Viewing feedback for: Classic Steel Body Email: [email protected] Last Visited: Yesterday
![View user's ads View user's ads](/vw/forum/templates/subSilver/images/lang_english/icon_ads.gif) |
lumber-baron Samba Member
![](/vw/forum/images/avatars/1437545396577bb73b1129e.jpg)
Posted: Fri May 19, 2023 10:21 am Post subject: Classic Steel - [email protected] |
Bought some of Mark’s Silver Weld Thru metal last fall, I picked up the parts from his supplier - Golden Star in Dallas TX. Most of us don’t put these projects together in a weekend, and thought I did look everything over, I didn’t check the fitment of everything right away. This spring I encountered some serious issues with the manufacturing quality of some of the parts to the point that I had to disassemble (drill out all the welds) and rework the entire stampings.
When I contacted Mark about these issues, he pretty much told me to pound sand.
I know that reproduction parts aren’t all plug-n-play and expect to have to make some adjustments, but this was significantly above and beyond that
I would have expected that someone trying to build up a business would have been a bit more accommodating.
Bottom line - I would not recommend doing business with Mark. |
![](/vw/forum/templates/subSilver/images/spacer.gif) |
esde Samba Member
![](/vw/forum/images/avatars/11247560414f9c009720f5b.jpg)
Joined: October 20, 2007 Posts: 6034 Location: central rust belt
Posted: Sun May 21, 2023 12:35 am Post subject: Re: Classic Steel - [email protected] |
Can you detail some of the parts used and problems you encountered please? _________________ modok wrote:
Posted: Sun May 21, 2023 3:23 am Post subject: Re: Classic Steel - [email protected] |
I posted this about the doglegs in the aftermarket metal forum:
https://www.thesamba.com/vw/forum/viewtopic.php?t=478200&highlight=
I also purchased a roof section which is made up of 2 pieces that are lap welded behind the sunroof opening (a minor detail that was not mentioned in his ad). The 2 pieces weren’t properly aligned when they were spot welded at the factory leaving one side longer than the other. Mark’s response was go to harbor freight and buy a spot weld drill. |
