12mpg from a 2.1 - what to look at?
vanis13
vanis13 is offline
PostPosted: Fri Aug 12, 2022 5:04 am    Post subject: 12mpg from a 2.1 - what to look at? Reply with quote
12mpg from a 2.1 - bad palindrome - what to look at?
(Working on friends 2.1, I'm a subi guy)
Maybe my ODB2 Subi made me stupid and lazy and I forgot no-readout diagnostics so hopefully y'all can help out.
History:
Until about a year ago, 1991 weekender has gotten 16 mpg since she bought it new.
About a year ago, mpg had been a steady 12 mpg
She remembers no specific event that's may have resulted in the mpg drop.
I'm visiting for a few weeks so have taken on some repairs for her. First thing was pressure testing coolant system and finding and fixing a bunch of sleeping points. That is now done, it holds 15 psi for hours. It didn't leak prior because it had a bad cap resulting in ambient coolant pressure system.
Re: coolant temp:
Since no ODB data, I can only go by the gauge which on regular driving is below the LED. Last night we drove it uphill on Mt Hood and the hottest it indicated was at the top part of the LED. When we leveled out, the radiator fan was kicking on as expected.
On a typical start up the gauge responds as expected rising in a reasonable time/promptly. It doesn't seem to lag/take a long time to show any activity. It didn't take a long time to rise as one might expect with a thermostat that is stuck open. It just doesn't go very high on the gauge which means nothing since there are many reasons the temp may be ok and the gauge shows low.
Re: other possible symptoms:
Starting cold, it has a very low idle speed that wanders a bit. Once warmed up it holds a good sounding 900ish RPM.
We just replaced the air filter but the old one didn't look particularly dirty. (Haven't yet done enough miles on new air filter to see if it made any difference)
What to look for/what to check/what to look for?
Plugs?
Vacuum leak?
Temp 2 sensor readings?
DanHoug
DanHoug is offline
PostPosted: Fri Aug 12, 2022 5:05 am    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
replace the oxygen sensor....
-dan
www.thefixitworkshop.com
brickster
brickster is offline
PostPosted: Fri Aug 12, 2022 6:07 am    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
If it’s not reaching operating temperature, it could be running rich which would lower MPG (and is detrimental to the oil’s lubrication long term). Use an IR temperature thermometer to determine where it’s running.
Pchill2
Pchill2 is offline
PostPosted: Fri Aug 12, 2022 6:16 am    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
Check your spark plugs first.
87 Syncro Westy
Honda K24 swap
Silverghost500
Silverghost500 is offline
PostPosted: Fri Aug 12, 2022 6:24 am    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
Is this the one that the oil drain plug had the red loctite on the threads?
When you drained the oil did it smell like it had gas contamination?
What does the tail pipe exhaust gases look and smell like? Over sooty, or heavy unburned gas smell?
Pull spark plugs and see what they look like. Hopefully they don't have red loctite either. They're probably going to look black and sooty.
1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A conversion
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA
PDXWesty
PDXWesty is offline
PostPosted: Fri Aug 12, 2022 8:07 am    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
This. So simple but I missed this one time and it was the cause of my poor running. New plugs is the first thing I'd try.
89 Westy 2.1 Auto
Californio
Californio is offline
PostPosted: Fri Aug 12, 2022 8:31 am    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
It's notorious difficult to get consistent MPG on these as driving conditions matter so much. My mileage drops way down, like from 19 to 14, if I go from 55 to 70 on the freeway. More if there's headwind, hills, etc. As you know.
So whatever running issues this one has, I wouldn't look too closely at MPG as an indicator.
If I remember right there's a heating circuit on the O2 sensor on later models and if this isn't working, it could make the engine take longer to idle correctly. Easy to test.
ThinkingD
ThinkingD is offline
PostPosted: Fri Aug 12, 2022 9:28 am    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
Maybe an exhaust leak/crack before the o2 sensor causing it to run rich by allowing fresh air into the system pre-o2 and making the ECU think it is running lean.
87 Titian Red Westfalia 2.0 VW I4 SOHC CBPA manual Ottawa, Ontario
nemobuscaptain
nemobuscaptain is offline
PostPosted: Fri Aug 12, 2022 11:51 am    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
Dont just replace anything without testing them. This involves a multimeter mostly (maybe a pressure regulator) and your Bentley.
Obviously you have to be pretty rich too get that.
Re: coolant temp:
The fact that the engine was getting up to temp doesnt mean the temp sensor was reading the temp correctly. Check the temp sensor output. If the ECU doesnt think the engine is warm, it won't let the 02 sensor lean out the mixture.
Plugs?
Vacuum leak?
Always start there.
Check grounds (equals clean metal) and all connections.
Check the wires.
Use a vac gauge to determine if you have leaks. It is CHEAP and finds leaks my ears never have. But this doesn't seem like one to me.
Temp 2 sensor readings and the O2 sensor. Measure their outputs and confirm the O2 sensor isn't improperly grounding.
That's where I'd start. Others are FAAAAAR better with FI so Im sure they will have input.
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
dabaron
dabaron is offline
PostPosted: Fri Aug 12, 2022 12:34 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
i will get 12-14 mpg in the city and 18-21mpg on the highway.
are you sure there is an issue?
1991 Vanagon GL Camper
jimf909
jimf909 is offline
PostPosted: Fri Aug 12, 2022 12:39 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
ROFL Laughing
- Jim
Butcher wrote:
Guilty as charged.
nemobuscaptain
PostPosted: Fri Aug 12, 2022 1:46 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
My first thought was, you're not running right... but I guess it depends on where you are and what crazy "gas" concoctions you are forced to run or how bad your traffic is. With my WB running Ohio gas (still forced e10) I got a pretty solid 16mpg at worst, usually 17, but never got better than a bout 20 on the highway.
11BC2
11BC2 is offline
PostPosted: Fri Aug 12, 2022 4:37 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
How much ethanol is in the fuel?
Dear Leader has increased to amount of ethanol; higher ethanol content = lower MPGs.
Ahwahnee
Ahwahnee is offline
PostPosted: Fri Aug 12, 2022 5:31 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
You might want to verify that the center lead on the (thick green) coaxial wire from the O2 sensor isn't shorted to ground. If so much as one strand of the coax shield is in contact with the connector that will cause the engine to run very rich (though usually that drops mileage into the single digits). A search will reveal more detail.
0to60in6min
0to60in6min is offline
PostPosted: Fri Aug 12, 2022 6:17 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
How about the air filter and the duct connected to the air filter canister?
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Aug 12, 2022 8:05 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
If my tire pressure is low so is are my mpgs.
First thing is always a basic tuneup.
Plugs, filters, etc.
A misfire will do it too. Clogged cat. Slow or dead O2 sensor. Out of whack air flow meter. etc.
But basics first. Then the advanced stuff.
And the crappier gas has an impact today. too.
Wildthings
Wildthings is offline
PostPosted: Fri Aug 12, 2022 9:21 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
Try adding a bottle of FI cleaner to the gas tank, that should get the spray pattern of the injectors up to snuff. You might also want to check your timing, following either the instructions in the manual, or the procedure Tencentlife promotes. Neither while particularly hard can be done without following the instructions to a "T".
vanis13
vanis13 is offline
PostPosted: Sat Aug 13, 2022 5:13 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
Thanks for the leads... Went down the rabit hole of coolant temp/ECU/gauge writeups this morning...yikes! A lot there to know with that.
Additional data ...."tuneup" done 6k miles 3yrs ago. The 12mpg started more recently
From the suggestions so far
Tail pipe clean, no excess soot. Actually no soot at all
A little arcing on the rotor tip. Cleaned with sandpaper. Cap looked good. Notice the circular wear pattern on the center spin point. Almost as of it was in there crooked. I seated it well. There was some spring in the distributer shaft - when I pressed rotor ask the way down whole shaft popped up 1/8?". Is that normal?
Plug condition in firing order
r39o
Samba Polizei
r39o is offline
PostPosted: Sat Aug 13, 2022 6:22 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
Wow, is there ANY exhaust coming out?
That is freakishly clean and rusty.
BTW That rotor is shot.....
DanHoug
DanHoug is offline
PostPosted: Sat Aug 13, 2022 6:35 pm    Post subject: Re: 12mpg from a 2.1 - what to look at? Reply with quote
the exhaust shows no evidence of, well, exhaust. so is the exhaust system rusty? are there leaks ahead of the O2 sensor?
an exhaust leak before the O2 sensor can admit air in between engine pulses. the O2 sensor sees this as running lean and richens the mixture up, when it really doesn't need it. while the muffler can be rusted out without effect on the O2 sensor, a cracked header, loose joint, or pinhole will admit false air.
-dan
