Abscate Samba Member
Joined: October 05, 2014 Posts: 22680 Location: NYC/Upstate/ROW
Posted: Mon Apr 12, 2021 7:37 am Post subject: 2002 T4 serp belt -dont be a dumba$$ (Like me) |
Proudly got out my serp belt tool and killed my tensioner bolt on my VR6 this morning. If i Had RTFM I would have found you detension by using a M8x 50 bolt, not the tensioner pulley bolt.
Ill drill and Helicoil a repair, but share for the Collective Knowledge. _________________ .ssS! |
Zeitgeist 13 Samba Member
Posted: Mon Apr 12, 2021 10:33 am Post subject: Re: 2002 T4 serp belt -dont be a dumba$$ (Like me) |
Bummer. VR6 is probably one of the easiest serp belt change procedures out there, especially if the belly pan is removed. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Wed Apr 14, 2021 3:42 am Post subject: Re: 2002 T4 serp belt -dont be a dumba$$ (Like me) |
Well, dumba$$ saved $300 by removing the tensioner, cleaning the left hand threaded bolt, chasing the threads with a left handed m8 tap he had, and reinstalling with loctite blue.
That tensioner is a thing of beauty
I added two marks, aligned is where the belt releases, and the second shows the tensioner with bolt removed. Only about 1 cm of deflection measured on case.
M8 x50 bolt for tensionrelease
50rocket88 Samba Member
Posted: Wed Apr 14, 2021 7:52 am Post subject: Re: 2002 T4 serp belt -dont be a dumba$$ (Like me) |
I have just removed one of the bolts that hold the tensioner to the block and used it to detension the pulley. Pretty handy! Not sure of the length, but it was long enough. |
Posted: Thu Apr 15, 2021 2:05 am Post subject: Re: 2002 T4 serp belt -dont be a dumba$$ (Like me) |
50rocket88 wrote: |
Ok, that’s brilliant...and now I don’t have to keep an m8 with my spare belt, either. It pays to expose your dumbassery to those smarter than you.
The manual calls for a 50mm length bolt, but the actual depth screwed on is about 1 cm, marked above _________________ .ssS! |
jimbomitch Samba Member
Posted: Thu Apr 15, 2021 6:47 am Post subject: Re: 2002 T4 serp belt -dont be a dumba$$ (Like me) |
That tensioner looks like it can be released with a 1/2" drive breaker bar as well. |
