Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp
Buggeee
Buggeee is offline
PostPosted: Fri Apr 01, 2022 5:40 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
More preparations
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
Buggeee
Buggeee is offline
PostPosted: Sat Apr 02, 2022 2:03 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
..and more preparations
Buggeee
Buggeee is offline
PostPosted: Sun Apr 03, 2022 1:42 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Progress
Buggeee
Buggeee is offline
PostPosted: Mon Apr 04, 2022 6:11 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Inch by inch...
Buggeee
Buggeee is offline
PostPosted: Tue Apr 05, 2022 6:53 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
vamram Premium Member
vamram is offline
PostPosted: Wed Apr 06, 2022 11:44 am    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Good gosh almighty Buggee, you are a machine! I'd say "inspirational" but "scary" comes to mind! Hope Eastwood is giving you some great promotional discounts for the product placement! Wink Laughing
Click to view image
Save the Supers!!
Buggeee
Buggeee is offline
PostPosted: Wed Apr 06, 2022 12:25 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Hey V! I've been hiding out with these big dogs in the Splitty Bus forum, you should see what they do over here!
I got that Eastwood thing years ago when one of my minions thought he was getting into welding and fabrication and it's been sitting in the corner ever since. Shocked I suddenly realized it could be used for something. Very Happy
I'll be back on the Super Duper as soon as it's warm enough to start painting again. Really good to have you stop by.
Buggeee
Buggeee is offline
PostPosted: Thu Apr 07, 2022 5:35 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Hunting pinholes with a bright light
Welded up the pinholes. Final grinding inside and out, mostly on the outside.
Persuaded a little bit of warp into submission with hammer and dolly and blocked the area with 60 grit for some bite.
Let the healing begin.
Buggeee
Buggeee is offline
PostPosted: Sat Apr 09, 2022 5:34 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
All of this, just to mount a battery! Somewhere in my mind, before commiting to this process, I actually considered setting a piece of plywood in there just to get the summer started early. Shocked
I blasted the Autocraft battery tray clean of the shipping primer, and welded it in. I had a hard time welding upside down under there but did not burn through the corner. I'll take that as a win. Very Happy
It's ugly, it's all metal... And it's mine. (p.s. those those little specks of light in the picture are not pinholes, they are reflections from the flash.)
Buggeee
Buggeee is offline
PostPosted: Sun Apr 10, 2022 5:28 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
I just fabricated this splash panel from scratch! I feel like I'm flying. My own personal mountain top. Very Happy
silkvw
silkvw is offline
PostPosted: Sun Apr 10, 2022 7:23 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
You do nice work! And have a great attitude about your project.
Keep it up!
'64 single cab Big Bend Bus Bash 2015 '16
'59 camper BBBB 2017 '18 '19 '20 '22 New Mexico
'70 Ghia........Bonneville,........TX Mile,........142 mph......(sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=641871&highlight=
Buggeee
Buggeee is offline
PostPosted: Mon Apr 11, 2022 6:35 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Well, I have no idea why this little wall is here. But it had one then, and it has one now.
Here's how that exercise in origami went down in my barn...
Buggeee
Buggeee is offline
PostPosted: Fri Apr 15, 2022 11:17 am    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Just a little progress. The tail light is cut out using the chrome ring as a stencil. Duraglass has been sanded down and a skim of Rage applied. Its an exercise in self restraint to not refinish this entire corner panel, but this is not the time for elective surgery. Birds are chirping.
I'm using 3M Panel Bond as the seam sealer in the joint of the battery tray to rear corner. Since the spot welds supporting the battery communicate directly to the exterior skin, I want to spread the load as evenly as can be possible. My imagination has that heavy battery working on the exterior skin over every bump and getting dimples or something.
Mr Margaret Scratcher
Mr Margaret Scratcher is offline
PostPosted: Sat Apr 16, 2022 8:35 am    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Buggeee wrote:
I'm starting in on the battery tray so I can have a battery.
Be gentle, this is advanced level for me. I have been studying....
I'm also diving headfirst into the battery tray as my first real attempt at a repair here: https://www.thesamba.com/vw/forum/viewtopic.php?t=723551&start=40 - if mine turns out as good as yours has so far Ill be happy!
Buggeee wrote:
I found this fiberglass treat.
This looks very similar to the story on my rear corner too...
Buggeee
Buggeee is offline
PostPosted: Sat Apr 16, 2022 2:47 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Mr Margaret Scratcher wrote:
I'm also diving headfirst into the battery tray as my first real attempt at a repair .
We'll keep chipping away at it from both sides of the pond!!! Very Happy
Buggeee
Buggeee is offline
PostPosted: Sat Apr 16, 2022 2:50 pm    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Feels good to have this corner in primer!
PostPosted: Sun Apr 17, 2022 1:56 am    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Yep yep!
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Sun Apr 17, 2022 4:24 am    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Super nice job Buggeee, what tool did you uses to cut that curve out so nicely? You are a master artist and I love your work. Applause Applause Applause
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
Buggeee
Buggeee is offline
PostPosted: Sun Apr 17, 2022 9:34 am    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
LAGrunthaner wrote:
...what tool did you uses to cut that curve out so nicely?...
Thank you L! The support and positive vibe in this community is fantastic.
Here's how that went down.
Big Bill
Big Bill is offline
PostPosted: Tue Apr 19, 2022 7:54 am    Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp Reply with quote
Awesome workmanship, if wonder if your bus realizes just how lucky it is you are now the owner. Carry on, I will be following. Very Happy
Page 6 of 10
