alaskadan Samba Member
Joined: January 09, 2013 Posts: 1971 Location: anchor pt. alaska
Posted: Wed Dec 30, 2020 10:03 pm Post subject: 83 diesel camper with bad engine - what would you do? |
| Pretty much says it all. There's an 83 diesel camper nearby for sale with a "bad piston". I gather that an original diesel is a slug. The bell housing and fuel tank are specific. Is the bell housing needed for any specific conversion? Asking 4k I'd try and kick em to 3500. Like I need another van, but visiting friends or family would dig it. Thoughts? |
valvecovergasket Samba Member
Posted: Wed Dec 30, 2020 10:07 pm Post subject: Re: 83 diesel camper bad engine what would you do |
theres quite a few worthwhile parts on that for a potential swap.
the fuel tank isnt unique to the diesels.
that seems like crazy money for a non running van though. unless its really really clean otherwise... |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10524 Location: Sunshine Coast B.C.
Posted: Wed Dec 30, 2020 11:13 pm Post subject: Re: 83 diesel camper bad engine what would you do |
Is there any chance this '83 has a 5 speed?
Neil. _________________ 1981 Westy DIY 15ยบ ABA
(VW Gas I4)
1988 Westy DIY 50ยบ ABA
VE7TBN |
Posted: Wed Dec 30, 2020 11:47 pm Post subject: Re: 83 diesel camper with bad engine - what would you do? |
| Most 37 year old non runners were long ago winched up onto a trailer and hauled off and crushed. Yes it would have to be dang nice to merit that kind of price. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24498 Location: NYC/Upstate/ROW
Posted: Thu Dec 31, 2020 3:30 am Post subject: Re: 83 diesel camper bad engine what would you do |
| Vanagon Nut wrote: |
Neil. |
I never realized it but my 1983 diesel had a 4 speed with granny gear.
The first was so low it was unusable on flat ground
On edit - fake news, it didnโt have a granny gear per experts below _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐
Gnarlodious  Samba Member
Joined: September 28, 2013 Posts: 2413 Location: Adobe Jungle USA
Posted: Thu Dec 31, 2020 7:53 am Post subject: Re: 83 diesel camper with bad engine - what would you do? |
Either they donโt really want to sell it or they are fantasizing at the high value of Vanagons recently. It might be worth $3,500 if it is nice condition. _________________ Vanagon โ83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
4Gears4Tires Samba Member
Posted: Thu Dec 31, 2020 7:57 am Post subject: Re: 83 diesel camper with bad engine - what would you do? |
I'm getting to the point where I would feel bad if anyone paid me for my van. "Oh no, what are you doing to yourself? Do you even realize?"  _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
Escorial Syncro Samba Member
Joined: May 02, 2004 Posts: 449 Location: Manitou Springs, CO
Posted: Thu Dec 31, 2020 8:22 am Post subject: Re: 83 diesel camper with bad engine - what would you do? |
I won't comment on the value, Dan knows what he's looking at and while I'm sure there's cheaper diesel westies with bad motors sitting around, there's probably not many sitting around in Homer Alaska!
I think that van (if clean, rust-wise) would be great if you ever wanted to put an early TDI (AHU or 1Z) in as the oil pan and most of the mounting hardware bolt up. A mechanical pump could make it easy if you don't like electronics. Or an AAZ with mechanical pump.
It would be great if it's a 5 speed as those had somewhat nicer mounting engine hardware in my opinion.
Sounds fun!
Joel _________________ Joel Lane
1985 Vanagon converted to syncro, ALH TDI w/GTB2056 turbo, Reimo clone top with Westy interior
2002 Toyota Tundra 4x4 |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10156 Location: Where?
Posted: Thu Dec 31, 2020 8:27 am Post subject: Re: 83 diesel camper bad engine what would you do |
| Abscate wrote: |
The first was so low it was unusable on flat ground |
The '83 diesel 5-speed is not a 4-speed with a low 'granny gear'. With a significantly more powerful engine than the stock 1.6 it is possible to start in second but even still requires riding the clutch. Starting an '83 5-speed 1.6 non-turbo in second gear was not intended by the factory and is a markedly unwise thing to do.
The stock '83 diesel DX 1st gear ratio is 4.11 and second is 2.33. The stock 4-speed 1st gear ratio is 3.78. Yes, the 5-speed first gear is lower than the 4-speed ratio as all of the ratios are closer together, but it is not a granny gear. For perspective, the syncro granny gear ratio is 6.03 and 1st is 3.78.
All of the 5-speeds in other markets had the same 4.11 1st gear but with taller R+P ratios. All five gears are useful and necessary for all normal driving. |
Posted: Thu Dec 31, 2020 8:36 am Post subject: Re: 83 diesel camper with bad engine - what would you do? |
| Hmm, kinda surprised here. Seems a full camper in ok condition that runs would be worth 10k. I guessed that I couldn't get hurt too bad after fixing it or doing a suby conversion on it. It looks to be a riviera. It just peaked my interest because it is a diesel and wasn't sure if thats what you want for a TDI conversion. Not sure about the 5 speed. There are fewer cheap full campers to pick from up here. |
| Escorial Syncro wrote: |
| A mechanical pump could make it easy if you don't like electronics. |
...Or even if you DO like electronics, but prefer added reliability over added unnecessary complication that doesn't give any real benefit. A proper mechanical pump will also give easier tuning without sacrificing any performance. |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17381 Location: Brookeville, MD
Posted: Thu Dec 31, 2020 9:01 am Post subject: Re: 83 diesel camper with bad engine - what would you do? |
If the same deal popped up near me and the body was in decent shape and the trans was the 5-speed, I would buy it. The engine is easy to upgrade to Mk3 mTDI and the 5-speed is great.
I recently installed an AHU mTDI into an '83 with the DX 5-speed and had the R+P swapped from the stock 5.43 to the 4.14. IMO it is a really nice end result. Comfortable cruising above 70 with fuel economy above 30 MPG.
With stock tires the rpm @ speed in top gear is as follows:
2500 @ 58
3000 @ 70
3500 @ 81
4th gear downshifts for steep highway grades give the following:
3500 @ 61
4000 @ 70 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19160 Location: Retired South Florida
Posted: Thu Dec 31, 2020 10:14 am Post subject: Re: 83 diesel camper with bad engine - what would you do? |
| The days of the $800 campers are behind us. I'd say if you want it, buy it. Any 30 plus year old vehicle is going to need eventually everything. If it were near me, I'd also buy it. Our 82 diesel camper mated to a 1.9 TDI drives like a modern vehicle. Plenty of power. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Thu Dec 31, 2020 10:32 am Post subject: Re: 83 diesel camper with bad engine - what would you do? |
| dobryan wrote: |
Buy it! But perhaps I am not the best person to give advice about buying another westy....  |
Yup, your credibility as an interventionist is shot!!  _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Thu Dec 31, 2020 11:27 am Post subject: Re: 83 diesel camper with bad engine - what would you do? |
| ?Waldo? wrote: |
2500 @ 58
3000 @ 70
3500 @ 81
3500 @ 61
4000 @ 70 |
This is what I was thinking except maybe with a gas inline engine. Just kidding. My first thought was an AAZ.
I know the engine is "bad" but if it is non op and tranny can't be tested, [edit] the van becomes somewhat less desirable, IMO. All depends on price of course.
(VW Gas I4)
VE7TBN |
Posted: Thu Dec 31, 2020 11:45 am Post subject: Re: 83 diesel camper with bad engine - what would you do? |
Neil. |
There's always a chance that a non-running engine is coupled to a ruined and non-rebuildable trans, but not all that likely. The swap to a tall R+P requires all the work of a trans rebuild anyway and if the current R+P is bad it is a non-issue if it is being replaced. Odds are good that if the engine has failed, the trans is at least rebuildable with a new R+P. |
Posted: Thu Dec 31, 2020 2:04 pm Post subject: Re: 83 diesel camper bad engine what would you do |
| ?Waldo? wrote: |
| Abscate wrote: |
Thanks fir setting me straight Waldo. It's been a few years since I sold this one but you did not need to slip 2nd to start. _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
Posted: Thu Dec 31, 2020 3:21 pm Post subject: Re: 83 diesel camper with bad engine - what would you do? |
| ?Waldo? wrote: |
| I know the engine is "bad" but if it is non op and tranny can't be tested, .... |
Ah, good points and pov. Well, hopefully it has a 5 speed and alaskadan will buy it and post pics!
(VW Gas I4)
VE7TBN |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3688 Location: Dartmouth, Mass.
