raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21551 Location: Oklahoma City
Posted: Thu Jan 25, 2024 2:49 pm Post subject: Re: D Jet hardware on a bigger engine |
Sorry I did not not get into this answer. As KTPHIL notes....the limiting factor is going to be airflow.
The 1.7L stock injectors can handle 1.8L no issues. Same overall volume per hour. The 2.0L injector from the 914 is only really different in the fact that it can support more pulsewidth. The pintle and flow rate is pretty much the same as the 1.7L.
The stock 1.7L runners, TB and plenum work fine to 1.8L. After that and even with certain versions of 1.7L and 1.8L (with better tuning, cam, valves and exhaust)....it can help to put a 2.0L bus TB on either the 1.7L or 1.8L when running 1.7L plenum and runners.
You can get away with 1.7L runners right up to about 2.0 to 2.1L....but you should have the later 2.0L bus TB and probably the bus 2.0 plenum. A full 1.7L intake set up....runners, plenum and TB will be too restricted.
And you are wise to use aftermarket EFI. The problem with D-jet with making significant changes in size and swapping around manifold components is that it greatly screws with the vacuum signature....which really screws with the MPS and fuel tuning. Aftermarket EFI only uses map as a secondary data point and not the main data point for tuning.
Ray |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34087 Location: Conejo Valley, CA
Posted: Thu Jan 25, 2024 2:16 pm Post subject: Re: D Jet hardware on a bigger engine |
I think the real limit (especially if you go programmable EFI) is what your question specifies... airflow.
On my Type 3, the practical limit is 1.8l, given the small intake tubes. Type 4 tubes look larger and could probably handle 1.9l without trouble.
But I'm just guessing... I bet it's been done. Maybe ask in the Performance Forum? Buses might have been upgraded and you wont' find their answers in the forum. |
Vanagonsgoslow Samba Member
Joined: April 18, 2019 Posts: 87 Location: E Dorado Hills, CA
Posted: Thu Jan 25, 2024 1:01 pm Post subject: Re: D Jet hardware on a bigger engine |
The standard 1.7 Djet FI system can probably handle an increase to 1911cc fine on a street car. If it's running lean, you can probably upgrade to 2 liter size fuel injectors. An adjustment to the MPS unit might also be needed for best performance. |
412le Samba Member
Joined: June 09, 2019 Posts: 1 Location: Denmark / Europe
Posted: Tue Jan 09, 2024 5:17 am Post subject: D Jet hardware on a bigger engine |
Is anyone having experience with the capacity of the 1,7 W engine throttle, plenum and intake tubes.
I am thinking about a 1,9 66/96 engine with 1,8 AN 85HP cylinder heads and with a programmable EFI
Cam will be standard W
Hardware from the old W engine will be reused.
As it is an automatic, max rpm will be appr. 5000
Has anyone tried something similar, and do they have some experience to share ? |
