Stewey Samba Member
Posted: Sun May 05, 2024 11:39 am Post subject: Twin carb tuning |
Seeing as tuning involves equalising the throttle plate openings, has anyone got comments on equalising the openings via the rpm of the separate carbs as opposed to balancing the vacuums? I’m thinking of balancing the carbs with a digital strobe light on No 2 and 4 cylinders to equalise the rpm.
Just a thought!…but I have the vacuum equalisers anyway.
Thanks….Stewey |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 10220 Location: Oregon
Posted: Sun May 05, 2024 11:49 am Post subject: Re: Twin carb tuning |
What carbs are you working with? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Stewey Samba Member
Posted: Sun May 05, 2024 12:09 pm Post subject: Re: Twin carb tuning |
Twin EMPI 34 EPC’s
Just a bit of lateral thinking! |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4031 Location: viroqua wi.
Posted: Sun May 05, 2024 12:18 pm Post subject: Re: Twin carb tuning |
Stewey wrote: |
Thanks….Stewey |
They share a common crank shaft. |
Posted: Sun May 05, 2024 12:21 pm Post subject: Re: Twin carb tuning |
I usually set the throttle plates at 0.003." I set them with the carbs off the engine. Slip a feeler gauge between the carb body and the throttle plate and adjust the idle screws until you feel a slight but equal drag on the gauge on each carb.
That will at least get the engine running pretty well before you tackle the carb sync.
If you don't have a carb sync tool. Search YT for the home made carb sync tool. It involves a couple water bottles, some hoses.
I use a "snail sync tool to set my dual carbs. _________________ I have learned over the years.
Buy Once, Cry Once!
Dodgy Samba Member
Joined: January 30, 2006 Posts: 523 Location: Leicester, UK
