Avi750 Samba Member
Posted: Mon Apr 12, 2021 10:07 pm Post subject: Engine build suggestion using transporter case |
Hi all,
I got an unknown transporter case with this num on it:
S112
004 101 102 A
6 ww0
the internal diameter for the cylinder in 100mm
so my plan is to rebuild this engine to have lot of horses and to install it in my 73' Ghia
I would appreciate your recommendation for build setup to have ~150HP +- and reliable engine (I'm not a drag racing but once a while I would like to burn up some rubber)
thanks a lot for your help
Avi |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7229 Location: Videbaek Denmark
Avi750 Samba Member
Posted: Tue Apr 13, 2021 11:55 am Post subject: Re: Engine build suggestion using transporter case |
Quote: |
2056 type 4
Good used W case.
Stock 71 mm crankshaft.
210 mm flywheel, lightened 1 kg.
Sachs HD pressure plate w. stock clutch disc.
Rotating assembly balanced.
AA H beam stock length rods.
Web 86b/86c camshaft on 104 LC. Installed straight up.
SLR reground type 4 lifters.
26 mm type 1 oil pump, modified to type 4.
Stock 94 mm cylinders bored out to 96 mm. Keith Black pistons.
Manton 3/8” push rods.
”S” cylinderheads, 42 x 36 mm valves, modified to my stage3 (Street) 10-1 CR.
HD rocker shafts with Porsche style adjusters.
009 distributor w. ignitor unit. Pertronix 3 ohm coil.
Dual 40 mm Dellorto carburettors with 35 mm venturies on CB manifolds.
4-2-1 header w. 1½/1 5/8/2 1/4” going into a 2½” muffler system.
CSP upright cooling system with a thermostatic controlled type 1 oil cooler in the stock type 1 position. 30 hp fan shroud with venturi ring.
Pull without belt. |
looks impressive, now I just need to collect these parts...
can you please estimate the cost of this combo (without the case)?
thanks for your help
Avi |
Posted: Tue Apr 13, 2021 12:50 pm Post subject: Re: Engine build suggestion using transporter case |
If you have only the case it adds up. Someting like € 5500-6000 with a cheap exhaust and Chinese 44 IDF and 6500-7000 if you want Dellorto´s and say a Python exhaust. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Avi750 Samba Member
Posted: Tue Apr 13, 2021 9:12 pm Post subject: Re: Engine build suggestion using transporter case |
understood,
so probably I'll look for something cheaper...
are you familiar with some other cheaper combo (~half this price) that will produce ~150HP?
thanks
Avi |
