kickdown switch missing
t-royR
t-royR is offline
PostPosted: Thu Apr 27, 2023 2:11 pm    Post subject: kickdown switch missing Reply with quote
There is no kickdown switch on my 69 automatic FI fasty. Reading suggests there should be one.
I took it for a drive a bit ago and while going up a good hill, I punched it, and it downshifted. As I understand it, that is the affect a kickdown switch is to have. With my car missing one, does it make sense it would kickdown like this? What am I missing?
T-roy
T-roy
75 Super
71 Super
71 Ghia coupe auto-stick
71 Ghia conv
69 Fasty
74 Ghia conv
t-royR
t-royR is offline
PostPosted: Thu Apr 27, 2023 2:11 pm    Post subject: Re: kickdown switch missing Reply with quote
It won't always kickdown. Usually, when I decide to try it, I kick it and it just stays in the 3rd gear I'm in.
T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Apr 27, 2023 10:28 pm    Post subject: Re: kickdown switch missing Reply with quote
Yours is shifting down based on load (sensed manifold vacuum). This is usually adequate.
However, there are driving conditions where you want it to downshift, but this vacuum effect won't do it, so you use the kickdown switch to force it.
All else fails, use the selector lever.
They come up in the classifieds occasionally, usually with the whole IAD assembly.
With this feature you can exercise a great deal of control of both up and down shifts with your right foot:
- Downshifts can of course be forced by mashing the pedal.
- Upshifts can be forced by letting off the gas for a moment, then pressing it again-- but not past the kickdown position.
When the engine is running well and with the kickdown switch, even fun canyon roads can be driven with an automatic, up-and down-shifting almost as well as with a stick, all by modulating the throttle. Very satisfying!
raygreenwood
raygreenwood is offline
PostPosted: Fri Apr 28, 2023 6:53 am    Post subject: Re: kickdown switch missing Reply with quote
It's my understanding and experience that if it was fuel injected the switch should be under the gas pedal. The carbed engines had one on the carb linkage.
Ray
KTPhil is offline
PostPosted: Fri Apr 28, 2023 8:14 am    Post subject: Re: kickdown switch missing Reply with quote
Ray
I've never seen a Type 3 with a pedal kickdown. Some may have invented one when they couldn't find an OG style switch. All FI Type 3s I've seen mounted it on the IAD assembly (auto and sticks).
t-royR
t-royR is offline
PostPosted: Fri Apr 28, 2023 10:52 am    Post subject: Re: kickdown switch missing Reply with quote
Thanks all
T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv
Bobnotch
Bobnotch is offline
PostPosted: Fri Apr 28, 2023 11:33 am    Post subject: Re: kickdown switch missing Reply with quote
KTPhil wrote:
Ray
Yup, same here. The switch is an arm style switch, held onto a bracket with 2 screws. Same switch used in both models, just how it's set up is different. There should be a spring loaded part on the throttle body arm that allows it to softly come into play.
Bob 65 Notch S with Sunroof
Tram wrote:
KTPhil is offline
PostPosted: Fri Apr 28, 2023 12:17 pm    Post subject: Re: kickdown switch missing Reply with quote
Yes, the idea is that at some point the throttle flap is wide open, but the other part of the pivot allows further movement to close the switch. That further movement is resisted by the spring. So you feel "full throttle" and can stop there... or press further to "full pedal" and trigger the downshift.
Carb linkage:
FI linkage:
raygreenwood
PostPosted: Fri Apr 28, 2023 1:53 pm    Post subject: Re: kickdown switch missing Reply with quote
Bobnotch wrote:
KTPhil wrote:
Ray
Yep my bad....mixing up my type 3's and 4's. When KTPhil posted the sketch of the throttle switch the memory came back. Its been forever since I worked on an automatic type 3.
I also tend to forget that the type 3 pedal is hinged at the bottom instead of the top so the kick down switch bracket would not fit under the pedal.
But....it would be dead easy to install a micro switch on the type 3 pedal. Ray
KTPhil is offline
PostPosted: Fri Apr 28, 2023 3:05 pm    Post subject: Re: kickdown switch missing Reply with quote
Micro switches are easy to find:
https://www.google.com/search?q=micro+switch&t...LMP7-G5iAE
The tough part is adapting a given switch's mounting holes to the VW throttle assembly. It can be done if you are clever and patient.
These same switches could be adapted to a pedal actuation, again requiring cleverness and patience.
