madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sat Mar 06, 2021 2:45 pm Post subject: Re: SSC Late Trans - Two Types |
Thought that big ass funnel looked familiar, that's my trans thanks for the reminder I have to rebuild that one for my bug _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Bruce Samba Member
Joined: May 16, 2003 Posts: 17294 Location: Left coast, Canada
Posted: Sat Mar 06, 2021 1:39 pm Post subject: Re: SSC Late Trans - Two Types |
QRP wrote: |
Does all this apply to type 3 as well??
I've got a SSC in my 73 squareback and have been wondering about it. |
No, A Type 3 never got the later zig-zag case because Type 3 production ended in 73, 2 years before the late case appeared in mid 75. _________________
pupjoint Samba Member
Posted: Mon Mar 01, 2021 11:23 pm Post subject: Re: SSC Late Trans - Two Types |
bugguy1967 wrote: |
Score! I had a 50% chance of getting a 3.88! Using it for road racing, so not overly concerned with shock loads.
i am very sure it has the 3.88. being in the US, i would send it to a transmission shop to get it gone thru and "upgraded" or maybe an ATB or LSD |
QRP Samba Member
Joined: April 27, 2008 Posts: 1713 Location: NORTH HOLLYWOOD,CA
Posted: Mon Mar 01, 2021 10:40 pm Post subject: Re: SSC Late Trans - Two Types |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Mon Mar 01, 2021 10:31 pm Post subject: Re: SSC Late Trans - Two Types |
_________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15313 Location: Deep in the 405
Posted: Mon Mar 01, 2021 4:52 pm Post subject: Re: SSC Late Trans - Two Types |
Here is the sticky that explains it. The 75 & later SSC cases are often called Z case. They are what you are asking about. There is nothing different inside then what was used in the earlier 73-74 SSC cases.
pupjoint wrote: |
yes there are 2 types and they both have the same ratios and 3.88, at least the ones i have seen 3.78, 2.06, 1.26, 0.93 |
Sorry but that is not true. You have to look at the code to see what you got
"AT" SSC Bugs were 3.88 with .93 4th gear.
"AN" SSC Ghia were 3.88 with .89 4th gear. These were the tallest gear ratio.
"AV" SSC Thing were 4.12 with .93 4th gear.
"DC" SSC Type III were 4.12 with .89 4th gear _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Mon Mar 01, 2021 2:03 pm Post subject: Re: SSC Late Trans - Two Types |
The "offset rib" trans represents the latest model box.
Same ratios as the regular SSC box (3.78/2.06/1.26/.82).
AT code for 3.88rp.
The one big difference is the use of the Aluminum "dual rib" side cover. It's way stronger than other Magnesium side covers.
While the offset rib box has better strength around the oil hole, and the "rib" is close to the opening, they can still be cracked like any box.
They are supposed to be stronger, but I have not really found that to be true.
Now, if you were to weld a gusset on the offset rib box, that would be very strong.
I blew one up in 10 passes on my 300hp drag car.
Went back to the normal SSC case and she held up for many years. |
Posted: Mon Mar 01, 2021 1:06 pm Post subject: Re: SSC Late Trans - Two Types |
Thanks! Been looking for that pic! _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2225 Location: HdG, MD & NJ
Posted: Mon Mar 01, 2021 12:17 pm Post subject: Re: SSC Late Trans - Two Types |
I’m sure either could be 3.88 or 4.12. The only true shortcut is to count the rotations in 2nd gear. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
b-man Samba Member
Posted: Mon Mar 01, 2021 12:04 pm Post subject: Re: SSC Late Trans - Two Types |
This one is supposed to be the strongest SSC case.
Internally likely the same as any other but I’m no expert.
_________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
Posted: Mon Mar 01, 2021 11:54 am Post subject: Re: SSC Late Trans - Two Types |
Posted: Mon Mar 01, 2021 11:40 am Post subject: SSC Late Trans - Two Types |
Asking a lot today.... I know.
I hear there's two single side cover transmission cases: one with a round boss around the drain plug, and one with a rectangular raised area around the drain plug, unlike any other trans. Can anyone confirm this? I haven't been able to find a pic. The rectangular one is supposed to be a sure-fire 3.88 r&p, with the best even gear spread (opinion). _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
