Barking Squirrel Samba Member
Joined: April 28, 2023 Posts: 73 Location: Halifax, Nova Scotia Canada
Posted: Fri Feb 02, 2024 9:21 am Post subject: Remove Heater box wrapped over exhaust? |
Hey Samba Folks.
Looking for advice on what to do with the heater/exhaust on the 1980 air cooled Matilda.
I have removed the auxiliary heater and supply parts from the engine. CO2 leaks, fire, stuck flaps, etc made it a necessary choice to remove as it was 43 years old and suspect.
Curious what to do with the remaining heater exchangers around the exhaust. Leave them? Remove the outside sleeve and let the exhaust breath?
What would you do?
Thanks Paul
_________________ 1980 Vanagon L 235k, Dual Carbs, "Mattie". Air Cooled. |
zerotofifty Samba Member
Posted: Fri Feb 02, 2024 10:54 am Post subject: Re: Remove Heater box wrapped over exhaust? |
The heater shroud on the pipes are needed to keep the heads cool on VWs. If you remove them, you should add shielding. But why remove them, if you fear exhaust gases in the cab, dont use them, but leave them in place. If you have an exhaust leak, well you should fix it by replacing with better units.
Did you gasoline heater actually catch fire, actually pump CO (CO2?) into the cabin, or was it you suspect it might?
Anyway ripping of the shrouding is not good for the engine. the shrouding blocks radiant heat from cooking the heads, and air flow thru them also blocks heat. the air flows thru them even when heater is off. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
Posted: Fri Feb 02, 2024 11:14 pm Post subject: Re: Remove Heater box wrapped over exhaust? |
Thanks for the wisdom. I will be leaving the jackets on. _________________ 1980 Vanagon L 235k, Dual Carbs, "Mattie". Air Cooled. |
Xevin  Samba Member
Posted: Sat Feb 03, 2024 6:37 am Post subject: Re: Remove Heater box wrapped over exhaust? |
Was the heater a Ba6 under the car style or Ba4 torpedo style in the engine bay you removed? _________________ Keep on Busin'
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
| Clatter wrote: |
Damn that Xevin...  |
| skills@eurocarsplus wrote: |
| SGKent wrote: |
Posted: Sat Feb 03, 2024 12:26 pm Post subject: Re: Remove Heater box wrapped over exhaust? |
That thing in your last photo, with the domed metal cover is the heater valve. The heater control cable is hooked to it. When heat is on that valve directs the flowing air into the cabin, when heat is off, the flowing air is directed out from under the dome, bleeding out under the car, hence there should ALWAYS be air flowing thru the heater exchanger boxes when engine is running, this assumes they are hooked up correctly to the fan house. In addition to the fan house supplied air (fan powered by crank shaft) there is the auxiliary electric booster fan in the engine bay. This fan need not be on for air flow when heater is in off position. HOWEVER, the electric fan should have one way check valves on its ports (flaps) that only open when electric fan is running, and seal when electric fan is off. This in combination with sealed plastic or paper hoses from electric fan to the heater exchanger boxes are NEEDED to...1 Keep the air flowing thru the heater boxes, and 2... Keep the hot air from going into the engine bay, which will in effect preheat the engine cooling air (bad!!!) So make sure all your heater hoses and those electric fan check valves are in place and sealed correctly. As this does affect your engine temperature and the longevity of the heater boxes. This is IMPORTANT!!! _________________ Sorry About That Chief.
Words to live by. |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1706 Location: The Old Pueblo
Posted: Sat Feb 03, 2024 4:16 pm Post subject: Re: Remove Heater box wrapped over exhaust? |
no hoses so their inoperable. Gonna have some cold nova scotia air blowing through your heater ducts unless you capped off the ports for the heater hose. Im curious to see what the hell else you might be cancelling. Those motors are highly dependent on the ducting of cool air around the heads and deflecting hot air is part of that equation. you can go from a hot dog to a boat anchor in 100 miles of hilly terrain. Faster than one can say "dropped valve seat". _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Sat Feb 03, 2024 4:33 pm Post subject: Re: Remove Heater box wrapped over exhaust? |
| AZ Landshaper wrote: |
| no hoses so their inoperable. Gonna have some cold nova scotia air blowing through your heater ducts unless you capped off the ports for the heater hose. Im curious to see what the hell else you might be cancelling. Those motors are highly dependent on the ducting of cool air around the heads and deflecting hot air is part of that equation. you can go from a hot dog to a boat anchor in 100 miles of hilly terrain. Faster than one can say "dropped valve seat". |
The lack of the hose from the heat exchanger valve to the body ducts as shown in the photo is not an engine cooling issue, but yes, it will allow cold air to migrate into the cabin, AND is a great way for mice to enter and set up a nest (stinky horrible mess). The hoses that if missing or leaky that cause engine excess heat are the ones between the heat exchangers and the electric engine bay fan. If missing or leaky or if the flaps in the electric fan are not sealing, then hot air will be drawn into the engine bay. Not good for engine cooling. There also flaps in the engine fan shroud that I forgot to mention, these are located where the fan shroud connects to the metal ducts that supply the heat exchangers with cool air from the crank driven fan. They prevent back streaming of hot air into the engine cooling system, notably when the electric fan is operating and engine driven fan is at low rpm.
All this stuff needs to be present and in good order to prevent hot air from over heating the engine, radiant heat from exhaust cooking the heads, and to protect the heat exchangers from being heat damaged. Of course having a working heater is important not only for comfort, but also for safety in regards to defogging the windshield. _________________ Sorry About That Chief.
Words to live by. |
Posted: Tue Feb 06, 2024 5:22 am Post subject: Re: Remove Heater box wrapped over exhaust? |
Thanks for all the thoughts.
There was an axillary heater under the van that was rusted out and disconnected by PO and myself. Most of the flaps, cables from the exhaust heat exchangers were rusted with holes and are removed. All ports that could allow cold air into the van have been sealed.
We have installed a Webasto Heater that provides hot air into the living space and to the dash blower should we need heat while driving and clearing the windshield. All engine tin and cooling flaps are in place and working.
My concern was around whether to keep air flowing through the heater boxes and not going into the engine bay since I am missing the "Heater Flap or Heater Control Valve (as Zerotofifty mentioned)" on the drivers side.
As AZ said. "hot dog to a boat anchor"
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19162 Location: Retired South Florida
Posted: Tue Feb 06, 2024 2:55 pm Post subject: Re: Remove Heater box wrapped over exhaust? |
I am going to offer an alternate point of view. In this picture you can see the fresh air duct from the blower on the alternator to both heat exchangers. Not my photo.
The question I read is "is it ok to remove the "cans" aound the heat exchangers? I would say yes it is. There is no reason the engine would run hotter. If the above duct work is missing, I would cap the tin work so no exhaust heat can work it's way up from the exhaust.
In theory, the alternator blower would move cool air across the heat exchangers cooling them, but without the blower, they are running hot anyway. If you removed the cans around the heat exchangers I believe you will find cast fins that could remove heat when exposed to moving air.
I don't think its going to make the engine run hotter. An example would be removing the heat exchangers and running header tubes. This was common on earlier air cooled VW's
[/img][/url] |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2688 Location: Southeast Kentucky
Posted: Tue Feb 06, 2024 3:29 pm Post subject: Re: Remove Heater box wrapped over exhaust? |
Yeah, that engine looks just like the one in my 83 Air-cool.
I wouldn't have second thoughts about using the heat system on it's manifolds. The air-valve boxes have rubber gaskets that dry-rot and fall out. This is not necessarily a problem unless you don't like heat in the summer..LOL.
I agree with Mark, removing the tin around the heat exchargers is not going to affect the engine over-heating. What's far more important is whether or not the proper cooling tin is in place, functional air control flaps and an operational the Thermostat, as well as the rubber seal around the outside of the engine tin.
I'd address the heat exchanger system and restore it to it's original condition and purpose.
Side note: All Air-cool VWs from 1960 (and maybe earlier) that I am aware of were designed for air to flow through the heat exchanges in or out of heating mode. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Posted: Tue Feb 06, 2024 4:27 pm Post subject: Re: Remove Heater box wrapped over exhaust? |
Thanks Andy and Mark. Very very helpful.
Mark, I have the same set up as your photo. All the piping is in place to allow the alternator fan to push cool air through the horizontal tube to the heat exchangers.
A few thoughts:
I suppose if the Heater Flaps are missing on the drivers side, the front end of the heat exchanger is open and therefore could allow air to be pushed (at highway speeds) in the opposite direction through heat exchanges and against the flow of the fan. That is a bad scenario. Hence your suggestion of "capping the tin".
Also I suppose replacing the heater flap or capping it wouldn't allow any air to flow across the heater exchangers, and therefore the exhaust would be like another time when the original heater was installed but not on: the flaps would be closed.
However, Andy, in your post, I am unclear if the flaps are closed, like when the original heating system was turned off at the dash, how any air could pass through the exchangers?
Just thinking....
I do like the idea of removing the tin around the heat exchangers so it behaves like the older style header tubes of previous years air cooled engines. So long as my engine seal, tin and flaps are good and groovy. _________________ 1980 Vanagon L 235k, Dual Carbs, "Mattie". Air Cooled. |
Posted: Tue Feb 06, 2024 6:16 pm Post subject: Re: Remove Heater box wrapped over exhaust? |
Got your pm. If you have the alternator blower and ducting, I’d leave that as is. Having the far ends of the exchanger open or minus the flaps is not the end of the world. I’d be inclined to resurrect the heat exchanger system. That’s just me.
To add some history. Prior buses and bugs used the engine cooling fan to push heat across the heat exchangers. When ambient temp required heat in the van, it was ok to borrow some of the engine cooling air for heat. In higher ambient temp, you’d close the heater flaps and all cooling air was forced over the engine cooling fans. If the heater system had air leaks, you’d lose some engine cooling. The 72 on buses with the type 4 engine had an electric helper blower and the aluminum shroud had two tiny hidden flapper valves. Buses and bugs with the type 1 upright engine had cooling hoses coming off the shroud to the heat exchangers. It was not uncommon in warm climates to remove the hoses and cap the outlets on the shrouds.
The Vanagon heat was a redesign. When functional it does an ok job. My description above is an over simplification, but more of an overview. If you’re going to strip the cans off, there would be no advantage to maintaining the alternator blower and plastic ducts if you have them. I see wanted adds for members looking to buy good used ones. Makes changing the alternator and belt easier. |
Posted: Tue Feb 06, 2024 9:39 pm Post subject: Re: Remove Heater box wrapped over exhaust? |
| Barking Squirrel wrote: |
| Andy, in your post, I am unclear if the flaps are closed, like when the original heating system was turned off at the dash, how any air could pass through the exchangers? |
Sorry about the confusion...
The Air-cool Vanagon engine is equipped with a Thermostat (talking about the cooling air for the engine). The Thermostat opens the Flaps (one each side of the engine, up high) that are normally closed when the engine is cold, even in hot weather when the engine is first fired-up. The function is to allow the engine to warm-up quickly. It is entirely separate from the Heating system of this discussion, but is important, both for engine cooling and providing heat sooner when the ambient temp is cold. I mention this only because over-heating was mentioned previously.
The Valves at the end of each heat exchanger (Bentley also calls them Flaps) always allow air to pass thru regardless of their position (heat on or off). The purpose is to maintain cooling for the exchangers. Valves closed, the hot air is diverted out as others have stated previously. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
Posted: Tue Feb 06, 2024 11:51 pm Post subject: Re: Remove Heater box wrapped over exhaust? |
| MarkWard wrote: |
The air is always flowing through the heater exchangers when engine is on, even when heat is turned off. When turned off the air blown through the heater exchangers is dumped out under the van at the heater valve, rather than dumped into the van cabin as happens when the heat is turned on.
remove the heater exchanger covers and that airflow ceases, and now radiant heat from the heater exchangers radiates onto the engine heads. _________________ Sorry About That Chief.
Words to live by. |
Posted: Wed Feb 07, 2024 5:16 am Post subject: Re: Remove Heater box wrapped over exhaust? |
This is perfect. Didn't realize the Heater Valves dumped heat under the van when the interior controls are set to off. Explains how there can be flow through the heat exchangers at all times. Makes sense to me now.
I will replace the drivers heat exchanger with one that allows this to happen.
Thanks, _________________ 1980 Vanagon L 235k, Dual Carbs, "Mattie". Air Cooled. |
Posted: Wed Feb 07, 2024 5:38 am Post subject: Re: Remove Heater box wrapped over exhaust? |
Thanks, |
On my 83, it has a short "pipe" about 2 inches in diameter (52mm), on the valve box that points downward for the exhausting air. I added 12 to 14 inch extensions on each box to direct the air down and slightly below the bottom of the engine. This reduced the amount of hot air above the transmission as well as away from the engine. The big fan on the end of the engine creates vacuum inside the engine bay. So, it pulls in air from every direction, including around that not so tight fitting rubber seal around the outer edge of the engine tin. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
Posted: Wed Feb 07, 2024 6:05 am Post subject: Re: Remove Heater box wrapped over exhaust? |
| zerotofifty wrote: |
| MarkWard wrote: |
remove the heater exchanger covers and that airflow ceases, and now radiant heat from the heater exchangers radiates onto the engine heads. |
I think we are saying the same thing. For the air cooled Type 1 engine and the Type 4 engine I agree. The air flow is from the engine driven blower across the cooling fins and the heat exchangers. The vanagon changed the method. All air from the engine driven blower is directed over the engine cooling fins. In addition, VW added the small belt driven blower and ducting to the alternator shaft. Its been many years, but I'm 90% positive only air from the Alternator blower is going across the heat exchangers in the vanagon engine setup. |
Posted: Wed Feb 07, 2024 6:27 am Post subject: Re: Remove Heater box wrapped over exhaust? |
| MarkWard wrote: |
Mark, you are 100% correct. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
pathao Samba Member
Joined: November 01, 2012 Posts: 340 Location: Montreal, Canada
Posted: Wed Feb 07, 2024 8:11 am Post subject: Re: Remove Heater box wrapped over exhaust? |
That last photo brought me back to memories' lane (that is one of mine) and made me realize that I'm late to the show.
To keep it simple
What would you do?
I would keep them (cause of radiant heat to the valves covers). Like it been said, make sure the air circulate/flows from the alternator's fan/ventilator. (edit : that short pipe downward idea = great idea. And may I had , no need to keep the original heat flap conjunction setup either. I would make a U-Turn pipe to replace that)
Tho this is not the base of your current post, but, since it also has been said here. Make sure that the air flow from the main-pulley-fan/ventilator-air-shroud-thermostat-oil-cooler setup is fully functional. That setup has 2 goals :
-cold start and
-when the engine is up to temperature, the driver side flap will direct (let say) 50% of the air flows thru the oil cooler. If you put your hand under the engine on the driver side -outside of the engine bay- , when the thermostat finally operate, you will feel the air coming down from the oil cooler. Good thing to not over cook your engine oil. https://www.thesamba.com/vw/forum/viewtopic.php?p=7880429&highlight=#7880429 _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me |
