Scotty D Samba Member
Joined: February 08, 2020 Posts: 133 Location: Claremont CA
Posted: Mon Mar 25, 2024 2:12 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
Thanks for the info Bob.
Once this thing is up and running, I'll be sure to get some proper wheel studs installed. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9660 Location: Pearl River, NY
Posted: Sat Mar 30, 2024 6:14 am Post subject: Re: Another Pickle Post - 1973 Squareback |
This photo would be great for the thread "Cats and VWs"- it's been almost a full year since its last post- https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
Scotty D wrote: |
The new Quality Control Manager is on the job.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22440 Location: Kimball, Mi
Posted: Sun Mar 31, 2024 9:46 am Post subject: Re: Another Pickle Post - 1973 Squareback |
Yeah, those shop "inspectors" are everywhere. I've got one that checks on me whenever I'm out in the shop. I personally thought that was a great pic though. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3334 Location: 802 The Pointless Forrest
Posted: Mon Apr 01, 2024 12:54 am Post subject: Re: Another Pickle Post - 1973 Squareback |
give that cat a wrench _________________ "Albatross"! |
Posted: Mon Apr 01, 2024 9:28 am Post subject: Re: Another Pickle Post - 1973 Squareback |
And done. |
Posted: Tue Apr 02, 2024 11:10 am Post subject: Re: Another Pickle Post - 1973 Squareback |
Some questions for the experts.
My oil breather is the version with two caps on top, and no outlets/inlets for vacuum lines.
In the photo below of a '71, I see that the oil breather does have an inlet for the vacuum line running to the air intake (marked 2 in the pic).
Assuming my oil breather is correct for a '73, what should the bung on the air cleaner intake be connected to?
The vacuum line marked 1 in the pic exists on my car, the hose marked 3 in the pic which heads to what I assume is a cleaner box exists as well.
Also, the hose marked 4 in the pic doesn't exist, not sure what the bung on the exhaust elbow is supposed to be connected to.
Sorry for the ignorance, and thanks in advance for your help.
Finally received my Bentley manual. I figure I'll read through it once or twice, and be at Tram's level in no time!!!
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34026 Location: Conejo Valley, CA
Posted: Tue Apr 02, 2024 12:25 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
This diagram is for later cars. See #8 and #9 for the evap canister hoses you are missing. Ignore the rest.
_________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
Posted: Tue Apr 02, 2024 12:29 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
Thanks for that Phil, that's very helpful.
My air intake does have the bung/inlet near the flap just before the oil bath (#2 in my earlier pic), what should I do with that? Just cap it off? |
Posted: Tue Apr 02, 2024 12:33 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
How important is the charcoal canister for the system? Is there a typical bypass for this, assuming it's in poor shape internally after 50 years. |
KTPhil Samba Member
Are there ANY hoses connected to your 2-cap breather box? If not, you will blow oil out the crank seals or pop off those caps. Look on the underside, too.
Otherwise, I'd get a 1-cap breather (with innards - spring, foam, washer) and plumb per the pic. _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
Posted: Tue Apr 02, 2024 12:36 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
KTPhil wrote: |
Otherwise, I'd get a 1-cap breather (with innards - spring, foam, washer) and plumb per the pic. |
Yes, the lower hose shown in red is connected to the bottom of the oil breather and up to the IAD as shown in the diagram. |
KTPhil Samba Member
Posted: Tue Apr 02, 2024 12:37 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
Scotty D wrote: |
Pretty much inoperative at this point. The thin metal tube from the front (expansion box) is probably internally rusted shut and doing nothing.
The canister in the engine area is to store fumes in the charcoal inside. Those thicker (1/2") hoses blow air through it to pick up those fumes, and suck them into the air cleaner to be burned.
But if the little tube (small hose) is clogged, you aren't getting any fumes to begin with.
Your tank is essentially non-vented if that small hose/pipe is clogged. It goes form the tank in the driver's inner fender, along the driver rocker panel, and up above the tranny, with rubber hoses at each end. You might try blowing through to see if it gets ANY flow. Don't smoke around it regardless! _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
KTPhil Samba Member
Posted: Tue Apr 02, 2024 12:40 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
Scotty D wrote: |
KTPhil wrote: |
Ok, then it's correct, as long as there are NO leaks. I'd replace the hose to be sure. I'm not sure what is inside the 2-cap breather box. I'd search here (and in the Type 4 forums for a similar breather, I think) to be sure. This is important, as that is under manifold vacuum and will confuse the FI if it leaks, as well as screw with your PCV function. _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
Posted: Tue Apr 02, 2024 2:18 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
KTPhil wrote: |
Scotty D wrote: |
KTPhil wrote: |
Ok, then it's correct, as long as there are NO leaks. I'd replace the hose to be sure. I'm not sure what is inside the 2-cap breather box. I'd search here (and in the Type 4 forums for a similar breather, I think) to be sure. This is important, as that is under manifold vacuum and will confuse the FI if it leaks, as well as screw with your PCV function. |
The hose to the breather connection is the PCV valve (the white plastic piece on the breather). Ray has a great work around for it that helps keep the FI stable. Otherwise the opening and closing of the valve screws with the idle. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Apr 03, 2024 7:09 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
Awesome! Where would I find said workaround?
I will likely be contacting Jim Adley again for the gas tank vent kit. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Thu Apr 04, 2024 11:11 am Post subject: Re: Another Pickle Post - 1973 Squareback |
Scotty D wrote: |
Ray Greenwood is the author. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Apr 06, 2024 5:07 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
Thanks Mike, I’ll do some research.
Decided to go get some inspiration (as well as parts and a shirt) from the folks at ISP West again. Man that Notch body is just so sweet.
Posted: Sun Apr 07, 2024 11:08 am Post subject: Re: Another Pickle Post - 1973 Squareback |
Yeah, I wish my own sunroof Notch was that clean. That's a great looking t-shirt. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Apr 07, 2024 4:08 pm Post subject: Re: Another Pickle Post - 1973 Squareback |
Bob I read through your entire post. That nutria brown notch is amazing, you guys did an amazing job. |
Posted: Mon Apr 08, 2024 11:38 am Post subject: Re: Another Pickle Post - 1973 Squareback |
Thanks. Hard to believe that was over 10 years ago (2007) that I did that car. It was a lot of work (the rustiest car I ever did), and was a true labor of love. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
