BLAZE CUT fire system
yel-mel
yel-mel is offline
PostPosted: Wed Dec 27, 2023 12:24 pm    Post subject: BLAZE CUT fire system Reply with quote
I finally installed a fire suppression system from Blaze Cut. It was a bit tricky to get the hangers in place, but I think it turned out pretty clean.
I hope it works if I ever need it.
77kafer
77kafer is offline
PostPosted: Wed Dec 27, 2023 12:27 pm    Post subject: Re: BLAZE CUT fire system Reply with quote
LOOKS GOOD.
Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer"
Semper_Dad
Semper_Dad is offline
PostPosted: Wed Dec 27, 2023 4:11 pm    Post subject: Re: BLAZE CUT fire system Reply with quote
Nice install. But did it require drilling holes in the sheetmetal?
I'd like to see some design that mounts to the decklid that utilizes the slots in the decklid reinforcement panel. But then again, I'd worry about setting the thing off by slamming the decklid too hard.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
yel-mel
yel-mel is offline
PostPosted: Wed Dec 27, 2023 6:10 pm    Post subject: Re: BLAZE CUT fire system Reply with quote
Yes Semper it did require drilling into the sheet metal for the clamps, however I feel this is the best location. I basically followed how Gene Kisler set his up. Gene has a top notch Thing and some very good knowledge on the subject ( good guy too). A alternative mounting idea could use magnets if you did not want to drill. The problem is the BlazeCut tube is not very flexible and takes something strong to hold it in place once you bend.
Hot Rod Harp
Hot Rod Harp is offline
PostPosted: Sun Dec 31, 2023 2:06 pm    Post subject: Re: BLAZE CUT fire system Reply with quote
yel-mel
What size did you buy? 44" or 6 foot ?
Thank you
74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
RinTinTin in Waldorf Astoria 1956
yel-mel
yel-mel is offline
PostPosted: Tue Jan 02, 2024 8:48 am    Post subject: Re: BLAZE CUT fire system Reply with quote
6 foot fits perfect
colin_peggy
colin_peggy is offline
PostPosted: Wed Jan 03, 2024 10:28 am    Post subject: Re: BLAZE CUT fire system Reply with quote
FYI , I used eight rare earth magnets ( 100 # ) to hold my system in place 2000 miles and 18 months later it hasn’t moved. Plus no drilling.
yel-mel
yel-mel is offline
PostPosted: Wed Jan 03, 2024 1:26 pm    Post subject: Re: BLAZE CUT fire system Reply with quote
Wow....that's a strong magnet
colin_peggy
PostPosted: Wed Jan 03, 2024 3:05 pm    Post subject: Re: BLAZE CUT fire system Reply with quote
I think the rating is excessive for what it actually is but don’t get your skin between the magnet and the metal
phillything
phillything is offline
PostPosted: Fri Jun 20, 2025 10:19 am    Post subject: Re: BLAZE CUT fire system Reply with quote
Hey colin_peggy (and others), I just put in my blaze cut using 100# rare earth magnets and clamps.. seems pretty solid and required no drilling through the car. It's pretty close to the fan shroud (but not touching)..
Anyone see any reason why I SHOULD NOT run like this?
Thanks
colin_peggy
PostPosted: Fri Jun 20, 2025 7:02 pm    Post subject: Re: BLAZE CUT fire system Reply with quote
Looks almost exactly like my installation and it’s been in place for several years and 5,000 miles . Haven’t moved with those magnets . As you said “ no drilling” .
doublecanister
doublecanister is offline
PostPosted: Wed Jun 25, 2025 5:58 am    Post subject: Re: BLAZE CUT fire system Reply with quote
I did the decklid mount with magnets back in 2021, at the time I had hand surgery and was no way I could do this easily uncoiled, these blazecuts are rather stiff items, but this is "right outta the box" mounted. So far so good.
There was some questions about it where it was mounted but I believe a fire in the engine compartment with this on the lid or the 'roof' should still melt and do it's job.
Used magnets with 'gorilla tape' on the back to avoid paint scratches, and used 2 of the existing bolt/nuts for the license plate light I believe as extra mounts. It's sturdy, even slamming the lid with my phone recording video inside engine compartment showed it missing everything so - so far so good.
And I angled the gauge for easy read with lid open and it's fairly easy to remove if needed.
Hope this helps,
T
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Thu Jul 31, 2025 7:31 pm    Post subject: Re: BLAZE CUT fire system Reply with quote
No issue with the mounting method ... using rare earth magnets is a great idea. However the position of the BlazeCut isn't really optimal. Most of the tubing is forward of the shroud and the ends curve forward right where a fire would likely be centered. Yes, a fire centered around the fuel pump and carb would eventually trigger the BlazeCut, but not as quickly as it would if the tubing was directly above those items ... and every second counts with an engine fire. I would either flip it so the center of the tube is over the carb, or mount the ends so they bypass each other over the carb. Just my my 2 cents ...
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
