ahcheemjoe Samba Member
Posted: Wed Mar 27, 2024 8:01 pm Post subject: Original style tar boards? |
Several years ago, I repainted the engine area in my '63 convertible. At the time, I removed the original worn tar board and replaced with waffle pattern replacements. I've never been happy with them. They car is very original, and to my eye they don't look right.
Does anyone make a set that approximate the look of the original?
rcooled Samba Member
Joined: September 20, 2008 Posts: 2509 Location: Santa Cruz, CA
Posted: Thu Mar 28, 2024 3:30 pm Post subject: Re: Original style tar boards? |
KGP&R (Airhead Parts) has two styles of tar board for Ghias...the least expensive one is the waffle pattern. You'll have to call about the other to see if it's what you're looking for.
https://airheadparts.com/vw-parts/vw-body-parts/en...ear_=1963/
They're having a 20% off sale right now too. Discount code is MOV20. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
obus Samba Member
Joined: March 08, 2001 Posts: 11072 Location: just off Garden State Parkway Exit 81
Posted: Fri Mar 29, 2024 7:49 pm Post subject: Re: Original style tar boards? |
Not what he wants...
ahcheemjoe wrote: |
...waffle pattern replacements. I've never been happy with them...to my eye they don't look right. |
Posted: Fri Mar 29, 2024 8:04 pm Post subject: Re: Original style tar boards? |
rcooled wrote: |
ahcheemjoe wrote: |
Yes, these waffles are more like what I have.
Any other suppliers in US or international? Thank you. |
Posted: Wed Apr 03, 2024 7:20 am Post subject: Re: Original style tar boards? |
Is the answer that they do not exist? Maybe my only option is to search for an original set? |
Braukuche Samba Member
Posted: Wed Apr 03, 2024 7:32 am Post subject: Re: Original style tar boards? |
ahcheemjoe wrote: |
https://www2.cip1.com/c24-141-898-805-t/ _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
McFunzeepants Samba Member
Joined: February 04, 2015 Posts: 123 Location: Santa Cruz
Posted: Thu Apr 04, 2024 8:06 am Post subject: Re: Original style tar boards? |
I used them, they are not as thick as the orignal stuff but they look more like the original ones since they don’t have the waffle pattern. They are also stiffer and don’t flop around like a piece of rubber like the cheap waffle ones do. I doubt you can find anything nicer at this time. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Rome Samba Member
Joined: June 02, 2004 Posts: 9656 Location: Pearl River, NY
Posted: Sat Apr 06, 2024 1:30 pm Post subject: Re: Original style tar boards? |
Many years ago I spoke with Vince (RiP) who was the original owner of a '65 Ghia Cabrio nearby in northern New Jersey. He refurbished it and during that time mentioned that his factory-original firewall insulation had broken up and wanted to replace it. Vince was a resourceful person and came up with the idea that the sound insulation from the back of a washing machine had a very similar texture and appearance to the factory sound panel. He found a large section from a junked machine, cut it to match the factory panel and attached it. Looked very convincing.
Another method would be to find an original tarboard even if it's partially broken or torn. Glue it back together using thin aluminum flashing on the back side to hold the pieces or joints together. Then apply roofing tar paper to the surface that you see in the engine compartment. Glue it on with contact cement and use a small roller to work out any air bubbles. The only issue then is that the thin flashing may prevent the triangular steel spikes on the firewall surface to pierce thru to hold the panel. |
Marcdeb Samba Member
Posted: Sat Apr 06, 2024 9:06 pm Post subject: Re: Original style tar boards? |
Thank you. This is very helpful. Great site. |
Loren Samba Member
Posted: Fri Apr 12, 2024 1:19 pm Post subject: Re: Original style tar boards? |
I just got the Cip1 tar board set and it's actually very nice. The material is very close to the original tar board found on later Ghias. Unfortunately, it has cut outs for later Ghias, so I can't really use it on my 58 Ghia project. Its a shame they didn't omit the cut outs and provide a template to cut them out if you needed them. As stated above, they are about half as thick as original boards, but they are rigid and look nice. I still haven't found a good replacement for lowlight tar boards. |
Posted: Fri Apr 12, 2024 2:08 pm Post subject: Re: Original style tar boards? |
Loren wrote: |
That's not good. I looked and the description actually says it fits 56 to 74. Not much detail included in the description. Now it also says out of stock. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
