Pop-Top Protection
wpicotte
wpicotte is offline
PostPosted: Tue Oct 12, 2021 10:41 am    Post subject: Pop-Top Protection Reply with quote
I frequently carry a kayak on my roof rack, and have created wear spots in the fiberglass at the rear of the pop top from loading / unload. The wear spots are right on the rounded corner where the panel curves down to the rear edge.
I'm trying to come up with a protective solution. I've considered things like ClearBra or the 3M sheets, but the repeated wear of the kayak (especially with a little sand on the hull) will go right through that.
I've also considered epoxying a flexible, teflon type material (like the thin cutting boards) to that bend. I don't know if that would hold up any better.
Any ideas / thoughts / similar solutions would be greatly appreciated. Thanks
danfromsyr
danfromsyr is offline
PostPosted: Tue Oct 12, 2021 10:52 am    Post subject: Re: Pop-Top Protection Reply with quote
figure out how to get a rear load bar back there.
maybe some load assist rollers too.
but a cross pipe with some jute rope will last a long time and remove all wear from the top..
Abscate wrote:
wpicotte
wpicotte is offline
PostPosted: Tue Oct 12, 2021 11:03 am    Post subject: Re: Pop-Top Protection Reply with quote
I could mount another crossbar, but not a top preference, as I have three installed already.
space
space is offline
PostPosted: Tue Oct 12, 2021 11:05 am    Post subject: Re: Pop-Top Protection Reply with quote
Ive been looking for something myself
My Kayaks are 70lbs per
Let me know what u find
T
82 westy
w:
2.5 JDM Subie
Rear discs
dschaftlein
dschaftlein is offline
PostPosted: Tue Oct 12, 2021 12:11 pm    Post subject: Re: Pop-Top Protection Reply with quote
I use the Yakima boat loader for my canoe and kayaks. Works great, Much simpler to load a canoe with one person than two!
https://yakima.com/products/boatloader
wpicotte
wpicotte is offline
PostPosted: Tue Oct 12, 2021 12:17 pm    Post subject: Re: Pop-Top Protection Reply with quote
Ah that's interesting. You have one installed in each crossbar? Do you first set the boat on the boat loaders entirely (i.e. they support the boat's weight) and into the saddles or whatever you're using?
PDXWesty
PDXWesty is offline
PostPosted: Tue Oct 12, 2021 12:33 pm    Post subject: Re: Pop-Top Protection Reply with quote
I used Yakima rollers on my rear bar to load kayaks. Kept it off the roof.
Maybe there's a temporary solution? Lots of products like this on line.
https://www.outdoorplay.com/racks/kayak-racks/rollers
89 Westy 2.1 Auto
fishgo
fishgo is offline
PostPosted: Tue Oct 12, 2021 12:50 pm    Post subject: Re: Pop-Top Protection Reply with quote
I use that too, but just on the front crossbar. Put the bow up there, swing the rear of the kayak up on the crossbars, wiggle into place, and strap down. Put a safety strap (very short) right to a tie-down strap on the luggage rack. Easy.
wpicotte
wpicotte is offline
PostPosted: Tue Oct 12, 2021 12:53 pm    Post subject: Re: Pop-Top Protection Reply with quote
Yep - read a couple reviews from people who recognized the need for only one of these after the fact, mounting a boat exactly as you have described. Mine arrives Friday. Thanks for the idea.
djkeev
djkeev is offline
PostPosted: Tue Oct 12, 2021 3:26 pm    Post subject: Re: Pop-Top Protection Reply with quote
Your rear bar needs to be farther back.
I have the same problem with ladders on my Tintop with my rack.
Dave
Ghia
Vanagon
Beetle
SCM
SCM is offline
PostPosted: Wed Oct 13, 2021 9:36 am    Post subject: Re: Pop-Top Protection Reply with quote
You'll love it. I've been using one ever since I first bought my van and it's made it so my canoe loads onto the van more easily than any of my other vehicles.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Wed Oct 13, 2021 11:29 am    Post subject: Re: Pop-Top Protection Reply with quote
This is what we use to load two canoes onto our Westy; the Thule "WaterSlide"
Simple and easy to use. We have light weight kevlar boats and the pad also protects them while loading.
https://www.etrailer.com/Accessories-and-Parts/Thule/TH854.html
https://www.rackwarehouse.com/thule-854-water-slide-vehicle-protecting-kayak-mat.html
It rolls up into a small bundle. Works great!
Currently:
