70bus  Samba Member
Posted: Tue May 09, 2023 12:29 pm Post subject: The Ol' Engine CC/Tranny Ratio Song and Dance |
I've dug through seemingly all the tranny articles, but would appreciate opinions on my specific options. 65 s/c. Big nut stock trans/RGBs needing a rebuild.
Motor options:
I have a 1600 SP in my '70, 69mm CW crank, stock cam. 30P3 carb and 205 something dizzy.
I have a spare Mexican universal case, stock, but it was last .040 and might need cut to 60. I have a pair of 211 '1500' heads appropriate for the truck.
I have an aluminum universal case, bored for machine-in 88s, full-flow, 69mm CW crank. SP heads. Think it was 1960cc or so. Also stock carb/diz/cam.
Tranny options:
Stock, or 3.88/82 Freeway Flyer. I have a NOS 3.88 R&P if I go that way.
Variables:
I prefer SP heads for torque. Have plenty of SP parts; no DP ones. I live on a hill which has a 25-degree slope nearly the whole way, and portions exceeding 30. I rarely drive on interstates, but it's sometimes necessary. Almost all roads in my state have hills, and some gnarly ones at that. Not looking to dump money on strokers, or dual carbs (tho would consider a 72 crank if stock carb is doable with it).
If I throw in a 1500 or 1600, various threads suggested a Freeway Flyer ends up being a dog with those engines. Stock tranny is great for hills with them, but a little slow or maxxed fan on highways. If I put in the AL case with stock gearing, I'm thinking I get a little more oomph on the hills, but unsure if I get slower fan speeds/higher street speeds. I do not need to do 75 mph, especially in a car with lap belts. The '70 has 3points AND disk brakes, so there's an argument to put the AL case in there as the safety features can handle the extra speed, and put the 1600 in the truck. It sounds like I am best keeping the stock 65 tranny ratios, and can then use any of the 3 motors I have/can build. Going w/ a FF likely means I am using the AL case, but it's unclear if I gain too much advantage to do so.
Thoughts? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
David Raistrick Samba Member
Joined: January 26, 2004 Posts: 633 Location: Geneva, Florida
Posted: Tue May 09, 2023 1:02 pm Post subject: Re: The Ol' Engine CC/Tranny Ratio Song and Dance |
E&B like their 1641/3.88/82/big nut combo.
honestly if you're not getting into 4th, it's really not going to matter a ton. 1st is going to have tons of room to get you and keep you going no matter what's behind it.
isn't that 88x69 a 1679cc or something? didnt you used to have a 1776/3.88?
here's a stock big nut and a 4.12/82, 3.88/82, 3.88/77, and 3.44/77. and some bay/vanagon gearing to compare (colors are still based on upright fan, not t4 fan). [edit: corrected rgb gearing, thanks tom for point out my brain fart]
color bands are cooling related - 2800 is reportedly the best fan range. 1500 min rpm, 3600 it starts to cavitate
keep in mind a 1600 is going to be working a LOT harder at 2500rpm to keep a bus chugging in 4th than say a 2L would be.
_________________ ...david - '66 SO-44 #231
Last edited by David Raistrick on Sat May 13, 2023 7:49 pm; edited 1 time in total |
70bus  Samba Member
Posted: Tue May 09, 2023 1:49 pm Post subject: Re: The Ol' Engine CC/Tranny Ratio Song and Dance |
Sorry, yes, 1680cc on the ALfromhell case seems right. That.s the only motor I’ve run besides a 1600, and both in the 70. The AL seems to hold the heat longer, but the extra cc may mean it isn’t making it as much as an overworked 1600 at speed to begin with.
With our hills, I don’t want to be screaming the motor in second just to get to top. That’s my concern w/ higher gearing. I guess I need 2 transmissions to test out each possible combo. LOL. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Lind Samba Member
Joined: November 06, 2000 Posts: 10215 Location: idaho
Posted: Tue May 09, 2023 9:24 pm Post subject: Re: The Ol' Engine CC/Tranny Ratio Song and Dance |
70bus wrote: |
I live on a hill which has a 25-degree slope nearly the whole way, and portions exceeding 30. |
a 25+ degree slope you want the lowest possible gearing, and you will be climbing it in 1st gear. Perhaps look into mountain gears, small tires and a big engine so you can get into second gear. _________________ .
Wanted:
70bus  Samba Member
Posted: Tue May 09, 2023 9:46 pm Post subject: Re: The Ol' Engine CC/Tranny Ratio Song and Dance |
I'm going to guess that's either an attempt at sound advice, or your usual dry humor. :)
It's a hill the spandex bikers use to train on, by lugging up it foot by foot, throwing up at the top, and then coasting back down. There's a race that sadistically paints the actual slope of each stretch on the pavement.
Always fun to watch the automobile fun in winter.
So yes, I want to get up it. But I think I need to drive in non-alpine zones as well, so I'll keep the stock RGBs. Some people have bad experiences w/ FF and 1600 or less motors, some don't. I'm mostly trying to decide if I get enough extra zing out of the 1680 to make a FF worth it, or if the extra CC make the stock ratio livable at higher speeds. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Lind Samba Member
Posted: Wed May 10, 2023 6:02 am Post subject: Re: The Ol' Engine CC/Tranny Ratio Song and Dance |
Anything higher than stock gearing will not be enjoyable.
25+ degrees is crazy steep. They literally made special gears for people that have to drive roads that steep. Of course those gears make it undriveable on the highway. Stick with stock gearing and a bigger engine and you will be fine. _________________ .
Wanted:
70bus  Samba Member
Posted: Wed May 10, 2023 8:24 am Post subject: Re: The Ol' Engine CC/Tranny Ratio Song and Dance |
I checked a few places, and the 'official' grades range between 8 and 23 for most of the streets. Long story, but we had measured sections with a 3' digital level and got the higher figures.
But yes, my main concern is getting home rather than going 75. Thanks for the input. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Clara  Samba Member
Posted: Wed May 10, 2023 9:00 am Post subject: Re: The Ol' Engine CC/Tranny Ratio Song and Dance |
70bus wrote: |
So yes, I want to get up it. But I think I need to drive in non-alpine zones as well, so I'll keep the stock RGBs. Some people have bad experiences w/ FF and 1600 or less motors, some don't. I'm mostly trying to decide if I get enough extra zing out of the 1680 to make a FF worth it, or if the extra CC make the stock ratio livable at higher speeds. |
With the steep hills in your area don’t over gear it. If anything you want more oomph . I would skip the 3.88 unless you use a bigger motor.
I put a 3.88 in my 65 westy when the trans started popping out of 4th. (big nuts, 1600dp, stock size tires) and it really was better with the 4.37 that it had before. I regretted it. It was not a good match.
While 2800 rpms is where it runs coolest on the flat, that does not mean I stay at 2800 rpms. There is a range of acceptable revs and temps. It’s fine to cruise at 3600rpms.
If it is really hot out. ( over 100f) yes I’ll drive closer to 2800. But if all the tin is in place the engine cools well and I don’t have overheating issues.
A stock 1 ton bus can cruise at 65 mph, according to the owners manual, and according to experience.
In Oregon, that means I pass people on I-5.
No 3.88 needed. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
