sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
vw356 Samba Member
Joined: January 09, 2004 Posts: 209 Location: Cullman,Alabama
Posted: Sun Dec 31, 2023 10:42 am Post subject: Re: Nova Scotian 54 standard restoration |
Looking great! I see why you do not want to buy parts.. Yours are better!
Looking forward to your next video too!
Thank You for sharing!
Happy New Year! _________________ Current projects:
1950's Volkswagens!
51,52,54's,55,56's,57,58's,'60's And then a bunch of '60's, but the '50's are my favorites.. |
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1136 Location: Austria
Posted: Thu Jan 04, 2024 6:21 pm Post subject: Re: Nova Scotian 54 standard restoration |
Got an unloved 54 tank.
The owner decided to get a better tank and sold this one to me for a reasonable price. Good tanks are too pricey for me. Haha
Mine was so bad I figured it would be easier to build one from scratch. This one will be an easy fix. All rust is from the outside. Top has some deep pitting that will need replacing. Small hole in the filler and a section on the end will need replacing. After repair it will get a liquid liner that will take care of the flange seam where I need to replace some metal.
_________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
Posted: Thu Jan 04, 2024 7:09 pm Post subject: Re: Nova Scotian 54 standard restoration |
Another part done.
My beam had swelled in the seams and had many holes so easier to build new. I saved the master cylinder bracket, accelerator bracket and spring tab, park brake washers and hook. Remainder is new.
Welds are actually better than the originals. With higher heat and wire feed you can make strong welds that look like shitty stick welding. I assume they used coat hangers and car batteries to weld these things together. I am amazed at how bad some of the welds were on this bus.
Edit: I just realized I welded the master cylinder bracket on backwards. I felt something was off... Annoying but easy fix.
FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Thu Jan 11, 2024 10:48 am Post subject: Re: Nova Scotian 54 standard restoration |
awesome work. Thanks for keeping the thread updated. To see progress like this helps keep me (and others Im sure) motivated to work on my own turd projects. _________________ Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller |
kadeef 1 Samba Member
Joined: December 03, 2021 Posts: 4 Location: The samba
Posted: Thu Jan 11, 2024 1:53 pm Post subject: Re: Nova Scotian 54 standard restoration |
Perfect work, there is a lot of important information and experience in your work for my renovation, I love your topic. Ivan |
Posted: Sun Jan 21, 2024 4:02 pm Post subject: Re: Nova Scotian 54 standard restoration |
Started the under seat panel.
Tried the bead roller but was a lot of work. I stretched the metal first with an english wheel then through the bead roller with 3D printed dies. Thinner steel would be much easier.
I decided to make a die and press them in. Will save time and look better. I was going to press in the terminations anyway. Need to pickup some 3/16" steel for the die.
Started on the splash panel. Needed a bit more hammer and dolly work. Also cut out a couple rusty bits
jborregoy2k Samba Member
Joined: October 16, 2016 Posts: 32 Location: El Carmen de Viboral, Colombia
Posted: Mon Jan 29, 2024 2:24 am Post subject: Re: Nova Scotian 54 standard restoration |
Thanks for documenting this project. Feel inspired by your work. I’m almost in the same part you are doing right now, so eagerly waiting for your youtube episode.
Cheers from El Carmen de Viboral, Colombia (South America)
Posted: Mon Jan 29, 2024 5:38 am Post subject: Re: Nova Scotian 54 standard restoration |
Huetti_1989 wrote: |
Nice work man!!
do you ever thinked about buying a power hammer for a work like this?
The Pullmax is a dream from me, but expensive, heavy and big...
-Christian |
Thanks
Would love to have a Pullmax but too expensive for me. I am thinking of building a cheep power hammer with an air chisel though. It would do shaping and planishing.
For this part pressing was easier anyway but for the rear floor panels a power hammer with sliding guide would be nice to get the ribs perfect. _________________ My 64 Kombi restoration
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24166 Location: Southeast USA
Posted: Mon Jan 29, 2024 4:21 pm Post subject: Re: Nova Scotian 54 standard restoration |
Next thing you'll be building a Kubelwagen from scratch. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
conrad1468 Samba Member
Joined: December 20, 2003 Posts: 1019 Location: Jeannette, PA 15644
sebgi1 Samba Member
Joined: September 19, 2005 Posts: 169 Location: Quebec, Canada
Posted: Tue Jan 30, 2024 3:42 pm Post subject: Re: Nova Scotian 54 standard restoration |
Amazing work!!
Power hammer for cheap…
https://youtu.be/pN4lP-bvNqk?si=SRQQlUjakgI-JGCi _________________ SEB
Dogs are the most precious and valuable possession of mankind. VWs are second!
'73 Neptune blue safare camper
'71 Neptune blue tintop |
Posted: Wed Jan 31, 2024 2:21 pm Post subject: Re: Nova Scotian 54 standard restoration |
As always, amazing metalwork. Ivan |
