New Project 1979 Adventurewagen - What Are These???!
stevehiggins1984
stevehiggins1984 is offline
PostPosted: Fri Aug 26, 2022 7:46 am    Post subject: New Project 1979 Adventurewagen - What Are These???! Reply with quote
Hi Guys,
First post, just reveived my camper into the UK. I bought her in 2010 when I lived in the states (and posted a few times on here) but that email long sinced closed down etc! Life got in the way with moving back to the UK but I finally got Wilma shipped back.
The bus is a 2l 1979 Adventurewagen and last night I had it running for about 10 seconds before it cut out, which is encouraging. On order now are some new fuel lines and I noticed some vacuum issues when inspecting today which have been semi addressed minus a couple of new hoses once I get them. Patience in order now to address these issues but it was running in the States so hopefully all will be fine.
In the engine bay, the opposite side of the battery tray I have these 2 cables that run under the bus. I am not able to find what they are and what they do. Would someone be able to point me in the right direction so I can search for something meaningful?
I've taken a few from underneath in case that helps
Cheers
Steve
richparker
richparker is offline
PostPosted: Fri Aug 26, 2022 7:52 am    Post subject: Re: New Project 1979 Adventurewagen - What Are These???! Reply with quote
Air conditioning.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
stevehiggins1984
PostPosted: Fri Aug 26, 2022 7:59 am    Post subject: Re: New Project 1979 Adventurewagen - What Are These???! Reply with quote
That's great, cheers. I can see where they should attach to the compressor now. I was just a bit confused as I wasn't sure if it was missing anything as quite a few bits on the Adventurewagen that I can't easilly find info on.
Appreciate your help.
