Trekker182 Samba Member
Joined: February 14, 2014 Posts: 99 Location: United Kingdom
Posted: Sat Mar 23, 2024 8:04 am Post subject: 72 Type 3 wiring diagram |
Hi Folks, does anyone have or know where I can find an individual/single wiring diagram for the starter system and one for the charging system suitable for my 72 fastback ?
Cheers
Don |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22439 Location: Kimball, Mi
Posted: Sat Mar 23, 2024 11:20 am Post subject: Re: 72 Type 3 wiring diagram |
Trekker182 wrote: |
Cheers
Don |
Honestly I don't know if there is just a partial wiring diagram posted anywhere. You could look in the wiring diagrams posted under the "technical tab" (upper right of the page). Keep in mind it defaults to type 2, so so'll have to click on type 3 to bring up those wiring diagrams. Just so you know, most of the wiring in the type 3 from 68 thru 71 is mostly the same as the 73. Where it differs is the 72 & 73 got a "computer diagnostic" system that works only at the dealership of old, and the cars came with extra wires just for it. Tram could explain it better than I can, as I don't have any type 3s with that system still in it or that had it. Sorry that's the best I can do. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Mar 23, 2024 2:45 pm Post subject: Re: 72 Type 3 wiring diagram |
Bobnotch wrote: |
Trekker182 wrote: |
Cheers
Don |
Honestly I don't know if there is just a partial wiring diagram posted anywhere. You could look in the wiring diagrams posted under the "technical tab" (upper right of the page). Keep in mind it defaults to type 2, so so'll have to click on type 3 to bring up those wiring diagrams. Just so you know, most of the wiring in the type 3 from 68 thru 71 is mostly the same as the 73. Where it differs is the 72 & 73 got a "computer diagnostic" system that works only at the dealership of old, and the cars came with extra wires just for it. Tram could explain it better than I can, as I don't have any type 3s with that system still in it or that had it. Sorry that's the best I can do. |
Thanks for that. My fastback has the diagnostic socket with all the extra 52 year old wires and many of them don't seem to match the wiring diagram. |
Posted: Sun Mar 24, 2024 11:52 am Post subject: Re: 72 Type 3 wiring diagram |
Trekker182 wrote: |
Bobnotch wrote: |
Trekker182 wrote: |
Cheers
Don |
If you have or can get a Brown Bentley manual (for North American models) I believe the extra wires are located in it (in it's own section). It's partly called out in the wiring diagrams with a circle around a number with it called out. Most of those wires go back to that socket plug in the engine bay.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
