Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Sun Apr 21, 2024 6:41 pm Post subject: Squareback outer popout window seals |
I’m trying to put on the outer seals on the pop out windows of my 68 Squareback. I thought the inners were a pain, but these are crazy. Can I get a closeup of how they’re mounted to the frames? Like their orientation, inner and outer. Things like that. And any tips on how to get them into the groove too. Thanks. _________________ If you`re going to do something, do it right. |
ajb164 Samba Member
Posted: Mon Apr 22, 2024 1:20 pm Post subject: Re: Squareback outer popout window seals |
I just did some recently. What’s the issues you are having? The outer ones are pretty straight forward I believe.
If you want pics can you be a little more specific of the angle and I’ll take some.
If I remember correctly, figure out where you want the seam first and start there. I put mine to the front upright in the middle or as close as possibly basically mirroring the inner seal/seam. One thing I did was to slightly stretch the seam making the portion slight smaller to slip in to the channel. I used a spray bottle with soap and water for lube.
One other thing to note is as you round the window it may seem like it’s a bit too large. You will have to work the seal back to take up the slack.
Hopefully this helps _________________
EverettB wrote: |
Moderator note:
Please don't post anything that calls my wife names or insults her if you want continue using this thread.
I will lock or delete the entire thing (seriously) if I have to. |
Posted: Mon Apr 22, 2024 1:58 pm Post subject: Re: Squareback outer popout window seals |
ajb164 wrote: |
Hopefully this helps |
I was mainly just wanting to know which side of the outer seal faces outward. But I got it. Thanks. _________________ If you`re going to do something, do it right. |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3710 Location: San Jose, CA
Posted: Mon Apr 22, 2024 3:17 pm Post subject: Re: Squareback outer popout window seals |
Bryan67 wrote: |
I was mainly just wanting to know which side of the outer seal faces outward. But I got it. Thanks. |
Theres's a flap that should sit over the front. Basically, the pop-out frame will kinda look like the window trim on the other seals when the inner and outer pop-out seals are installed. A lot of people mess this up, unfortunately. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22468 Location: Kimball, Mi
Posted: Mon Apr 22, 2024 3:44 pm Post subject: Re: Squareback outer popout window seals |
ajb164 wrote: |
Yup, I've found slightly stretching the seal to get it into the groove works well, then bunching it up after 8 or so inches. I use a little soap and water to lube the seal onto the frame. Plan on spending some time getting the outer seal on, as it's a fiddly job that takes time. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
