Splicetree Samba Member
Posted: Mon Nov 22, 2021 1:59 pm Post subject: Dometic/Elektrolux RM 182 AC input voltage |
Hi guys,
I have a T25 Syncro '91 which I have imported from Canada to Netherlands. I'm in the process of going through all the electrics to get it converted. It has a 110v inverter and sockets which I have removed and I have installed a 230v charger.
Now I am wondering if the original Dometic / Electrolux fridge, RM-182, that has the option to run off of shore power, in Canada 110v @ 60hz will run also run off of 230v @ 50hz? Anyone here know what the original input voltage/frequency range is? I tried to find the original specifications on samba or elsewhere online but haven't had any luck. Were there 2 editions? And if so, does anyone know the part that was specific? Alternatively I could install a step down transformer..
Thanks in advance!
fxr Samba Member
Joined: December 07, 2014 Posts: 2644 Location: Bay area CA
Posted: Mon Nov 22, 2021 2:18 pm Post subject: Re: Dometic/Elektrolux RM 182 input voltage |
The 120V part of the fridge is simply a resistive heater. If you fed it with 240V, then you'd double the current, so four times the power. Neither the heater nor the ammonia refrigerant would appreciate this.
Your best bet would be to replace it with a 240V version - I'm sure there must be some available as people replace them with 12V compressor fridges, which might your best option anyway. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Mon Nov 22, 2021 2:30 pm Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
Thanks fxr. That was fast. Why do you think a step down transformer would then not work? If it wouldn't care about the frequency, there's simple travel adapters up to 2000w that can do this. Or am I missing something?
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
fxr Samba Member
Posted: Mon Nov 22, 2021 4:45 pm Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
Splicetree wrote: |
Thanks fxr. That was fast. Why do you think a step down transformer would then not work? If it wouldn't care about the frequency, there's simple travel adapters up to 2000w that can do this. Or am I missing something? |
Sure, you could use a transformer - but that's weight and bulk I wouldn't want. If you're fine with it, OK! The frequency is irrelevant in this scenario. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Tue Nov 23, 2021 12:11 am Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
Exactly. Well I was thinking about something more compact that doesn't do frequency conversion. What do you think about using this for the time being?
https://www.amazon.com/dp/B097M44BXX/ref=cm_sw_r_awdo_navT_g_DNER1HE251AK6EMABHGV
Obviously not the best solutions but it's cheap and since I understand there's only a resistive load (need to be sure) it would work. 2000w should be more than planty.
Thanks again guys! |
fxr Samba Member
Posted: Tue Nov 23, 2021 3:21 am Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
That should keep you going for the time being, if you often stay in places that have full hook-ups.
Let us know how you get on with it! _________________ Jim Crowther
Vespa GTS 300 |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23853 Location: NYC/Upstate/ROW
Posted: Tue Nov 23, 2021 4:14 am Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
Dometic has excellent customer support. Send them an email and see if there are conversion options direct from the manufacturer. Most stuff made is 50/60 Hz compatible but motors are one of things that like to be kept native. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
RawUmber Samba Member
Posted: Tue Nov 23, 2021 8:39 am Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
Dometic RM182B service manual:
https://www.loam.org/vw/Vanagon/DometicRM182B/DometicRM182B.pdf
Another way to rig it up for shore power would be to forget the 120V input and instead connect your domestic shore power to a suitable ~12V camper battery charger, then run the refrigerator from 'battery' 12V. The 12V heater might not run as effectively as the 120V heater, but it might simplify your setup. |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1936 Location: Vancouver Island, BC
Posted: Tue Nov 23, 2021 10:25 am Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
The thermostat does not work on 12V, only on shore power and propane.
Also, If I recall correctly, draw on 12V is 7A, which means 84W. Doesn't sound like much. I bet the shore power mode offers more power (and more cold). _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Ziegel Samba Member
Posted: Tue Nov 23, 2021 1:00 pm Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
Brickwerks have the 230v element. Iβd be surprised if it was any more complex than swapping it out and ensuring the wiring feeding it is fit for purpose.
[url] https://www.brickwerks.co.uk/t3-parts/t3-westfalia...v-85w.html [/url] |
VicVan Samba Member
Posted: Tue Nov 23, 2021 3:31 pm Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
According to this link the 220V element is 85 W, so the same power as the 12V one. Interesting. So running it on 12V would mean running it full blast. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Ziegel Samba Member
fxr Samba Member
Posted: Tue Nov 23, 2021 4:15 pm Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
VicVan wrote: |
According to this link the 220V element is 85 W, so the same power as the 12V one. Interesting. So running it on 12V would mean running it full blast. |
You can always put a thermostat on the 12V side. You can get two for $10 !
https://www.amazon.com/gp/product/B07H2X4NNR
I run one of these on my Peltier effect cooler. Halves the total power draw. _________________ Jim Crowther
Vespa GTS 300 |
VicVan Samba Member
Posted: Tue Nov 23, 2021 11:20 pm Post subject: Re: Dometic/Elektrolux RM 182 AC input voltage |
fxr wrote: |
VicVan wrote: |
I run one of these on my Peltier effect cooler. Halves the total power draw. |
Nice trick! A good way to decrease the risk of killing the battery if I forget to stich the 12V off.. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
