How do you mount your badges on the rear grille?
Stockholm VW
Stockholm VW is offline
PostPosted: Tue Mar 16, 2021 6:51 pm    Post subject: How do you mount your badges on the rear grille? Reply with quote
I want to mount my auto club badge on the rear grille, but I can’t figure how. Can you reach the backside of the grille somehow, or do you have a trick for how to get a bracket and mounting nuts behind there?
1966 Volkswagen 1300 Sedan (now 1641), 6 volt, L456 Ruby Red, Platinum leatherette.
anthracitedub
anthracitedub is offline
PostPosted: Wed Mar 17, 2021 8:45 am    Post subject: Re: How do you mount your badges on the rear grille? Reply with quote
Seems like your club would have some ideas. I’d probably use some earth magnets .
mukluk
mukluk is offline
PostPosted: Wed Mar 17, 2021 9:29 am    Post subject: Re: How do you mount your badges on the rear grille? Reply with quote
3M automotive double sided tape comes to mind.
Stockholm VW
PostPosted: Wed Mar 17, 2021 9:42 am    Post subject: Re: How do you mount your badges on the rear grille? Reply with quote
Thanks! Yeah, I was considering this, but wasn’t sure there would be enough surface area on the Beetle grille to mount it properly.
What’s the thinnest tape 3M makes? I’ve found the 1.1 mm, but it seems thicker than modern emblem applications.
mukluk
mukluk is offline
PostPosted: Wed Mar 17, 2021 9:51 am    Post subject: Re: How do you mount your badges on the rear grille? Reply with quote
Arrow 3M double sided tape link
