matter396 Samba Member
Joined: February 19, 2009 Posts: 4 Location: Houston, Tx
Posted: Sun Jun 01, 2025 2:16 pm Post subject: 3 rib bus throwout bearing sleeve |
Hey fellas I have a 3 rib bus tranny that has the three bolt throw out bearing sleeve. My tranny did not come with bolts or studs and I am in need of them,, can’t find a bolt to fit or studs anywhere, help!!!!??? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52822 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jun 01, 2025 2:30 pm Post subject: Re: 3 rib bus throwout bearing sleeve |
It should be a common M6 stud, 20-25mm long, Ace hardware perhaps? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4099 Location: Seattle, WA
Posted: Sun Jun 01, 2025 2:35 pm Post subject: Re: 3 rib bus throwout bearing sleeve |
I think the threaded holes in the trans are M7. If you are in an isolated area with no vendors of M7 studs/bolts, you can get them online at, for instance, https://belmetric.com/ _________________ '67 bug: seized by the authorities
Posted: Sun Jun 01, 2025 2:49 pm Post subject: Re: 3 rib bus throwout bearing sleeve |
Now that you mention it M7 does ring a bell, please disregard my previous advice. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jun 01, 2025 3:44 pm Post subject: Re: 3 rib bus throwout bearing sleeve |
7mm was right. Auto parts only not at ACE. O’Reillys saves the day. Thank you all!!! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42609 Location: at the beach
Posted: Sun Jun 01, 2025 5:31 pm Post subject: Re: 3 rib bus throwout bearing sleeve |
if we are talking the steel sleeve the TO slides on, the fiche gives the stud as 7mm x 32mm. It does not give the pitch.
Part N 014 449 2 up to 213 2 194 781
washer 7N 012 134 2
lock nut N 011 007
After 1973 they used a 7mm bolt x 15 mm long
Part N 040 203 3
Weddle has them https://weddleindustries.com/products/H-BM7X15H/H-BM7X15H M7 x 1.0 x 15mm
says use with specific lockwasher # H-WM7-STL
https://weddleindustries.com/products/H-WM7-STL/H-WM7-STL _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
