'69 T2 tranny
dogmeat
dogmeat is offline
PostPosted: Fri Sep 24, 2021 8:09 pm    Post subject: '69 T2 tranny Reply with quote
Hi all. I'm new to VW and recently acquired a T2 needing love. I'm building an engine that I'm pretty sure will be 1641 with new cylinders and DP heads. Prolly a mild cam as well. So.... reading around I'm seeing that there are transmission options. This is not something I had considered when I started but now I have to ask.... First, is this something to pursue? Whats the best if you have $$$$, and what kind of money? Then, whats the most reliable?
TomWesty
TomWesty is offline
PostPosted: Fri Sep 24, 2021 9:10 pm    Post subject: Re: '69 T2 tranny Reply with quote
With that engine, stick with a stock geared transmission. The engineers got it right on that one. Don’t go with a taller fourth gear until you get north of around 2000cc. And then probably closer to sea level. I’m sure most on the forum will agree.
dogmeat
dogmeat is offline
PostPosted: Fri Sep 24, 2021 9:43 pm    Post subject: Re: '69 T2 tranny Reply with quote
thanks... that is my first inclination but there is so much stuff out there....
richparker
richparker is offline
PostPosted: Fri Sep 24, 2021 10:06 pm    Post subject: Re: '69 T2 tranny Reply with quote
Stay stock and if you want taller gearing you don’t just change 4th, you change the ring and pinion.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
Wildthings
Wildthings is offline
PostPosted: Fri Sep 24, 2021 10:52 pm    Post subject: Re: '69 T2 tranny Reply with quote
I you want longer gearing, go with 27x8.5R14 or 195r14 tires and see how you like it, easy to change back to stock if you lose too much tractive effort.
