TomVaughan64 Samba Member
Joined: February 02, 2023 Posts: 56 Location: California
Posted: Mon Jan 29, 2024 7:57 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
esde wrote: |
Tom, the post you quoted is my exact experience with POR15, but don't try to tell the followers. Guys that love POR just won't listen..
Soaking will do the job, I watched a YouTube video where a guy literally dunked an entire car in a tub he made from plastic and pallets. Afterwards when he was getting into some places he missed, he found the rust in the blind cavities was well treated. I'll try to find the link, as I forget what brand sauce he used. I haven't tried the Rust911, though I have used the Evaporust and Ospho, and I have a tank set up for electrolytic rust removal. Thats another fun rabbit hole to go down, though your family will panic that you're about to blow the house up..
Great work so far |
Yeah, at the moment I am thinking of trying to make a "bathtub type" soaking container out of conduit and plastic for the chassis. That would be pretty wild to make one for a whole car. Can't imagine what my neighbors would think if I made something like that. _________________ Tom
"Begin with the end in mind"
Stephen Covey
"Keep focused and seeking knowledge, you will never find disappointed, only small hiccups!"
Jimbo
56 Old Speed Euro Deville Influenced Build |
Posted: Mon Jan 29, 2024 8:07 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
j-sou wrote: |
I bought a set of 12/55 KPZ 356 wheels |
That seems like a pretty amazing set of early KPZs. _________________ Tom
Stephen Covey
Jimbo
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Thu Feb 01, 2024 3:01 am Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
TomVaughan64 wrote: |
Reading Jason's build threads are really educational. His work is incredible.
Here is a quote, from Jason, that caught my attention:
"My goal with every restoration that comes to me is to open up as many blind cavities as possible/justifiable and remove all collision damage, rust and subpar repairs before the blasting and primer is achieved."
1. As per Jason, I would open up as many blind cavities as possible and remove all collision damage, rust and subpar repairs. Looking at Floyd, I would have roughly straightened the doors, fenders, hood, and decklid and mounted them with the running boards, Hopefully, this would have allowed me to fix the three bumper mounts that have accident damage. Next, I would have taken out the front firewall and spare tire tray. Also, I would have removed the outer skin of the rear driver's quarter panel and heater channels (after bracing) prior to mechanical stripping and media blasting. I missed this step. I will do all of these things and media blast the cavities before taking down my plastic booth. This is one of the disadvantages of the Gibbs. All of the dust from the media blasting is going to stick to the oily car. I will have to wipe it down with Gibbs again to remove all of the dust. This will cost me 3 to 5 hours because I did the steps out of order. Not too bad considering the overall hours of the project.
2. Mechanically strip the body. Get an 80-grit texture on everything possible.
3. Media blast everything that I could not mechanically strip.
I agree with all of that, it's a great plan. With your car stripped down to the whitey titeys I think it's safe to say now that you've got a great car to start with, considering its age!
I've had really great experience with Summit Racing epoxy primers - they stick and are exceptionally hard when cured. Their urethane filler primer is also good. Not so much their single stage top coats, which tend to chip a lot when handled.
Since I don't know what your welding experience and plans are, I'll just mention this.. most of the body was spot welded. If you're going for OG, spot welders aren't terribly expensive, but get a 240V version, not 120V. There's a seller on ebay called tips 'n' tongs that can custom make the copper jaws for you if you need a special angle.. I ordered their XL tongs for my spot welder to reach in and weld the pans to the tunnel, but due to limitations on the welder power, I could only use it to spot weld the rear of the pans to the cross braces. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Sat Feb 03, 2024 6:24 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
Funny you should mention spot welding. I happen to be looking into that right now. I am trying to figure out what to order (if anything) and what I will or will not be able to do. I am not sure what I am going to do here. I am still looking into the possibilities. Any feed back or experience with spot welding would be appreciated.
My pans have already been welded by the pervious owner. Assuming they are on correctly, I will not be welding pans on this project. However, during my research, it seems like factory like spot welds, on the pan, may require more current and bigger machines than i could afford or fit in my shop.
Washburn Metals seems to be well known for their pan installations and they use a really big spot welder.
Here are a couple of pictures from the Washburn Metals Instagram page @washburnsmetal :
Here is another video I found here on The Samba:
Perhaps some one can let me know if it is possible to adequately spot weld pans with 230 volt current, or is it just better to plug weld this part.
Earlier in this tread I introduced a video of a VW Bug restoration VW Kafer Full Body Restoration. According to his answer in the comments, the gentleman in the video was using a "Telwin Modular Digital 400 2+2 millimeter 380 V with 16 A":
Here is what that Spot welder looks like:
I do not have 400V service in my shop that this spot welder requires.
There are several examples of what look like this same welder in a 230V model. They all seem to be exactly the same spot welder as the Telwin 230V spot welder. The specs and operating instructions seem to be the same. The other models that I found were Sealy and HTP.
HTP has the lowest price. I am hoping it is the same model as the others. The specs state that you can weld 2.0 + 2.0 mm. My interpretation of this is that I could max out with this spot welder at trying to attach two 14-gauge pieces of sheet metal.
Here is a link HTP America Quick Spot II spot welder web site
https://usaweld.com/collections/htp-america-quick-spot-ii/products/quick_spot_ii
HTP has a good video on this spot welders performance:
Thank you for any feedback you can give me here. _________________ Tom
Stephen Covey
Jimbo
grailoc Samba Member
Joined: March 25, 2004 Posts: 1441 Location: FRANCE and now QUEBEC city
Posted: Sat Feb 03, 2024 9:50 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
grailoc wrote: |
I bought the HTP spot welder during black friday.
it is in fact the TELWIN Italian made brand so I was happy about the purchase I made |
That is great to know! I thought that was the case but it is good to know it is the same. _________________ Tom
Stephen Covey
Jimbo
Posted: Thu Feb 08, 2024 6:15 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
I have some personal experience using a handheld Harbor Freight 240V spot welder. It will work well for a lot of areas but you’ll be limited by the tongs, so I’d suggest looking around for tong options. What I’ve found is the small handheld spotters just don’t have the amperage to adequately weld thick metal. I think the HF spotter will weld the two halves of the tunnel together, but it would not be able to weld pans onto those two halves.
Those shops doing excellent restoration level work are a great inspiration! If you can’t see how it’s supposed to be done, then you’ll never really know what to shoot for on your own! For my 1967 beetle, I couldn’t justify the cost of a big spot welder just to do my pans, but I have the HF spotter for anything else I can reach, like the rear floor crossmembers. _________________ Robert in Memphis
esde Samba Member
Joined: October 20, 2007 Posts: 5971 Location: central rust belt
Posted: Thu Feb 08, 2024 7:02 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
I have used, and still occasionally use a spot welder. Installing seal channels for instance, you want the correct indentation that a spot welder leaves.
But most times, the tongs simply cannot get around to both sides. I have used a spot welder with giant hoop tongs to spot weld the supports to the inside of a bus long side wall, and it was a PITA even with three people. Cool, but not something I'm doing again unless it's the absolutely right project.
The large machines are sweet, but not practical for most people in the home shop.
Currently when doing rosette welds (what I prefer on floor pans) I use a Miller with a pulse setting. You can do a really fast hot rosette this way, that takes a few seconds to finish with a rol-loc disc. I use this machine for most everything, and save the spot welder for when appearances matter.
FYI, I have 2 spot welders, a 40 year old 220 miller, and a fairly new 220 harbor fright. They weigh the same, and are indistinguishable from one another. The HTP machine is intriguing but I haven't found any situation where my ghetto level machines won't do the job. _________________ modok wrote:
Posted: Fri Feb 09, 2024 8:58 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
scrivyscriv wrote: |
I have some personal experience using a handheld Harbor Freight 240V spot welder. It will work well for a lot of areas but you’ll be limited by the tongs, so I’d suggest looking around for tong options. |
esde wrote: |
FYI, I have 2 spot welders, a 40 year old 220 miller, and a fairly new 220 harbor fright. They weigh the same, and are indistinguishable from one another. The HTP machine is intriguing but I haven't found any situation where my ghetto level machines won't do the job. |
Thank you for the great feedback. I just ordered the Harbor Freight 240V spot welder. At $159, it is worth a try. It helps to know that this spot welder worked well for both of you. _________________ Tom
Stephen Covey
Jimbo
Posted: Sun Feb 11, 2024 9:31 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
I spent the past couple of weeks setting up and using Rust911 on my doors. It took a few times with my first door but I finally figured it out.
When soaking the doors the Rust911 leaves a black residue which I am still removing from the door on the right:
Here are a few before and after pictures of the rust on the inside of the door:
I am happy with the end result.
Here are the steps that I figured out through trial and error:
1. Mix 56 gallons of water with 3.5 gallons of Rust911 in a 70 gallon container
2. Soak first half of door until rust disappears (full door does not fit in my container)
3. Pull door and wash soaked part with soap and water
4. Dry door with towel
5. Finish drying with a heat gun
6. Spray Ospho in the impossible to reach areas (upper window frame)
7. Apply Gibbs to the rest of the soaked part of the door
8. Repeat steps 2 thru 9 on the second half of the door
9. Use Gibbs and a maroon Scotch-Brite sanding pad to remove the black residue.
I wanted to give an update on my experience using Gibbs. We had a strong storm with a lot of wind. Floyd's car cover was not secured very well and it blew away leaving Floyd out in the very heavy rain for about 3 hours. I finally got the shop cleared out so I could get Floyd out of the rain. There was some flash rust in a few areas that wiped off when I reapplied the Gibbs. Floyd has been in the shop all week and there is no new evidence of rust. This was a pretty good test. I never did find my car cover.
Next, I will continue to soak other rusty parts and fasteners.
Here is my rough drawing of a chassis rust removing soaking station that I am building:
I am making this out of 3/4-inch conduit, plastic, and velcro. There are six small sprinklers on the top and six on the bottom. There is also one sprinkler that can be moved anywhere, including inside the tunnel. The water and Rust911 solution comes out the bottom into a container that has a pump to push the solution back up into the sprinklers. I will update how the build of this station goes and how it works on my rusty chassis. _________________ Tom
Stephen Covey
Jimbo
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9978 Location: Huntington Beach, CA
Posted: Mon Feb 12, 2024 9:27 am Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
I made a plastic “pan” out of 2x4s laying flat on the floor. Then install 4 pieces of 1” plywood, each piece cut to a triangle, to form a point meeting in the very center of the rectangle. Installed each plywood triangle onto the 2x4 base and allowed them all to rest on the concrete floor in the center. This giving me a 1 to 5 slop to the center. Then another round of 2x4s, screwed together standing on their small edge, attached to the base 2x4s from the previous rectangle, to circle the car. Then I took some 6mil plastic sheeting and with a cut off sheet, rolled it over the 2x4 edge and stapled to the outside curb. Rolled the Bug body onto the plastic. Then a few lengths of PVC tubing to form a small rectangular above the top of the car, hovering about 6inches off of the surface. Then from the ceiling, attached eyelets and dropped T bar ties. Twisted them around the PVC. Followed that up with another full sheet to fully cover the car and to keep the “juice” in the pan. Dropped my small sump pump into the center of the sloped floor, ran a flexible line up to the top of the Bug and installed a garden sprinkler, full 360. Poured in 5 gallons of Ospho. Turned on the pump! Viola, Ospho bath for several hours. When that was finished I moved the sprinkler into the interior. Sprinkler hit the roof and the liquid would follow that down and around into the inner black holes, just like water, hitting all the nasty parts. That was another 4 hour run. Rotated the body upside down and filled the top with the Ospho. Sloshed it around now and again for a day. Once done, I rolled it outside and squirted water into every nook and cranny for a few hours. Rolled it back into the garage after dripping for a while. Took a small Propane heater and allowed it to dry out. Poured some epoxy primer into the top and sloshed it around, then rolled it slowly, side to side and rollered the primer as best I could as it poured out. The remainder landed on the plastic floor, still in place with no sump. Off to the blaster after that! That was my experience with a Bug from several years ago!
In the 54, I used a garden sprayer full of Ospho and a plastic floor! Way less work. Worked just as good. I modified the wand to spray out a drip system sprayer head, full 360! Worked great! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Mon Feb 12, 2024 10:03 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
VW_Jimbo wrote: |
In the 54, I used a garden sprayer full of Ospho and a plastic floor! Way less work. Worked just as good. I modified the wand to spray out a drip system sprayer head, full 360! Worked great! |
Great write up on the soaking booth you built for your previous car. I feel like I can see pretty clearly what you built based on your description.
I followed your advice on getting a commercial sprayer for spraying Ospho on and into the body. I have been thinking about a way to add a flexible tube with a radial sprayer at the end just like you describe. However, I could not find a small radial sprayer head until you mentioned a drip system head. I found these on Amazon. Is this more or less what you are talking about?
I am also looking for a way to spray the inside of my chassis tunnel with some Master Series, which you have mentioned a few times in the past.
This is a great video testing different rust encapsulating paints. Master Series ranked really well. Unfortunately, since this video came out the Master Series paints are sold out.
Stephen Covey
Jimbo
Posted: Tue Feb 13, 2024 11:20 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
I soaked the front beam in the Rust911 solution. If you look closely at the bottom right, you can see part of the front beam:
Here is what the beam looked like prior to soaking. This beam was already media blasted. This seems to mostly be surface rust:
Here is what it looks like when in comes out of the soaking tub (notice the black residue):
After a hour of scrubbing with Gibbs and a maroon Scotch-Brite pad:
This is probably a little boring, but these are details I wish I would have know before I started this restoration. Hopefully this helps someone to move in a straighter, faster line. _________________ Tom
Stephen Covey
Jimbo
VWGlassee Samba Member
Joined: November 06, 2012 Posts: 78 Location: Belgium
Posted: Wed Feb 14, 2024 4:17 am Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
Not boring at all! It can be a great help for others. And it is fun to see the progress on your build
Keep up the good work!
Yannick |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2180 Location: Graz, Austria, Europe
Posted: Wed Feb 14, 2024 4:51 am Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
Your methods of getting everything bare metal works great for getting beautiful pictures.the parts look great and to be in good shape, generally speaking.
I am not 100% sure though how your procedure is going to be with that much bare metal around. I understand you are using the GIBBS oil for protection, and while that may work well, by now you already have it in every crease, seam, gap, inside out. So my thoughts, according to your way of doing it. You will either have to work with an extremely diligent paint shop, powder coater, primer dip or what not, as they NEED to understand your method of cleaning and protection. your parts will have to be degreased, and wax removed, primered, seam sealed with as much diligence as you put in all the paint and rust removal. Remember that originally the whole body, as a unit, was primer dipped in a tank, and VW provided drain holes all over the body and pan, so that excessive primer could get into and out of cavities.
I get your claim on 100% clean metal top quality resto like in a pro/pro/PRO shop (if there is any with your standards), but you may have to live up to your standards and do all the seam cleaning, soaking with primer, painting/dipping all the inner areas of the body, BY YOURSELF at this point. I am not sure if even a great body/paint shop will be able to fill all your needs ( and all the bare metal and oiled seams and gaps that is). JMHO.
I am sure you are way ahead my thoughts and already have your plans staked.
(edit. Personally I tend to get things into high quality epoxy primer and paint asap after blasting or sanding. The front axle would be a great candidate for KTL dipping and powdercoating ( high quality 2 step primer/finish) ) _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Wed Feb 14, 2024 9:29 am Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
VW_Jimbo wrote: |
That would be one of many choices to choose from. I am at Home Depot everyday, buying materials for work, so grabbing stuff from them is super easy and the business pays for it! The head I used had an adjustable distance knob. I turned it up to about medium, so that the inside was drowned in Ospho. I ran my borescope up into a few of the cavities and could see full coverage!
I do not use Master Series. Not a fan, although there are many. I like Eastwood’s interior frame coating that comes with a tube, the sprayer head and a can of the product. Good stuff. But in lieu of that I poured a quart of thinned down epoxy primer along the roofs outer frame work and roll the fluid into it by rotating the Bug. I then rolled it back and forth several times to try and hit all of the inside. Once dried. I again used the borescope to check out the coverage and had to go back and reapply a few times! Hope that all helps you out! _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Feb 14, 2024 8:37 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
VWGlassee wrote: |
Yannick |
Thank you for the nice comment and thank you for following along _________________ Tom
Stephen Covey
Jimbo
Posted: Wed Feb 14, 2024 9:27 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
djfordmanjack wrote: |
(edit. Personally I tend to get things into high quality epoxy primer and paint asap after blasting or sanding. The front axle would be a great candidate for KTL dipping and powdercoating ( high quality 2 step primer/finish) ) |
Thank you for all of your thoughts on my project. I am really happy to get other people's opinions.
First let me be clear that I do not really know what I am doing as this is my first time with a full restoration. I have settled on using the GIBBS because I am very interested in doing extensive metal work on almost all of the sheetmetal. I especially like my experience so far with the shrinking disk. This disk does not like to be used on epoxy. I would have to remove all of it at least on the side that I am using the disk. This seems like a lot more sanding than I want to do.
I am doing this restoration to experience as many of the parts of the restoration as possible. I am planning on trying to paint the car myself. I am not expecting to be able to match the pros but I am willing to put in the effort. For example, I am planning on injecting EvapoRust or Ospho into all of the seams I can reach with a hypodermic needle and seam sealing both sides of the seam as mentioned earlier in the thread.
I definitely agree about painting or powder coating the front beam as i am not planning on metal working the beam. However, I do not currently have any painting equipment or knowledge on what to buy. Also, my media blasting and stripping booth needs to be modified to be used for painting. I am trying to do things a step at a time with stripping everything being my main focus now and then I will put that equipment away in storage to give me room for the next step.
I current have 4 other project VWs sitting on my driveway waiting their turn. With this first restoration, I am build out the infrastructure so that when I get to my next restoration I may be able to follow a different path like painting the front beam at this point in the process. My shop is small. This means I cannot keep that soaking tub in there. I need to put everything I can into it now and then empty it out and put the tub in storage. I am hoping that the GIBBS will keep the front beam from rusting until I can get the knowledge, tools and infrastructure in place to do the painting.
So far I really like how easy it is to use GIBBS. I am hoping it works out over the long term. I will continue to give my feedback on using it so others can learn from my mistakes and my successes. _________________ Tom
Stephen Covey
Jimbo
Posted: Wed Feb 14, 2024 9:39 pm Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
VW_Jimbo wrote: |
I do not use Master Series. Not a fan, although there are many. I like Eastwood’s interior frame coating that comes with a tube, the sprayer head and a can of the product. Good stuff. But in lieu of that I poured a quart of thinned down epoxy primer along the roofs outer frame work and roll the fluid into it by rotating the Bug. I then rolled it back and forth several times to try and hit all of the inside. Once dried. I again used the borescope to check out the coverage and had to go back and reapply a few times! Hope that all helps you out! |
Thank you for the great information!
I did buy this last night. I thought it was inexpensive enough to give it a try.
I also purchased some drip sprinkler heads to try out.
Sorry for the misquote about the Master Series. My memory is not as good as it used to be. _________________ Tom
Stephen Covey
Jimbo
Posted: Thu Feb 15, 2024 3:47 am Post subject: Re: 56 Old Speed Euro DeVille Influenced Build |
Tom, seeing what and how you achieved it so far, I think you are a perfectionist and artist and great craftsman. You will get to learn all the trades one after another as you see need. I get that.
There are many different ways to approach a project build. and we have to make do with the space and tools we have. you already exceeded 95% of hobby builders with your shop rebuild and dust curtains... so I have no doubt this Oval is going to be spectacular. absolutely second your thoughts on metalworking, which most often only works well on bare metal.
Personally I try to find build stages. like cutting rust out and do repairs on roughly cleaned parts ( blasted or sanded only at the repair places). This may well take 1, 2, 3 or even more steps of going back and forth with cleaning, blasting, soaking, welding, sanding, hammering, seam sealing, metal shaping aso. You can do all the metal prep work before as you do, but it is not a must. and it sometimes will cause you extra work.
Personally I like to only take a part down bare metal, or have it chemically cleaned, blasted or KTL coated, when metalwork on it is completely finished. That way you end up with a most homogeneous prep and paint build up.
When I talk about 'seam sealing' I do not actually mean caulk or automotive seam sealer that you put 'on top' of spot welded joints. I talk about soaking the overlap seams, creases, cavities, with thinned out epoxy primer, metal prep, or whatever you see fit and works well for you. My tip is I am always using the same kind of quality automotive primer from my local shop. Its used in heavy machinery equipment and trucks and steel construction. A quality industrial product. Have been using for 25 years now. I did experiments with exposing painted metal sheets to sun, rain, bending, hammering aso for a year or more. Similar to what the repair geek guy doing in his test video. Found the perfect primer. it comes as a 2K epoxy and they also fill it as 1k in paint cans ( for touch up). the 1k isn't as UV resistant, but otherwise the rust inhibiting pigments are the same. I use different spray nozzles with extended wands, fe. 3 or 4 inch plastic tubes added, flattened , what not. then I will 'pressure' feed a factory spot weld overlap with such a nozzle, directly from the spray can. The primer is very thin, and will be pushed into the overlap/seam by can pressure. you may want to try and experiment with that. Usually the primer will bleed through on the other side of the overlap, or try working both sides if accessible. I never use weld through primer. don't like it. it always splatters with TIG or MIG. it's better suited to spot welding but you need a strong machine with high amperes.
The way I am using thinned out primer, either from the can, or 2K, shoving and soaking with a brush, or both. then wiping off excessive stuff, you will get very well covered seams and cavities, BEFORE you even put on primer on the sheet metal surface or actual 'automotive' seam sealer.
you can also 'seam seal' parts before sandblasting. the blasting media will not get into the overlap. and not remove the primer. Filling the seams with primer before blasting will also keep it from being filled up with media ( sand would later on tend to soak water and will rust the cavities/seams even worse).
Looking forward to follow your project along,
regards from Europe
Günter
Your methods of getting everything bare metal works |
So far I really like how easy it is to use GIBBS. I am hoping it works out over the long term. I will continue to give my feedback on using it so others can learn from my mistakes and my successes. |
