Posted: Thu Sep 09, 2021 5:02 pm Post subject: T3 Technique Ball Joints - Not created equal |
This thread is sort of a continuation of this thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=276274
But since these new T3 joints are actually coming to fruition, I figured it would be best to start a new thread. And just to keep things congruent, here's the info that was posted deep in that other thread about the new joints (originally posted April 28, 2021):
T3 Technique has taken on the HUGE (and expensive) challenge of having bespoke upper and lower ball joints made. The sample/prototypes of the new UBJs are excellent and are headed to production as we speak. The new lower ball joints needed a little refinement to get them up to my standards, but I think we are really close to pulling the trigger on those too. It will be a few months before we see tangible stock, but they are coming. Once I have some stock, I'd be happy to cut a sample apart to show you all the differences.
And, as some of you may have already read about, there will be a new tall version of the UBJs to help correct the geometry of a lifted van and help proved more UCA to spring clearance. In my lifted 2wd, these tall ball joints absolutely transformed the drivability, ride quality, stability, etc. It's like a completely different van. Below is a photo to show the difference between a stock length UBJ and the tall UBJ.
Today I received news that the new upper ball joints will be here right around the end of September, possibly early October. Pretty excited about that. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
T3Technique.com or contact me at [email protected]
Last edited by Christopher Schimke on Thu Sep 09, 2021 5:03 pm; edited 1 time in total |
Posted: Thu Sep 09, 2021 5:03 pm Post subject: Re: T3 Ball Joints - Not created equal |
I also received my sample/prototype lower ball joints and I'm REALLY stoked on these. I worked really hard with the engineers to get exactly what I wanted out of the new joints. I cut one of our new joints apart, along side a brand new low quality Vanagon ball joint currently on the market, to show what makes these new joints so special and what makes all other Vanagon lower ball joints on the market today so inferior and prone to failing in short order. The low quality joint that I cut apart is indicative of all Vanagon lower ball joints in the market today. Yes, I have cut apart all of the currently available joints on the market to prove it. There are some variations of the plastic design, but none of them have the proper support to prevent the joints from failing prematurely.
First, a shot of the new joints untouched (sorry for the crummy, raw photos). You can see they come with the correct wire circlips that actually fit properly and if you have a keen eye (and experience with low quality Vanagon lower ball joints), you can see the solid metal insert.
Now for the guts of the matter. First, look at how much grease is in the new joint compared to the low quality ball joint. I did not add or remove any grease for either joint. This is exactly how they looked when the boot was removed.
New T3 joint:
Low quality joint:
And below is the crux of it all...the reason I went down this ball joint road to begin with. The new T3 joint is on the left, the low quality, joint is on the right.
1) On the new T3 joint, see above the ball how there is a thin plastic liner backed up with a solid metal insert that is crimped to the joint body? That's the key! Now look at the low quality joint. See how there is a big gap between the plastic liner and the stamped upper cap/insert? The reason these low quality joints fail is because the load path is directed toward that plastic part and the cap/insert. The constant pounding the tire hitting bumps drives the ball toward that area. With no support in the low quality joint, the ball becomes loose prematurely leading to failure.
Because the new T3 joint has a plastic liner with full support, this will not happen.
2) The other key feature of the new T3 joint, and a problematic issue with the low quality joint, is articulation. Look at the open area under the boot where most of the grease goes. Notice that angle of the walls and opening size of the new T3 joint is greater than that of the low quality joint. Many of the low quality joints actually restrict suspension articulation by restricting joint movement. The new T3 lower ball joints allow full articulation.
Anyway, that's the latest on the new T3 ball joints. I'm pretty excited about this and wanted to share. The lower ball joints are still in the testing phase, but I'm hoping to have them to market sometime in the Spring of 2022. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4922 Location: Bemidji, MN
Posted: Thu Sep 09, 2021 5:17 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
holy cow, what an undertaking!! and thank you for filling a real need. kinda makes me want to saw my stamped bottom TRW joints for a lookee. have one cast bottom.
anyway, thank you for serving our community so well. amazing. Belly Up, folks. we've whined for years about cheap parts that don't last. these will come at a price that is in line with their quality. do it right, once. _________________ -dan
www.thefixitworkshop.com |
bobhill8 Samba Member
Posted: Thu Sep 09, 2021 5:27 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
Thank you Chris - looking forward to smoothing out my ride with both of these. _________________ 1986 Westy
1971 Squareback |
chrismsnt Samba Member
Joined: March 06, 2018 Posts: 248 Location: Cumming, GA
Posted: Thu Sep 09, 2021 6:46 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
Christopher Schimke wrote: |
Today I received news that the new upper ball joints will be here right around the end of September, possibly early October. Pretty excited about that. |
If you need to test it on a higher van, just let me know! I'm a high flyer! Since I'm already in line for your 25mm sway bar kit.. I can just hit all the work at once! _________________ Chris
1989 T3 Vanagon 16" Syncro
1967 Squareback
https://vwvandiesel.com
Instagram @VW_VanDiesel |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12127 Location: Port Manteau
Posted: Thu Sep 09, 2021 7:11 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
Christopher, you're an amazing asset to the community. Thanks! _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Thu Sep 09, 2021 7:22 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
Yes please |
Posted: Thu Sep 09, 2021 7:24 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
What ride height is considered lifted? Im right at 19.25” on my syncro |
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Thu Sep 09, 2021 9:01 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
I’ll echo everyone’s appreciation and thanks.
Now that the pleasantries are out of the way.
How do I buy a set for my high top?
Take
My
Money
Owen _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Thu Sep 09, 2021 9:23 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
Too good to be true! |
hans j Samba Member
Joined: May 06, 2006 Posts: 2723 Location: Salt Lake City UT
Posted: Thu Sep 09, 2021 9:25 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
Glad I've been waiting years to replace my bad lower joints!
On those uppers, is the joint in a different location than the stock version? I'm wondering if the SAI or roll center is the same. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181
?Waldo? Samba Member
Posted: Thu Sep 09, 2021 9:30 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
Thanks for your efforts Chris! |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1880 Location: Vancouver Island, BC
Posted: Thu Sep 09, 2021 10:02 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
Impressive work! Can't wait for my current ball joints to fail. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Joined: January 01, 2007 Posts: 16957 Location: sticksville, ct.
Posted: Thu Sep 09, 2021 11:55 pm Post subject: Re: T3 Technique Ball Joints - Not created equal |
i'm in for a set as well
question, are you going to make the lowers greaseable? i may have missed it but wanted to ask _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
turbotype1 Samba Member
Posted: Fri Sep 10, 2021 6:17 am Post subject: Re: T3 Technique Ball Joints - Not created equal |
skills@eurocarsplus wrote: |
question, are you going to make the lowers greaseable? |
This^^^^^. _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
DigiMatrix Samba Member
Joined: April 20, 2010 Posts: 457 Location: Up North Canada
Posted: Fri Sep 10, 2021 6:44 am Post subject: Re: T3 Technique Ball Joints - Not created equal |
Chris, thank you for being a top supplier for us! Let us know if/when we can pre purchase these please. I want on the list. _________________ _________________
'91 Syncro Westfalia
soon to be 2.5 liter stroker WBX 10:1 comp
Digifant ECU with knock sensor and custom
cylinder selective knock control by me |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6438 Location: Honolulu,Hawaii and France
Posted: Fri Sep 10, 2021 7:02 am Post subject: Re: T3 Technique Ball Joints - Not created equal |
I'm down!!! I'll definitely buy a few sets when I'm back. This is great timing with the junk we're plagued with nowadays.
Sh!t, I would have loved testing a set of these on my Syncro, I'm currently in Central America, and everything is taking its toll even on brand new everything. All I do is off-road pretty much.
Chris, hit me up if you want me to put the lowers to the test in Baja, I can get them in La Paz and swap them there on my way back up from Central America.
I'm exactly at 6107 Lbs ,2770Kgs) fully loaded right now, stock height, it was 510mm but it's back down to 480mm now from spring sag, weight and all. Still plenty droop and suspension motion.
98mm 16" Syncro front outer cv's , 108x32 mm Audi front inner cv's and 108x40mm 930 cv's everywhere else.
Aloha! _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
dobryan Samba Member
Joined: March 24, 2006 Posts: 16567 Location: Brookeville, MD
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Fri Sep 10, 2021 8:07 am Post subject: Re: T3 Technique Ball Joints - Not created equal |
Beautifully done, Chris, as always!!
I knew there was a reason that I've been putting off replacing the lower ball joints for seventeen years... _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Posted: Fri Sep 10, 2021 9:22 am Post subject: Re: T3 Technique Ball Joints - Not created equal |
From https://wagenswest.com/how_to/how_to_images/bus_vanagon_balljoints/IMG_6155.JPG
I understand that the Lemfoerder balljoints were becoming hard to obtain. Given your willingness to support the Vanagon community and exemplary customer service I would buy them from you if I had not obtained a set of moog a year or so ago for my suspension overhaul. Do you have any differences with the Lemfoerder/Moog joints?
