dr8track Samba Member
Joined: July 18, 2005 Posts: 504 Location: Seattle area
Posted: Fri May 21, 2021 5:19 pm Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - SOLVED!!! |
Jrh5r wrote: |
Man, I am so glad to hear that! I had just rewired my bus fuse box per the wiring diagrams to the tee and triple checked it. When things were acting odd, I remembered my dads beetle and the bulb issue. You really have to use the exact bulbs specified or it’ll do odd things. I was already in the middle of tracing back wiring and trying to source a new signal switch. Pulled and jiggled the front bulbs and I had narrowed the issue down. Now I’ll never forget. Glad I could help you, because I was this close to saying screw it after this entire resto. Hopefully this thread will help others! If you make your way to Charleston, let me know. We will grab a beer. Cheers! |
Most definitely! And thanks again! It's great to have this community as such a great resource for all of us. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
Jrh5r Samba Member
Joined: January 08, 2021 Posts: 33 Location: East coast
Posted: Fri May 21, 2021 1:31 pm Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - SOLVED!!! |
Posted: Mon May 17, 2021 4:03 pm Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
Jrh5r wrote: |
I recently had a similar issue. Spent days trying to resolve it going through wires. Finally took off the turn signal lenses and removed one bulb at a time. The front turn signal bulb was shorting out between the two tabs, feeding power back through the harness. Try removing a bulb at a time and see if that resolves the issue. |
Mystery solved!! And the winning solution comes from Jrh5r! Using your advice I set out to pull one buld at a time and see if it eliminated the problem. Since I already had the lens off on the rear passenger side I decided to start with the backup light. Pulled it, tested everything.... SUCCESS! The very first try solved everything. Put a new bulb in the socket and everything is good to go.
You have no idea how close I came to rewiring everything. I had purchased nearly $90 in wiring to do the job. That's all going back. Thank you to everyone and thank you, thank you, thank you Jrh5r! If you're ever in the NW I owe you a few tall cool ones. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
Posted: Mon May 17, 2021 3:33 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
#30 should have power the whole time. If removing the wire from #30 stops the problem from happening then at least part of whatever is wrong might well be in the headlight switch. |
Posted: Mon May 17, 2021 12:50 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
Wildthings wrote: |
dr8track wrote: |
New discovery... even w/o running or key on, put it in R and the front parking lights come on along w the backup lights. With engine running and headlights on I have the same old problem.
I'm going to pull the battery out tomorrow and open up the back of the tail light housing and take a closer look. |
This indicates that something in the lighting circuit is getting power when it should not be. Does removing the plug from the headlight switch (have #1 and #2 fuses in place) fix eliminate the symptoms? |
Thanks for the ideas. I was trying to remove some "wires to nowhere " from PO's and noticed the headlight pull knob is very loose. I felt around behind it and was going to take it out and tighten it but I was afraid I wouldn't be able to blindly get it hooked back up.
How exactly is it supposed to be held in the dashboard? I couldn't feel any threaded ring on back to tighten.
So you are saying to pull the power to the switch and see what happens? Which do I pull?
Posted: Sun May 16, 2021 8:48 pm Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
dr8track wrote: |
Jrh5r Samba Member
Posted: Sun May 16, 2021 7:02 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22681 Location: NYC/Upstate/ROW
Posted: Sun May 16, 2021 4:00 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
telford dorr wrote: |
Check the condition of the harness in the starter area and engine bay. You've got a short between the right side tail light / side marker wire and the main black engine wire. This is usually caused by a temporary short on the (unfused) main black engine wire which melted its insulation enough to fuse it to the tail light wire.
Does the tail light light when the engine is running, perchance?
Has this bus ever had an engine fire, requiring harness repair? |
Telford has nailed this as usual. Short between tail And reverse light harness feeding coil.
Assume you have multiple faults, not just one. It will quickly become apparent you should rewire this whole section, not try to patch it _________________ .ssS! |
Posted: Sat May 15, 2021 8:32 pm Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
I did a little probing around the wire harness and couldn't see any obvious issues. I was curious if I might have temporarily resolved whatever was shorting out by just moving the bundlle around. Put fuse 2 back in and no such luck, but I did discoveer a couple more things.
Transmission not in reverse, engine started, headlights on, turns on reverse lights. Turn key off, engine goes off even with headlights on. So in any gear other than R it doesn't have the problem of continuing to run if the headlights are on.
I'm going to pull the battery out tomorrow and open up the back of the tail light housing and take a closer look. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sat May 15, 2021 5:18 pm Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
Has this bus ever had an engine fire, requiring harness repair? _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Sat May 15, 2021 3:27 pm Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
Pull fuses 1 and 2. See if one of them stop the problem. |
You nailed it! Pulling fuse #2 solves all problems. The backup lights are only on now when the bus is in reverse. The head lights no longer kill the engine after turning the key off.
2 controls:
License Plate Light - Confirmed not working with 2 pulled
Rear side marker R - " "
Tail Light R -
I think Bussdaddy may have called it. Maybe I have ground and power reversed to the R side marker? _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
Posted: Sat May 15, 2021 10:20 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
Pull fuses 1 and 2. See if one of them stop the problem. _________________ '71 panel, now with FI
Posted: Fri May 14, 2021 6:19 pm Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
busdaddy wrote: |
Weren't you having problems with your backup lights recently?, and confusion over what color wire a ground should be? Are you sure you don't have a marker light powering the coil via the backup light circuit? |
I believe you are referring when I replaced the gray plastic housings for the rear lights. And yes, it took quite a bit of advice to get them hooked back up and functioning. So yes, it's certainly possible I screwed up somewhere. But the tail light housings were changed in July of last year. Wouldn't it be odd for it to take this long for the problems to show up? _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51185 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon May 10, 2021 11:53 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
Weren't you having problems with your backup lights recently?, and confusion over what color wire a ground should be? Are you sure you don't have a marker light powering the coil via the backup light circuit? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon May 10, 2021 11:37 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
busdaddy wrote: |
Wildthings wrote: |
It is a great example of German afterthought engineering. |
Or thinking ahead and saving money, backup lights were optional in some markets, why add wires to every single unit if they were never going to be used?
Does the engine stay running with just the parking lights on too, or only when the switch is pulled out all the way? |
Yes, I just checked. The engine does stay on if you start it and turn on the pariing lights, then turn off the key. Then if you turn off the parking lights the engine stops.
Could it be that there is something in the ignition switch that is not happening that would cause the problem? Like mechanically whatever is suplposed to be happening isn't happening inside the ignition switch? _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
Posted: Mon May 10, 2021 8:35 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
Wildthings wrote: |
Does the engine stay running with just the parking lights on too, or only when the switch is pulled out all the way? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon May 10, 2021 4:05 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
The backup light fuse is an inline fuse that lays somewhere on the left side of the engine, it is in the middle of a black wire that attaches to the 12+ side of the coil. The other end of the black wire goes to the reverse light switch on the transmission. It is a great example of German afterthought engineering. |
Posted: Sun May 09, 2021 10:32 pm Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
Or a major harness short between the ignition circuit and the tail lamp circuit. Pull the appropriate fuses and see if any of them stop the engine issue |
I tried pulling some fuses associated with the problem to see if the results might provide some clues.
#12 Pulled this one first - I believe it controls the horn and brake lights. Turned on the key and started the bus. Turned on the headlights. Turned off the key and the bus remains running. Turn off the headlights and the engine stops. Only diffesrence is the horn doesn't make a kind of sickly beeeeeppp when the lights are turned off.
#3, 4, 5, 6 Pulled the low and high beam head light fuses. Problem still there.
I wanted to pull the fuse for the backup lights, but I can't find it. The manual says it's #11, but only in the autmatic transmission model. The manual indicated it's supposed to be in the engine compartment near the coil. The only fuse I could find was a fused power wire running between the electric fuel pump and the coil.
Can anyone steer me toward the backup light fuse and let me know if the problem persisting with the above fuses provides any answere? _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
Posted: Wed May 05, 2021 12:38 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
One likely scenario
Someone decided they wanted the ability to turn the headlights on with the key off. They thus wired to a terminal 15 wire to the headlight switch with out removing the terminal 30 wire to same. Have a look at your headlight switch fir extra wires that don’t look stock. _________________ .ssS! |
Posted: Wed May 05, 2021 12:30 am Post subject: Re: 74 Westfalia Electrical Gremlin Nightmare - Help! |
Abscate wrote: |
Your headlights are backfeeding 12 volts to the coil
Get the wiring diagram , tear out what is in there, and rewire to the diagram
That will take 1/3 the time of trying to sort out someone else’s diarrhea |
That's what my friend recommended. He knows electrical and I 'm pretty clueless, so he's going to help me out. I'm still baffled what caused it. It was all working so well. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
