Went and got a notchback
Braukuche
Braukuche is online now
PostPosted: Fri Jan 19, 2024 1:23 pm    Post subject: Re: Went and got a notchback Reply with quote
Jason37 wrote:
Just out of curiosity, what are your plans for carbs on the new motor? To try to save you some headache, the early cars have a narrower engine bay and fitting duals is a pain.
https://www.thesamba.com/vw/forum/viewtopic.php?t=742183&highlight=early
I tried as many carbs as I could get my hands on, and recently tried some DCNF's as well. If you run the LHS backwards and notch the tin around the oil cooler, they might work.
I’m running the original style single side draft and intake manifold with stock exhaust.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
Jason37
Jason37 is offline
PostPosted: Sun Jan 21, 2024 7:42 am    Post subject: Re: Went and got a notchback Reply with quote
Awesome. I was going to go the same route when I built the 1.8 but in the end decided to go to ICT’s for a little more power. I will be watching with interest as I need to rebuild my stock motor and was going to bump it a bit. If you haven’t had any work done to the heads, user Brian_e has an excellent write up in the performance section on improving singleport heads.
Ossipon
Ossipon is offline
PostPosted: Sun Jan 21, 2024 8:09 am    Post subject: Re: Went and got a notchback Reply with quote
This may or may not be an issue for you yet. But something to consider. I was talking to a friend who had the Solex side draft and 64 single port manifold. He told me he had to de-carbon the heat riser twice while he owned it. And the impact of the clogged heat riser was readily apparent with rough running and power loss until it was really warmed up.
I asked him what he did. He tried different manifold and did his best to remove the carbon buildup, and polish the riser, but it would just clog with normal use. Said this was the biggest issue while using the side draft. This issue might be even more noticeable with a larger displacement.
Ossipon
VWs in my life:
Air
Type 1 - 59, 62, 63, 71 Super 68 KGhia/ Type 2 - 59 Single Cab / Type 3 - 64 Notch
Water
GTI 83, Jetta 81, 85, 87, 91 TDI, 98 TDI, 09 / New Beetle 99 / SportWagen 05, 13 / Tiguan 18 / T3 92
Braukuche
PostPosted: Sun Jan 21, 2024 9:51 am    Post subject: Re: Went and got a notchback Reply with quote
I have a NOS intake, but maybe he was running too rich?
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Braukuche
PostPosted: Mon Jan 22, 2024 9:35 pm    Post subject: Re: Went and got a notchback Reply with quote
Raining cats and dogs today so went into the gorge and finished building the long block for the Notch.
New Autolinea Aluminum case
69mm German crank, one over.
90.5 pistons and cylinders
New rods
Engle 90 cam and lifters
6v flywheel
New AA single port heads, stock springs, stainless valves.
All original German hardware except the rod ARP bolts.
7.8 compression with an 040 deck, tight but should run nice and cool.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Braukuche
PostPosted: Sat Jan 27, 2024 5:45 pm    Post subject: Re: Went and got a notchback Reply with quote
I’ve got my heater channel in, still acting on the outer rocker. What’s the deal with the wiring tube? Does the tube go in the actual heater tube or alongside it covered by the outer rocker?
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Bobnotch
Bobnotch is offline
PostPosted: Sun Jan 28, 2024 1:34 pm    Post subject: Re: Went and got a notchback Reply with quote
Along side it. There should also be a "heat shield" between the heater tube and the wiring tube. The heat shield acts as an insulator for the heat tube, keeping the cool outer air from cooling the heated air.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Braukuche
PostPosted: Sun Jan 28, 2024 1:42 pm    Post subject: Re: Went and got a notchback Reply with quote
Thanks for the response Bob.
Does the heat shield attach to the lower inner rocker flange along with the outer rocker cover?
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Bobnotch
Bobnotch is offline
PostPosted: Sun Jan 28, 2024 3:36 pm    Post subject: Re: Went and got a notchback Reply with quote
Yes, it attaches to the heat tube top and bottom via tabs that are tack welded in place.
Tram wrote:
Tram wrote:
Braukuche
PostPosted: Sun Jan 28, 2024 7:52 pm    Post subject: Re: Went and got a notchback Reply with quote
Been thinking for quite a few weeks how to alter the late model heater channel to look more like an early one and came up with this.
I installed the late channel, fully welding the section in behind the kick panel and tacking the front section in after I cut the forward heater vent section out.
I used a vent piece ISP sells that looks like the early one more or less.
Luckily whoever hacked out the old one left a fragment of the original so I was able to locate the new vent, which is important as the carpet kit has openings in it that much match up.
I had to make some bends in the vent piece to allow for the cover to slide on and fab a piece to receive the cover attached to the top of the heater channel. I then had to cut out the stepped section to make a flat angled inset for the cover to retract on when open.
I then was ready to attack the rest of the channel to make it look more correct. I used a tool to get the proper angle and then cut down the length of the channel on the top step. I then bent in the step so when I pushed the panel in to the proper angle it would but up against the top of the channel which I also had to bend out using at slapped and a hammer. I then got in a few tack welds before it got too late. Tomorrow I will finish the welding. With carpet in it it should look correct.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Erik G
Erik G is offline
PostPosted: Mon Jan 29, 2024 4:03 pm    Post subject: Re: Went and got a notchback Reply with quote
Good work. As a heads up, since you mentioned it, the carpet always has the wrong vent placement the first 3 times you order it, so you may want to order now so it's in the correct place a few tries down the line. BTDT
Braukuche
PostPosted: Wed Jan 31, 2024 9:07 pm    Post subject: Re: Went and got a notchback Reply with quote
Pretty much finished up the pan. Have a few more items to adjust, hook up, but the bulk of it is done. I chose a stock look, but am going with the 12 volt alternator and 12 volt with six volt pinion gear high torque starter. I plan on driving this thing long distance, so want reliability.
Discovered that I am missing a thermostat type device that goes between the heat riser on the box and the intake manifold. Of anyone has one let me know. I’m in the market!
Finished up the heater channel, tried to get a better picture so you can see the new angle of the ISP heater channel. Did some more patching on the outer quarter wall. Have to wait for the rocker to finish it off so I will keep moving on.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
HenrikL
HenrikL is offline
PostPosted: Thu Feb 01, 2024 1:11 am    Post subject: Re: Went and got a notchback Reply with quote
Please report how the starter works. I bought a starter with the same specification (not sure if same brand) and it us unusable....
The problem is that te starter is not machined the same way as a stock starter and does not get locked into position by the gearbox. Before I tighten the two nut I can move the starter a few milimeters. This is enough to make the starter gear out of position and bang on the flywheel instead of engage.
When the starter spin the engine it is great (very powerful), but when you only get a "bang" on the flywheel it is not so fun.
Braukuche
PostPosted: Thu Feb 01, 2024 8:39 am    Post subject: Re: Went and got a notchback Reply with quote
It is a WOSP brand unit. I have one in my 59 Bus. It works fine. I know a lot of Porsche 356 guys use these on 12v conversions, I will check out there and see if they have had issues.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
ibjack
ibjack is offline
PostPosted: Thu Feb 01, 2024 6:10 pm    Post subject: Re: Went and got a notchback Reply with quote
Great progress Dan!
'68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074
Braukuche
PostPosted: Thu Feb 01, 2024 9:21 pm    Post subject: Re: Went and got a notchback Reply with quote
ibjack wrote:
Great progress Dan!
Thanks Jack.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Braukuche
PostPosted: Wed Feb 07, 2024 9:23 pm    Post subject: Re: Went and got a notchback Reply with quote
Finished most of the welding. What a PITA. But the body is solid as a tank now. I double walled welded it like original, so it feels all nice and stiff.
Finished modifying the other rocker so once carpeted it will look correct. Fixed a hole in the inner fender too. Later I used kitty hair over the welds to seal them.
Moving on to stripping the body starting with the roof which just had surface rust. The drivers side rocker remains unfinished until ISP mails me my outerrocker.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Bobnotch
Bobnotch is offline
PostPosted: Thu Feb 08, 2024 1:40 pm    Post subject: Re: Went and got a notchback Reply with quote
You're really going gangbusters on this project. I thought it was a "fill in project" while working on your bus. It looks like it's taken on a life of it's own now to be completed. I know how that goes though. Wink
It's coming along nicely, and you're making great progress on it.
Tram wrote:
Tram wrote:
ibjack
ibjack is offline
PostPosted: Fri Feb 09, 2024 9:23 am    Post subject: Re: Went and got a notchback Reply with quote
Dan is an "all in" type a guy like us Bob. Glad he's found fun and excitement with restoring type 3's.
the1500club.com
Braukuche
PostPosted: Fri Feb 09, 2024 9:36 am    Post subject: Re: Went and got a notchback Reply with quote
The bus has stalled because I got sidetracked on the Notch. I’ve built plenty of buses but never a Notch so the novelty of it I guess is drawing me in.
Yeah Jack I’m all in for sure, I think some people think I should be in the nuthouse due to my obsession.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Page 5 of 6
