Reply with quote
Very nice job! The skill(s) that some people have never cease to amaze me!
"Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy
fastmc25
fastmc25 is offline
PostPosted: Sat Jul 09, 2022 7:46 pm    Post subject: Re: Kubel 2021 Reply with quote
Got more done this week
Peace,
Paul
oscarsnapkin
oscarsnapkin is offline
PostPosted: Sun Jul 10, 2022 3:38 am    Post subject: Re: Kubel 2021 Reply with quote
Nice job. How did you go about applying Master Series to the pans? I have done my whole chassis and more or less every other part of the with mixed results. It seems like the flatter the surface, the worse it looks, for example the rear acces cover plate came out like shit so matter what I did. Parts like the control arms/spindles came out great. I also had this weird problem where for some reason the black (I used AG111, not the chassis black) went on with a dull finish instead of the nice gloss. Did you thin the paint, spray, etc…? I sandblasted (pans I will scuff with sandpaper, I’m done with blasting) and applied paint with foam brushes. Two coats silver, and then 2 coats of black. I’m hesitant to do the pans because I’m worried they’re going to look awful.
- 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind."
fastmc25
fastmc25 is offline
PostPosted: Sun Jul 10, 2022 4:27 am    Post subject: Re: Kubel 2021 Reply with quote
I used a 3” fine bristle brush on the pan. Put it on a little heavy and it flows out better. You’re never gonna get rid of the brush marks totally unless you spray. Foam brushes just disintegrate so I never use them
If you decide to spray get a cheap gun that you’re not worried about so you don’t mess up a good one. As master series if it sets up in the gun very long it is gonna be a pain in the butt to get completely clean
. I usually undercoat the underside of the pan so it comes out really nice. On the suspension parts I use VHT epoxy for chassis and suspension. Comes out a nice semi gloss black and it’s very hard.
Hope this helps.
Peace,
Paul
Page 1 of 4
