roconn123 Samba Member
Posted: Mon Mar 25, 2024 4:16 pm Post subject: part identification |
Eurovan 2002 SWB/Weekender
Someone cracked the mirror casement on the driver's side and I am trying to repair myself. I need, however, to buy a part but I don't know the name of it.
It is a bolt/pin that attaches to a spring that secures the mirror to the car plate. (If I am using the right names - who knows.)
See some photos attached. Any sleuthing help would be greatly appreciated.
HeyCrutch Samba Member
Joined: August 12, 2022 Posts: 124 Location: Asheville, North Carolina
Posted: Mon Mar 25, 2024 4:31 pm Post subject: Re: part identification |
Can you highlight where in the mirror housing this part comes from? (Or describe it based on this photo) This might help locating it on the parts diagrams...
Or is the pin/bolt part of the glass itself? |
Posted: Mon Mar 25, 2024 5:32 pm Post subject: Re: part identification |
There are two pins. They attach/hook behind the electric panel to springs and then travel through the casement into the door panel.
They form a kinda both (1) hinge keeping the casing locked into the door (2) but also allowing the mirror to be pushed into the van to avoid what happened to me.
here is a video where these pins are pulled through the casing -
https://www.youtube.com/watch?v=fu7KTFn7v6Y
Thanks for responding I appreciate it!!!
Richard |
EuroTec Samba Member
Joined: August 24, 2020 Posts: 382 Location: Asheville, North Carolina
Posted: Tue Mar 26, 2024 4:16 am Post subject: Re: part identification |
Chances are you'll need to find a used mirror assembly. _________________ If it ain't broke, don't fix it! |
Posted: Tue Mar 26, 2024 5:07 am Post subject: Re: part identification |
7D185750 is the rear view mirror housing part# (left, left hand drive) - "for rear view mirror, electrically operated and heated."
The components of the mirror housing looked to be a single part.
However, the parts page also mentions this ...
1E 701858595
ball pin
no replacement part / M3X15
Hard to tell if that ball pin is what you are dealing with. I think Dean is right - a full side mirror housing might be your best option. |
bcolins Samba Member
Joined: December 04, 2020 Posts: 734 Location: Austin, TX
Posted: Tue Mar 26, 2024 10:17 am Post subject: Re: part identification |
I have a silver right side mirror assembly that the adjustment motor drive is no longer working on. I would take $50 for the complete assembly plus shipping if you are unable to find the part you need. Located in Austin, TX. |
TheOneTrueQuux Samba Member
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
