8 and 15 amp fuse position
5657 is offline
PostPosted: Fri Apr 14, 2023 7:30 pm    Post subject: 8 and 15 amp fuse position Reply with quote
The Owners Manual refers to 8 and 15 amp fuses but doesn't show which fuse goes in which position in the fuse block. Photos in the gallery show a variety of combinations being used. Which is correct? Thanks.
1956 Type 2 Ambulance
1957 Type 1 Deluxe
1975 914 2.0 litre
2017 Jetta TSI
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Apr 14, 2023 7:50 pm    Post subject: Re: 8 and 15 amp fuse position Reply with quote
Would help greatly to know what year of bus is involved..... Confused
In Stereo, Where Available!
5657
5657 is offline
PostPosted: Fri Apr 14, 2023 7:52 pm    Post subject: Re: 8 and 15 amp fuse position Reply with quote
Indeed it would. Friday night after a long week....
It's a 1956 ambulance. It has the regular 1956 6 fuse box.
1957 Type 1 Deluxe
1975 914 2.0 litre
2017 Jetta TSI
Eric&Barb
PostPosted: Fri Apr 14, 2023 8:26 pm    Post subject: Re: 8 and 15 amp fuse position Reply with quote
No worries! Smile
Should be 15 Amp in all, except one fuse spot. The far right spot going to the horn and wiper motor being 8 Amp.
You can also confirm this by sorting out the Watt/Amp draws for each fuse. EG starter solenoid draws about 10-12 Amps. So 12 Amps x 6 volts = 72 Watts.
A 15 Amp fuse x 6 volts = 90 Watts
While an 8 Amp fuse x 6 volts = 48 Watts.
Wiper runs 20 to 22 Watts, etc...
For those items without listed Amp/Watt draws in the VW literature, a clamp type multi-meter will show you the real amounts of those.
5657
5657 is offline
PostPosted: Fri Apr 14, 2023 8:55 pm    Post subject: Re: 8 and 15 amp fuse position Reply with quote
Thanks.
The various fuse kits being sold seem to be composed of 8 amp and 16 amp fuses. Do 15 amp European type fuses even exist anymore?
1957 Type 1 Deluxe
1975 914 2.0 litre
2017 Jetta TSI
PostPosted: Fri Apr 14, 2023 10:33 pm    Post subject: Re: 8 and 15 amp fuse position Reply with quote
Is an ambulance different?
Normally it's all 8 amp fuses. They are white in color.
You are right it says 8/15amp but I have no idea what the 15 amp would be used for, unless it's some accessory.
I believe everyone uses the 16amp / red fuses now, if needed
earlywesty
earlywesty is offline
PostPosted: Sat Apr 15, 2023 5:21 am    Post subject: Re: 8 and 15 amp fuse position Reply with quote
Yes, Everett is correct. All white 8 amps except one red 15a. Bentley manual should show it well. Wiring diagrams are available on this site.
DeadBlow
DeadBlow is offline
PostPosted: Sun Jul 06, 2025 12:25 pm    Post subject: Re: 8 and 15 amp fuse position Reply with quote
I have a 62 Doka with a 12 volt conversion and 8 position fuse box... should I use 16 Amp fuses all around? Hard to find any info on this....
Buying things on the internet... Sports.
1962 Doka
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun Jul 06, 2025 3:01 pm    Post subject: Re: 8 and 15 amp fuse position Reply with quote
I’ve always just used 8 amp on stock split screen Bus's.
Roads Scholar
Member# 2059
70bus Premium Member
70bus is offline
PostPosted: Sun Jul 06, 2025 3:45 pm    Post subject: Re: 8 and 15 amp fuse position Reply with quote
Page 52 of my 64/65 model year Owner's Manual says 8 amp fuses; pic of fuse box is also all white fuses. Checking the one for your year is best bet.
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
DeadBlow
DeadBlow is offline
PostPosted: Tue Jul 08, 2025 9:38 am    Post subject: Re: 8 and 15 amp fuse position Reply with quote
Great! Thank you!
1962 Doka
70bus is offline
PostPosted: Tue Jul 08, 2025 9:50 am    Post subject: Re: 8 and 15 amp fuse position Reply with quote
So I looked at EDIT - first poster's 57 Owner's Manual in the Tech section... and while it CLEARLY shows a row of white (8 amp) fuses across the box, the damn text says keep a set of spares in 8 AND 15!
So much for looking at the manual as 'best bet.'
I would guess a 15 could go on farthest right, as it handles all the lights, wipers, etc. But if an 8 there isn't blowing regularly under load, it's safer to keep that lower amperage fuse in place. If it does blow eventually, you'll know you have an unexplained load increase.
For the 62 owner, the manual does say "8 amp fuses" for spares.
Craig K
70 Neunsitzer
65 Pritschenwagen
BarryL Premium Member
BarryL is offline
PostPosted: Sat Jul 12, 2025 11:40 am    Post subject: Re: 8 and 15 amp fuse position Reply with quote
'66 and '67 are Red Fuse in two right spots.
Not sure about Westy interior lights fuse or backup lights harness fuse.
