swmoboy Samba Member
Joined: March 03, 2021 Posts: 9 Location: Springfield, Missouri
Posted: Sun Apr 21, 2024 2:52 pm Post subject: brake line rubber grommets |
Does anyone have any suggestions how to install the rubber grommets on a 64 bus. I do not recall where I bought the grommets but the rubber seems to be too firm to want to install. I've destroyed a couple trying to force them in. I've tried lubrication with no luck. Interesting the ones I have the groove that would fit in the frame does not seem to be very wide. The rubber is also very firm. Any suggestions where to purchase better grommets and hints to install are appreciated. |
amishman Samba Member
Joined: March 09, 2004 Posts: 3219 Location: California
Posted: Sun Apr 21, 2024 6:15 pm Post subject: Re: brake line rubber grommets |
Funny I just purchased some myself as I am doing brakes on the rear and it seemed odd where the brake lines go through the metal holes, mine had no rubber grommets it seemed weird so I found grommets to be used after reading up about it.
Past times I did grommets I used a small blade screw driver to help push them into place after starting it on none edge by hand so will be reading any posts made here to offer me tips as well.
The grommets I purchased have a split on them and they seem bendable so though starting one corner and then use a small flat blade to tuck them in would work?
TJ _________________ tj (the Amishman)
Come visit my web site!
http://www.vwhippie.com |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sun Apr 21, 2024 6:53 pm Post subject: Re: brake line rubber grommets |
amishman wrote: |
TJ |
That's what i do. Works every time |
Jimone Samba Member
Posted: Mon Apr 22, 2024 5:43 am Post subject: Re: brake line rubber grommets |
i just got the last one on my bug...
those things were miserable. hard to get to. hard to move. easy to tear.
patience it the best thing i can advise. i got mine eventually. i probably tried the last one 20 times. _________________ november 1952 ragtop
november 1954 single cab |
