Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24774 Location: Olympia Wash Rinse & Repeat
Posted: Sun Feb 26, 2023 6:25 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
Thanks for the update! Keep this situation in mind when the next hurdle comes up. Just take it one step at a time, you will get there.... _________________ In Stereo, Where Available! |
RCJH77 Samba Member
Joined: March 27, 2022 Posts: 193 Location: Johnson County, KS
Posted: Sun Feb 26, 2023 6:01 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
I'm ecstatic to report that the motor is back in and the bug is shifting perfectly! To everyone who responded to this thread with advice, suggestions, etc., I cannot thank you enough! Couldn't have done it without you! |
RCJH77 Samba Member
Posted: Fri Feb 24, 2023 9:07 am Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
It's motor install day (if I can find a helping hand...otherwise it'll be Sunday)!
RCJH77 Samba Member
Posted: Thu Feb 23, 2023 9:01 am Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
Well, then 253 ft lbs it is!
Tried a different method for measuring the end play and I'm feeling much more confident in the original shims that were used. I watched a Chris Vallone video where he was rebuilding a 36hp motor and noticed that he measured the end play like this:
1. Install metal and paper shims.
2. Install flywheel (torque to 75 ft lbs)
3. Measure end play (using the same EMPI tool I'm using)
Using this method, I found that I have approximately .004-.005 inches of end play, which is within the allowable limit. With that out of the way, I think I have everything else buttoned up and ready for the motor to go back in.
The only lingering question, which happens to be the most critical question, is how this all happened in the first place. Best guess is that the PO didn't install the pressure plate correctly (tightened the bolts incorrectly, didn't torque them, etc.). I know he left out the paper shim on the flywheel, but I highly doubt that would've caused all of this.
Anyhoo, I'm just going to move forward and hope that I've corrected his mistake(s). Hope to report good news soon! |
EVfun Samba Member
Posted: Wed Feb 22, 2023 11:41 am Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
RCJH77 wrote: |
Sort of a mini-sidebar, but still on the current subject of this thread...
Why does "everyone" suggest torqueing well beyond the recommended torque limit for the flywheel gland nut? I've done a lot of research (probably way too much) on this subject and I've found that ~99% of the resources I've found recommend torqueing the gland nut to 250-300+ ft lbs, which is significantly more than the Bentley manual states (217 ft lbs).
Today, I finally found one more resource that suggests 217, but that's it. My gut tells me to stick with 217, but I'm curious as to why anyone would suggest more torque. |
Well, my last 36 horse engine had the flywheel get a little loose and started knocking. Drove it 3 miles home, parked it, and put it up for sale -- I need less cars not more. Sold it that way and the buyer towed it home. I have no idea if the crank was saveable. That is a rebuild level tear down. _________________
Wildthings wrote: |
Posted: Wed Feb 22, 2023 9:00 am Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
RCJH77 wrote: |
VW thru Bentley upped the torque to 253 Ft Lbs. sometime in the 1970s. _________________ In Stereo, Where Available! |
RCJH77 Samba Member
Posted: Wed Feb 22, 2023 8:47 am Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
RCJH77 Samba Member
Posted: Sun Feb 19, 2023 7:26 am Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
pastellgreen wrote: |
And don't forget the paper gasket should be installed also during measurement. It will be compressed about 0,05mm, so it adds 0,15mm to the calculation. |
Appreciate the reminder! 👍 |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1050 Location: Germany
Posted: Sun Feb 19, 2023 2:39 am Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
RCJH77 Samba Member
Posted: Sat Feb 18, 2023 9:23 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
Awesome. Thank you! |
RCJH77 Samba Member
Posted: Sat Feb 18, 2023 9:21 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
glutamodo wrote: |
As far as the tool goes, I think you have the lock nut on the wrong side.
I also think the lock nut is normally much thinner than that. I had a look at pics I took of such from long ago, It was a much better quality SP brand tool and it did have slightly thinner lock nut, but while it was a feeler gauge tool. I had found I could fit an SP dial indicator onto it.
Oh geez, you're right. That's weird because that's how it was straight out of the package. But yeah, you're right. I'll flip it around tomorrow and see if that helps. Thanks! |
Posted: Sat Feb 18, 2023 9:06 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
RCJH77 wrote: |
Something like this?] |
Yes, that should do if the quality is not too bad. If you look on Ebay you can find vintage made in USA dial gauges and use that cheap foreign set just for the mounting parts.
https://www.ebay.com/sch/i.html?_from=R40&_nkw...mp;_sop=15 _________________ In Stereo, Where Available! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26328 Location: Douglas, WY
Posted: Sat Feb 18, 2023 7:43 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
_________________ Andy T.
RCJH77 Samba Member
Posted: Sat Feb 18, 2023 7:34 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
Eric&Barb wrote: |
If the .88mm shims did not lock the engine up before, then yes your measurement is incorrect. Get a good quality dial indicator (not a junk digital one) and a clamp setup to get a good reading. Then drop the EMPI tool in the scrap pile. |
Posted: Sat Feb 18, 2023 6:52 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
If the .88mm shims did not lock the engine up before, then yes your measurement is incorrect. Get a good quality dial indicator (not a junk digital one) and a clamp setup to get a good reading. Then drop the EMPI tool in the scrap pile. _________________ In Stereo, Where Available! |
RCJH77 Samba Member
Posted: Sat Feb 18, 2023 5:59 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
Something isn't right. They don't even offer shims under 0.24mm (x3 = 0.72mm), so my end play measurement can't be right. Argh. I'm stumped. |
RCJH77 Samba Member
Posted: Sat Feb 18, 2023 5:27 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
Trying to determine the end play and I'm running into some weirdness.
I removed the old rear main seal and shims and installed the flywheel (torqued to 225 ft lbs). I did see an old page that said to NOT torque the flywheel, but everything else I've seen says to torque it, so I did. Hope that's correct.
First issue: Using an EMPI end play tool from JBugs, best I can tell, it doesn't fit my flywheel (see pic). I had to modify my setup to get it to work (see pic). Is this the wrong tool for my 36hp motor and flywheel, or am I doing something wrong?
Second issue: I'm getting an end play measurement of 0.030 (.75mm). The shims that were in place when I took the flywheel off are 0.035 (.88mm) in thickness.
Could this have been the root cause of my problems? If I've measured the end play correctly, the shims should've been somewhere around 0.65mm (plus the 0.15mm compressed paper shim), correct? So essentially, the PO allowed for no end play at all, and actually overcompensated. |
Posted: Thu Feb 16, 2023 6:33 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
Cusser wrote: |
Who noticed? Eric or Barb ???
Mrs. Cusser wouldn't notice if she backed into a moose, and poor Bullwinkle was stuck in the engine.... |
Both actually, did not mention to her about the vibration and she voiced the same findings. _________________ In Stereo, Where Available! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31397 Location: Hot Arizona
Posted: Wed Feb 15, 2023 6:08 pm Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
Eric&Barb wrote: |
We definitely have noticed a big difference with how the flywheel and pressure plate orientation balancing made for less engine vibration. |
Mrs. Cusser wouldn't notice if she backed into a moose, and poor Bullwinkle was stuck in the engine.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
RCJH77 Samba Member
Posted: Wed Feb 15, 2023 10:12 am Post subject: Re: 1960 Beetle 6v - Gearshift Housing Bushing / Shifting issues |
Eric&Barb wrote: |
Plus does it hurt to try?? |
Correct! |
