Hot Air Samba Member
Joined: February 25, 2007 Posts: 672 Location: Baltimore, Maryland
Posted: Thu Apr 17, 2025 11:21 am Post subject: Hood crest install |
How do these hood crest attach to the hood. O know I will need shorter moulding. Picks of a hood with the crest on and missing showing attachment holes.
_________________ 73' Bug
85' Porsche 911 Carrera 3.2 |
Dan22 Samba Member
Joined: August 30, 2019 Posts: 660 Location: Battle Ground, WA
Posted: Thu Apr 17, 2025 11:56 am Post subject: Re: Hood crest install |
Carefully bend those tabs up on the back, and poke them through the holes in the hood. Then flatten back down. This assumes you hood has the two slotted holes.
Hopefully they are not fatigued so bad that they break. _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 876 Location: Moreno Valley
Posted: Thu Apr 17, 2025 12:31 pm Post subject: Re: Hood crest install |
looks to be an early what is called a 4 brick emblem . count the second row of bricks from the bottom . |
finster Samba Member
Joined: May 26, 2012 Posts: 10081 Location: not far from the madding crowd
Posted: Fri Apr 18, 2025 3:57 am Post subject: Re: Hood crest install |
as stated above there were slotted holes for mounting the crest.
this is a later car but shows the slots (can I assume their position didn't change?)
this is how it should look when fitted - note the trim strip has a 'cut out' so it fits nicely over the crest mounting
this is how not to do it!
_________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Fri Apr 18, 2025 4:41 am Post subject: Re: Hood crest install |
Thank you. That's what I needed. _________________ 73' Bug
stale air Samba Member
Joined: August 23, 2007 Posts: 5664 Location: Senoia Ga, formerly NorCal
Posted: Fri Apr 18, 2025 5:28 am Post subject: Re: Hood crest install |
Dont forget the "seals" that go on the backside.
_________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Fri Apr 18, 2025 9:27 am Post subject: Re: Hood crest install |
stale air wrote: |
Dont forget the "seals" that go on the backside. |
...of the hood  _________________ "we're here on Earth to fart around" kurt vonnegut
Posted: Fri Apr 18, 2025 9:29 am Post subject: Re: Hood crest install |
finster wrote: |
stale air wrote: |
...of the hood  |
Yes, thanks. I should have been more clear.  _________________ WANTED: Henry Veale Santa Rosa plate frames
Dan22 Samba Member
Posted: Fri Apr 18, 2025 9:53 am Post subject: Re: Hood crest install |
Would someone share how the seals install. Are they just putty, or do they get poked through with the bend over pins?
And who sells the seals?
EDIT: I see WW has them!
Thanks! _________________ 1-0900722 die langsame grüne Schildkröte
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25988 Location: Olympia Wash Rinse & Repeat
Posted: Sun Apr 20, 2025 3:10 pm Post subject: Re: Hood crest install |
Would also use some butyl rubber (A clay like sealant) between the base and hood to seal the water from those mounting holes. _________________ In Stereo, Where Available! |
