BlackDogVan Samba Member
Joined: December 21, 2007 Posts: 855 Location: Vancouver Island
Posted: Thu Mar 03, 2011 11:27 am Post subject: 5 cylinder TDI blahblahbl... wait a second... audi trans?!!! |
Flipped Audi trans with the bellhousing rewelded, hard to even see the joint.
So this is a audi bolt pattern but whats to stop this from working with a 1.8T or TDI convert with a Passat longitudal mount 5speed trans?
Is the starter direction a game killer? Axle flanges? _________________ Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Still addicted, looking for Doka...
insyncro Banned
Posted: Thu Mar 03, 2011 11:48 am Post subject: |
Very interesting. |
Posted: Thu Mar 03, 2011 11:54 am Post subject: |
I actually considered doing exactly that with my 1.8T project, but I didn't like how high it raised the inner CV joints in comparison to the outers. Probably not an issue on a lowered, or maybe even stock, height van, but on a higher van, I think that the CV angle would be less than ideal. Cool to see it done though. Where did you find that? _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
svxcarat Samba Member
Joined: May 19, 2009 Posts: 127 Location: San Francisco
very cool |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18745 Location: Retired South Florida
Posted: Thu Mar 03, 2011 12:04 pm Post subject: |
What Audi is that transmission from? I wonder how well the shift rod seal will hold up. In a stock configuration, the shift lever would be above the level of the hypoid. I can not see the welds, but it would require a very skilled person to do with a fixture that could hold it centered. You would have to fight warping and it would need to be precisely centered to work. Otherwise impressive. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10495 Location: Sunshine Coast B.C.
Posted: Thu Mar 03, 2011 12:14 pm Post subject: Re: 5 cylinder TDI blahblahbl... wait a second... audi trans |
BlackDogVan wrote: |
Is the starter direction a game killer? Axle flanges? |
Re: "game killers". Upright engine? Possible clearance loss due to exhaust routing?
I"ll probably figure it out right after hitting "submit" but how does starter direction affect things? Doesn't that TDI spin CCW? Which engine is it? 2.5?
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
Posted: Thu Mar 03, 2011 12:22 pm Post subject: |
@ Chris - http://www.brick-yard.co.uk/forum/charge-cooler-and-new-gearbox_topic62757.html
Good point about the CV angles.
@ Vanagon nut - I meant the physical starter location. Ours hang over the trans, that audi has it beside the engine block & i'm not sure with the longitudial passat installs.
I'm guessing whomever welded the exhaust didn't to the bellhousing  _________________ Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Still addicted, looking for Doka... |
Posted: Thu Mar 03, 2011 12:27 pm Post subject: |
Audi's used an engine side starter, opposite of the Vanagon. I can just make out the starter I think in the one picture. I think fitting the starter with the turbo would be tight, but it must fit. As long as an "engine side" starter and matching flywheel are used, it should fine. The engine will always turn in the same direction regardless of the transmission. |
Posted: Thu Mar 03, 2011 12:28 pm Post subject: |
@ Vanagon nut - I meant the physical starter location. Ours hang over the trans, that audi has it beside the engine block & i'm not sure with the longitudial passat installs. |
Right. I just saw it and was composing a reply. Thanks!
So starter positioned as per pic would require longer wires from battery and alternator etc. What other possible issues would result from starter being positioned there?
(VW Gas I4)
VE7TBN |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15351 Location: Syracuse, NY
Posted: Thu Mar 03, 2011 12:45 pm Post subject: |
I can't say I'm favoring the exhaust or engine carrier welding
and I'd like a better image of where the Alum bellhousing was welded..
the Audi CVs were larger than the stock vanagon so it wouldn't be too tough to adapt to a Porsche 930 CV to handle the angles..
this is only for a 2wd modification,
I would be concerned with how the internals woud get oiled and how long it'll last..
the starter is in a "stock" locaiton it doesn't even know the trans was rotated
I have a Formula Vee engine adapter for an inline 4cyl that's made to be on a flipped beetle trans.. not that that adds anything to this conversation though.. _________________
Abscate wrote: |
r39o Samba Polizei
Posted: Thu Mar 03, 2011 1:05 pm Post subject: |
danfromsyr wrote: |
I would be concerned with how the internals woud get oiled and how long it'll last.. |
*VERY* concerned.....x2 _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Thu Mar 03, 2011 1:14 pm Post subject: |
It's an Audi 012/01A gearbox.
I'll be interested to know if anything has been done about the oiling inside the gearbox.
If not, the diff bearings won't be getting any oil and will run dry and die very quickly.
Nice idea but it looks a bit half thought out. Fingers crossed that the input shaft has been lined up carefully before the bellhousing was welded back on too.
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD
Posted: Thu Mar 03, 2011 1:22 pm Post subject: |
danfromsyr wrote: |
x2, though I consider myself a hack at that stuff.
And the size of tube used for carrier may be too small.
(VW Gas I4)
VE7TBN |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2986 Location: Issaquah, WA
Posted: Thu Mar 03, 2011 1:23 pm Post subject: |
I think the internal oiling would be fine, but I agree with Mark's concern about the shifter seal. That's a fairly light duty seal and I don't think it's really designed to have the oil capacity against the back of it.
I'm guessing that is a 2wd version of the 01E transmission that Audi used on their higher output cars starting in 1990. There is the 01A which is for lower powered cars and then the 01E which was used on the URS4 etc. The Porsche 968 used a version of this transmission on our side of the pond.
Interesting idea, and pretty cleanly done. I'm impressed with the installation.
David
Sir Sam Samba Member
Joined: July 19, 2009 Posts: 1724 Location: Fort Collins Colorado!
Posted: Thu Mar 03, 2011 2:30 pm Post subject: |
I'm also wondering about oiling, unless the tranny was filled completely to the top I would be worried about how it would oil everything.
Seal the "top" side of the tranny and add a breather/reservoir somewhere and fill it to the top........ _________________ '91 Carat Westy
87' Syncro + '87 Westy conversion coming soon |
Posted: Thu Mar 03, 2011 2:34 pm Post subject: |
All this does is re-awaken my north american Eurovan AAB IDI to 5cylinder mTDI dream. Identical in theory to my AAZ-mtdi. Just need the head & a few other bits from the UK. _________________ Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12167 Location: Port Manteau
Posted: Thu Mar 03, 2011 2:40 pm Post subject: |
All this does is re-awaken my north american Eurovan AAB IDI to 5cylinder mTDI dream. Identical in theory to my AAZ-mtdi. Just need the head & a few other bits from the UK. |
Does the AAB have piston squirters built into the block? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Thu Mar 03, 2011 2:48 pm Post subject: |
Zeitgeist 13 wrote: |
Does the AAB have piston squirters built into the block? |
Yes.
Some AAB porn...http://www.vwdiesel.net/forum/index.php?topic=25252.0 _________________ Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Posted: Thu Mar 03, 2011 4:14 pm Post subject: |
The lemur likee ^ _________________ Casey--
y u rune klassik? |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2625 Location: Southeast Kentucky
Posted: Thu Mar 03, 2011 8:02 pm Post subject: Mounting tube |
The engine mounting tube looks like one I saw for sale here in the Samba with a package deal...........Quantum 5-cylinder diesel, South Africa Bell housing, mounting bars, etc..... looked very similar if not the same!
Years ago, my uncle and his brother-in-law fabricated an engine adapter to mate a 4-in-line Rabbit engine to a '69 beetle tranny for his rail buggy...... it was a rough looking adapter. However, it worked well! I do not recall how they centered it! _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
