robertsfd2002 Samba Member
Posted: Mon Sep 20, 2021 6:13 am Post subject: Re: Oil leaking from inside tire area and tire angle |
I got it. Thank you everyone. Very helpful for a slow guy like me. |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Mon Sep 20, 2021 5:06 am Post subject: Re: Oil leaking from inside tire area and tire angle |
as the others said, that's an early gasket you have. BTW a 1984 mexican bug's engine for the internal mexican market in its original spec has no fuel injection nor hydraulic lifters, and it is in most respects similar or the same as a late (pre-FI) german 1600. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3855 Location: San Jose, CA
Posted: Sun Sep 19, 2021 8:02 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
No, no, we're saying you got 36 HP gaskets, you want the later 40-horse thru 1600 gaskets. Yes, order some for a 1969. (Or 70, or 71, or 65, or 62...you get the picture ) |
Posted: Sun Sep 19, 2021 7:59 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
How do I determine what I need? JBugs has these:
valve cover gaskets are used on 1200cc 40 Horse through 1600cc Type 1, 2 & 3 engines as well as Vanagon watercooled 1.9 & 2.1 Liter engines. The valve cover gaskets fit 1961 through 1977 Beetles
OR
valve cover gaskets are used on 25 and 36 Horse engines. The valve cover gaskets fits 1954 through 1960 Beetles
I was told the 84 Mexican bug was essentially the same as the 1969 bug, which would suggest the first item description, but then you're suggesting it is a 36hp so this suggest the second item description.
Any idea which I should try? |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sat Sep 18, 2021 6:10 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
36 hp gasket...probably just sent you the wrong ones |
Posted: Sat Sep 18, 2021 3:23 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
Here is the valve box:
Posted: Sat Sep 18, 2021 2:40 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
robertsfd2002 wrote: |
Here's a picture of the cover with the gasket I bought. At the widest point, the cover is 9 and 7/8 inches.
Thanks for the other thoughts/tips/links.
That looks like a super early gasket, like 25 hp, or 36 hp. Is there any chance you clicked and ordered the wrong ones? The lower corner radii are too tight on that gasket to boot. You need good ol' 1600 gaskets.
(Yes, I know I said all the gaskets were the same earlier...but 36hp?) |
AutoMechanic Samba Member
Joined: December 28, 2019 Posts: 483 Location: Roanoke Virginia
Posted: Sat Sep 18, 2021 1:24 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
Gear and hub oil smells like onions it’s gross lol. Worst stuff ever to try to get the smell off your hands so don’t get it on your hands. |
vamram Samba Member
Posted: Sat Sep 18, 2021 1:01 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
Can you post a picture of the head that belongs to that valve cover? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Sat Sep 18, 2021 11:40 am Post subject: Re: Oil leaking from inside tire area and tire angle |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31389 Location: Hot Arizona
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9776 Location: Oregon
Posted: Sat Sep 18, 2021 7:26 am Post subject: Re: Oil leaking from inside tire area and tire angle |
Robert,
Have you read through this thread on Mexi Beetles?
https://www.thesamba.com/vw/forum/viewtopic.php?t=583972
Also, Hopkin seems to be the resident expert on these cars.
Antonio Trejo sells part for Mexi Beetles too. He may be able to lend a little knowledge to ya.
https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=14183
Regarding the valve cover gasket. I am under the impression that they are not any different than a standard 1600cc engine valve cover. I could be wrong in this thought.
Any mainline auto parts store, should be able to order a gasket set for your engine.
Don't the Mexi Beetle engines, have hydraulic lifters? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sat Sep 18, 2021 7:25 am Post subject: Re: Oil leaking from inside tire area and tire angle |
Cusser wrote: |
Sorry - most of us here lack experience with 1984 Mexican Beetles; are fuel injection valve covers different size? |
I pondered the same question last night and researched as much unspecific garbage the web could offer, and near as I can figure, they have basic ol' type 1 heads. Which makes the OP's VC gasket situation all the more puzzling.
OP: the reason vendors don't list valve cover gasket sizes is that, there IS only one size. So without seeing pictures of your exact situation, and perhaps measurements, it's hard to say what's going on. I've only ever used good ol' cork gaskets, and in 38 years of messing with these cars, never got a gasket that was so undersize. And just so we're on the same page, "about an inch" is about four yellow #2 pencils laid side by side
Pics please.
By the way, your gear oil looks maple syrup colored, so it looks plenty clean, I wouldn't change it out...but you should check the level and top it off after replacing axle seals.
Cusser Samba Member
Posted: Sat Sep 18, 2021 7:06 am Post subject: Re: Oil leaking from inside tire area and tire angle |
Doing a valve adjustment and find the valve cover gasket ordered from JBugs that was supposed to fit is too small (about an inch too short sideways). No local stores I know of in my small town carry anything that will fit. Unfortunately I peeled out the old gasket before checking the new would fit so no reusing it.
Is there are way to know the gasket you order online will fit? I can't find anywhere that gives any kind of dimensions. Am I left ordering from somewhere else just hoping it will fit and repeating that until I luck out?
Sorry - most of us here lack experience with 1984 Mexican Beetles; are fuel injection valve covers different size? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri Sep 17, 2021 7:35 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
This may be a stupid question, but when I fix the gear oil leak, should I go ahead and drain and replace the oil?
Follow-up question unrelated to the gear oil leak but now an issue in getting the car back on its feet.
Thanks. |
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 824 Location: Downriver, MI
Posted: Thu Sep 16, 2021 4:17 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
Anyone know where I can find some 8-day weeks (or even better, 9-day weeks)? |
I get it, not enough hours in a day.
24hrs per day is the great equalizer amongst us all....... _________________ '69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200 |
Posted: Wed Sep 15, 2021 8:05 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
Original Poster: you can also mull some of these threads, there are many good tips and comments from others who have been down this road many times. The early brake drums are slightly different so don't be distracted if you see parts mentioned (like "oil slinger") that aren't on your car. The threads with the most replies often have more pics and more discussion. It makes good bedtime reading.
https://www.thesamba.com/vw/forum/search.php?searc...=titleonly |
Got it volksworld. |
Posted: Wed Sep 15, 2021 6:17 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
just try not to follow his advice on removing and reinstalling big nuts with a hammer and chisel...stuck on the side of the road desperation tactics only |
Posted: Tue Sep 14, 2021 5:30 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
Thanks for the extra tips.
I've got the John Muir book so I'll see if that's enough. And that tool looks like a good gift for my son. |
